Question about Intel Motherboard
Ga-72gx Need to know hook ups of power switch,etc,etc on motherboard
  • 158 Answers
Go through the tutorials here.
Get back if help needed thnx
Posted on Jan 21, 2009
CPU is On but Cable not connected error
Oh? Did this just happen?
Or are you installing this motherboard for the first time?
Will help to know, because you may not have the necessary needed, power cables plugged in,
OR;
One or more of them may be loose.
I also see that English is not your native language. I apologize that English is all I know, in advance. If you see something printed here you do not fully understand, post back in a Comment.
We will work it out.
Gigabyte GA-8I945GZME-RH,
(GA-8, capital I, 945GZME-RH, not GA-81945GZME-RH ),
http://www.geeks.com/details.asp?InvtId=GA-8I945GZME-RH-BO
Gigabyte Support > GA-8I945GVME-RH motherboard > Main Support page,
http://ee.gigabyte.com/products/page/mb/ga-8i945gzme-rh/download/
See where it states -
Advantages/ Overview/ Specification/ Downloads/ News/ Awards?
Look at the black bold subheading under it - Download type: and under it - Drivers - in the box.
Click on the blue arrow to the right of the box.
In the drop down list click on - Manual
In the list go to the second file down.
English - 1003 - 5.4Mb - 10/07/2006
Left-click on the blue -> FTP
This is a PDF file. After you click on FTP, it may take up to 30 seconds before the first page comes up.
Power cables to motherboard;
1) 24-pin ATX main power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
2) 4-pin ATX +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
Notice how both power cable connectors have a LOCK on the side?
Look at the photo in the middle for both power cable links, above.
The connector on the motherboard has a TAB, that the Lock goes over.
Hooked end of Lock, goes over Tab on female motherboard connector.
When the hooked end of the Lock is over the Tab, on the motherboard connector, you KNOW the power cable is plugged in tightly.
If not, there is your problem.
Do you have the SATA power cable plugged into the Harddrive, tightly?
SATA power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
Do you have the SATA data cable plugged in tightly to the motherboard, AND to the Harddrive?
http://en.wikipedia.org/wiki/File:SATA_ports.jpg
CPU = Central Processing Unit. Another term used is Microprocessor, or simply Processor for short.
Does NOT mean personal computer.
CPU is on? You mean the Power Supply's fan is running, and computer case fans, and Processor fan.
Does not mean the Processor is on.
Why?
Primer:
You press the Power On button. This plastic assembly pushes against a Power On switch,
http://www.axiontech.com/prdt.php?item=78201
The Power On switch is a Momentary Contact Switch.
It closes very briefly, which in turn briefly completes a circuit.
The Soft Power On circuit.
The Power Supply always has a constant 5 Volts present, when it is plugged into power. A 5 Volt reserve power, called the 5 Volt Standby power.
Closing the Power On switch briefly provides a Ground, and completes the Soft Power On circuit.
The Soft Power On circuit excites the Power Supply, and turns it on.
The first chipset to receive power is the BIOS chipset.
The Basic Input/Output System program, on the BIOS chipset, is initialized. (BIOS program)
BIOS looks to see what devices are connected, does a Ram Memory count, TURNS the Processor on, and hands the computer over to the Operating System.
(Windows XP, and Windows 7, are two examples of an O/S)
You are getting a 'Cable not connected' error message, which means BIOS hasn't turned the Processor on.
Is the 4-pin ATX +12 Volt power cable plugged in, and tightly? It's power for the Processor.
Post back in a Comment.
Regards,
joecoolvette
Jul 04, 2012 | Gigabyte GA-8I945GZME-RH Motherboard
How to connect the connectors power switch - hdd led - reset switch etc on a motherboard GA-K8NSC-939 ?
Click here for the Motherboard manual and refer page No.23 for Front panel wiring details.
Feb 18, 2012 | Gigabyte GA-K8NSC-939 Motherboard
What power supply do I need for the Gigabyte GA-MA790GPT-UD3H Motherboard. I will be using an UPS to keep power on for 10 minutes if the mains fails.
At an average PC with 17"CRT Monitor consumes 200-350 Watt. Allied peripherals and accessories etc. add to the overall power consumption. Hence, it is alway better to keep a buffer while estimating power consumption. So, It is recommended that UPS of atleast 500W may be used. (UPS of higher Power Output /Wattage would allow to keep up some other devices as well in case of power failure)
Also, CPU Power Supply (Internal) generally should be 350-450 watts.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck!
Don't forget to convey your feedback
CreativeTECH
Jan 18, 2011 | Gigabyte GA-MA790GPT-UD3H Motherboard
I need the front panel wiring specs for power switch and so on fo a ga-7dx rev 2.2
that model does not come up on the eb page for gigabyte so need to know the socket type to get the informaion you need psot it here and I will try getting it again
Aug 20, 2009 | Gigabyte GA-7DX Motherboard
GA-8pe800 pro and kvr333x64c25 memory problem
the 1g is defective return it and get a replcement
Mar 28, 2009 | Gigabyte GA-8PE800 PRO Motherboard
Switch led etc connections for gigabyte ga 72xe
i need a manual for the ga 72xe motherboard
Oct 19, 2008 | Intel Motherboard
Printout on a ga-72x motherboard
go directly to manufacturer website and download pdf file on user manual
Feb 24, 2008 | Computers & Internet
Need a diagram of motherboard pins
The link below will take you directly to the GA-7ZX family page. You will have to figure out which revision/series board you have and download the appropriate manual. http://www.gigabyte.com.tw/Support/Motherboard/Manual_List.aspx?Keyword=GA-7ZX. Good luck and don't forget to rate this post.
Jul 13, 2007 | Gigabyte GA-7ZX Motherboard
Intel Motherboard Logo
44 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
