Question about Gemini DJ Gemini FirstMix I/O
No sound coming out the headphones on the Gemini firstmix I/o
Hie lost license key gemini io firstmix pro please help
Isn't the license on the software, not the Gemini unit?
Here is the website for Cross DJ Mixvibes software. In case you can't find your copy.
There's a free version, a $39 version and a $89 version.
Cross DJ app for Mac PC Free and Pro versions By MixVibes
Sep 07, 2016 | Computers & Internet
How do I set the record back to the beginning after cuing or listening to half the track?
All you have to do for that is hit the CUE button twice rapidly and it'll re-start from the beginning.
Dec 28, 2014 | Gemini DJ Gemini FIRSTMIX-PRO DJ...
Need help with a sound problem im experiencing with my Gemini CNTRL-7 controller
Hey, try changing your default playback device. Your controller may be trying to tell your PC that it has a speaker, changing the playback device to your speakers may fix this. (if using windows, right click on your speaker icon - lower right hand corner, select 'playback devices' and then choose your usual device - if you don't know which one is, then just select different ones and see what works)
Later,
Beau.
Jun 20, 2014 | Gemini DJ Gemini CNTRL-7 USB MIDI DJ...
Gemini FIRSTMIX PRO can't volume on master output
Dear Joshua Chan, I suspect there is a problem with your sound card driver. Could you please try to use some free driver update software and see if this tackles the issue?
Jan 26, 2014 | Gemini DJ Gemini Firstmix Pro DJ Software...
I cant get my headphone to work on my gemini cntrl-7.
If you are using virtual dj , adjust your settings under configuration - sound setup , change the output settings to headphones.
Jun 08, 2012 | Gemini DJ Gemini CNTRL-7 USB MIDI DJ...
Where do i plug my speakers in on my cdj 600's? got it working through the headphones everything else is useless??
You connect POWERED speakers to the left and right outputs... You MUST use POWERED speakers or an external amplifier. This unit has a small headphone amp, but that CANNOT power passive speakers.
Apr 22, 2011 | Gemini Sound Products Gemini CDJ 600...
Gemini DJ Gemini FirstMix I/O Logo
46 people viewed this question
Top Gemini DJ Audio Players & Recorders Experts
chuck ringwood
chuck ringwood
James Kovacs
James Kovacs
Gil Shultz
Are you a Gemini DJ Audio Player and Recorder Expert? Answer questions, earn points and help others
