Question about Williams 2509612 Ceramic Mid-Size Heater
Chipping oven coating
The coating on the inside floor of my oven is chipping off. Is there anything I can do to fix it? Is it dangerous?
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 79 Answers
You could cover it with Esd Mats
Posted on Mar 04, 2013
My sisters has a Sharp microwave r-403hw was manufactured july 2003 my question is how long are you allowd to keep a microwave for and if the inside chips from the paint is still ok to cook food in it or...
As long as the microwave oven is working to heat or cook according to the program set , the micro wave can be used safely. Now if there is any chipping of the paint within the oven chamber, then you can re-coat the inside with non conducting ceramic paint.
However if there is no issue if there is no damage to the inside or to the working of the microwave as you can use the oven till it fails to heat.
Jan 25, 2011 | Sharp R-403HW Microwave Oven
I have a 0.9 cu ft homestyles microwave oven model 7560. The finish is chipping away from the front and side of the oven where the door closes against that area.. Would this cause a leak in the...
This will not cause a leak, if the chipping is in the microwave cavity it will make the micro arc, and will kill it after a few times. But if its not in the oven cavity then you are good
Dec 21, 2010 | Microwave Ovens
Chipping/peeling rusting paint in interior under carousel
Scratches and bare spots are fairly common, but should be addressed as soon as they arise so the corrosion will not spread and arcing does not occur.
Unplug the power cord and remove the turntable and the support that is under the turntable. Clean the surface of the support wheels or any other part that rubs on the oven cavity.
Take some mild sanding cloth or scotchbright and clean the bare and rusted areas in the microwave. Use appliance touch up paint to re-coat the surface. You can find the touch up at most anywhere that sells appliances, it comes in a plastic bottle similar in appearance to fingernail polish, yes it does have a brush inside.
Let it dry per the instructions on the bottle or 24 hours if not specified.
May 11, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
On the bottom of my microwave, the coating started "chipping" off and now there is a fairly large area that appears to be rusting and makes where the turntable wheels rest look really dirty. Is there...
This is often caused by spills and condensation.
The metal will have to be sanded smooth and clean.
You can use a wire brush and naval jelly to get rid of the rust.
If any rust remains, you can use Rust Reformer paint to stop the rust process, then sand it smooth when it's dry.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart or Lowe's.
Nov 23, 2009 | Emerson Microwave Ovens
Our Whirlpool Refrig GD25DFXFW02 is working fine our problem is the ice maker , the cubes contain white flakes, is there a coating on the ice maker that could be chipping off> We have changed the filter...
The inside coating has come off the inside of the ice maker . The white " flakes " is calcium deposits , sticking to the exposed cast metal , inside the ice maker , and sticking to the cubes , after water freezing in the mold . You need to replace the ice maker .
Nov 02, 2009 | Whirlpool ED2FHEXN Side by Side...
Chipped coating
NO PROBLEM the coating is only there to keep the pot from sticking to the burner and to look good . as the problem gets worse you will need to "TAP"the handle of the pot to unstick it from the burner before picking it up to pour . please rate this answer, thanks
Feb 08, 2009 | Mr. Coffee 12-Cup Programmable Coffeemaker
Enamel chipping
the interior of the oven cavity is chipping??? if so not a worry or concern for saftey or health concerns stictly cosemetic
Nov 12, 2008 | Ovens
The inside of my microwave is chipping away. I can see metal in some spots already! Please help
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 20, 2008 | Microwave Ovens
Oven enamel chipping
Never heard of such a problem, you are the first to post it. There is no fix for this.
Apr 03, 2017 | Dacor Epicure ERD30 Dual Fuel (Electric...
Williams 2509612 Ceramic Mid-Size Heater Logo
Top Williams Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
