Question about Hotpoint Ultima WF860 Front Load Washer
Hotpoint ulima wt721
Hiya can you tell me what code f02 is
  • Hotpoint Master
  • 3,463 Answers
Error code F02 means the motor has jammed, and or the tacho is loose or broken.
You will find the tacho on the opp end of the motor to the pulley..
Check to see if it is loose or broken, if it is loose, just push it back in to position.
Plz rate my solution,
Thanks.
Posted on Jan 22, 2009
Hotpoint aquarius super silent WF630 FAULT CODE F02
[/spoiler] [spoiler title="EVO1 Washing Machines and Washer Dryers" open="0" style="2"]
  • F01 - Short circuit motor triac*
  • F02 - Motor jammed tacho detached*
  • F03 - Wash thermistor open/short circuit*
  • F04 - Pressure switch jammed on empty*
  • F05 - Pressure switch jammed on full*
  • F06 - Program selector error*
  • F07 - Heater relay stuck*
  • F08 - Heater relay cannot be activated*
  • F09 - Incompatible eeprom*
  • F10 - Pressure switch not sensing correctly*
  • F11 - Pump cannot be activated*
  • F12 - Communication error*
  • F13 - Dryer fan or dryer thermistor faulty*
  • F14 - Dryer element faulty*
  • F15 - Dryer element relay faulty*
  • H20 - Not fillings. Check tap, hose and inlet valves
  • LOCKED - Check interlock*
Error Codes Hotpoint Service
Aug 24, 2015 | Hotpoint Washing Machines
My Hotpoint ultima WT721 1200 spin keeps tripping out all plug sockets. Have changed fuse but still does it. What could it please?
hello, bad earth check all the wired connection to the washer if these are ok then check your socket wires make sure wires are tight if these ok then there may be fault inside the washer power supply hope it helps
regards
shaun
Jan 15, 2011 | Hotpoint Washing Machines
What does the message F-08 mean on my Hotpoint Ultima wt721 please?
Error code F08 that the heater relay cannot be activated.
Check all connections to the module, pressure switch, and heater element.
Hope this helps.
Feb 01, 2010 | Washing Machines
My hotpoint washing mechineall displays flashing when we put on .why?model wt721
Basically it is telling you that it has an error. Countthe number of flashes and see which lights actually flash and then refer to your user manual and it should identify what is wriong.If you don't have one then see which lights are flashing and drop me an email to kw7157@yahoo.co.uk in the next 8 hours.
Nov 10, 2009 | Samsung Washing Machines
Hotpoint ultima wt721 error code fo2 showing! will not work properly!
Error code F02 means the motor has jammed, and or the tacho is loose or broken. .Check the motor hasn't jammed up somehow, or that the small tacho coil on the end of the motor hasn't dropped off (tip the machine back and it's in between the brushes - it should be held in place with a clip. If it's hanging loose it's the fault)
This fault code basically means the PCB cannot detect any impulses from the tacho coil on the motor, so the main implication is that the motor is just not running. However, because other fault codes cover most of the other motor faults, the PCB thinks the motor may be physically jammed. That is, as far as the PCB is concerned, it is supplying the motor with power, but it can't detect the motor is running. This fault is not caused by worn carbon brushes because on these washing machines, an open circuit on the motor causes the washing machine to do nothing at all. It would not fill, or empty (as well as the motor wouldn't run) although the indicator lights would work.
Nov 03, 2009 | Hotpoint Ultima WF860 Front Load Washer
What do the F11 and F02 mean?\
hiyas here is the meaning for the codes
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
F11 Means
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Potential Causes
• Check Wire Harness connections to the MCU, the motor, and Central Control Unit (CCU)
• Check the Drive system for any worn or failed components
• Check MCU
• Check CCU
• Check Motor
Replace failed component.
I would suggest that you possibly call out an engineer
Jul 20, 2009 | Whirlpool Washing Machines
Help with correcting fault code f-5
F-05 error means:-- Water Temperature Sensor Error
If during the water heating step in wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed.
TO RESOLVE THE PROBLEM:--
Check the Water Temperature Sensor, Heating Element and Element Relay globul1a.gif Check connections to the Sensor, Heating Element and Relay
May 07, 2009 | Washing Machines
Found filter on front of my WT721 hotpoint but tried turning anti clock wise it turns slightly but can,t get if off !
You are turning it the correct way, could be something stuck in the filter, just keep trying to unscrew it and pull hard at the same time.
Please rate my solution.
Thanks.
May 03, 2009 | Hotpoint Ultima WF860 Front Load Washer
Test on display cant use washer
turn the machine on while you press the start and on buttons at the same time until dOFF appears.
Dec 17, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
HOTPOINT ULIMA WT721 FAULT CODES F5 AND F11?
my hotpoint ultrima wt721 has stopped with f-5 showing the door has stayed locked wot do ido
Jul 15, 2008 | Washing Machines
Hotpoint Ultima WF860 Front Load Washer Logo
714 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
