Question about Vizio L6 20.1 in. HD-Ready LCD Television
Tv on no picture no sound tv making a pulsating humming noise.
Cable is connected. Power is OK... turn TV has no picture, no sound, white screen with tv making a pulsating sound. Tried disconnecting and plugging back in still no change... Wonder if TV has died... less then a month old.... can this be...
  • 362 Answers
Hi phalbeis, Unfortunately it looks like the power supply has failed, since the unit is new I would check into the return policy of the store you bought it from, if your lucky you can just exchange it. If not it will have to be shipped back to the manufacturer.which can be a hassle, you may have to pay the shipping to the repair facility.
Let me know how it goes and please rate this solution. Lone99star
Posted on Jan 21, 2009
Toshiba model 42hp66 Plasma flat screen Problem No picture or sound. Pushing on button 2 clicks are heard A slight hum is heard at the Z SUS board. Green power light is on (power light is...
Hi
There are some factors of this kind of problem.
First you could have a failure in the power supply. Next could be the main board. Lastly you could have a problem with the panel itself, this would mean a new set for sure because the part cost is more than a new set.
However try troubleshooting the problem before spending money on repairing or replacing the television. Possibly you can restore the picture and sound to your television ...
Verify the TV is powered on by pressing the power button on the TV's remote or the front panel of the set. This may seem like an obvious step, but many TVs are equipped with a standby light that will illuminate if the TV is turned off, making it appear that the TV is on when it is not.Cycle through the TV's video inputs to verify that your TV is set to the right one. For instance, if you are attempting to use a digital cable converter box that is plugged into the Video 1 input and the TV is set to a Video 2 input that has nothing plugged into it, the TV will not display any picture or sound and may even say "No signal" on the screen. To cycle through the inputs, use the input selection button, typically labeled "input," "source," "TV/video" or the like.
Re-seat the video and audio input connections to verify a loose cable is not causing the TV's loss of signal. If you have a coaxial cable connected from your wall cable jack directly into the TV, it may have come loose thereby eliminating all picture and sound on the TV. Locate the connection cable or cables of whatever device you are attempting to watch and unplug them from where they plug into the TV. Plug them back in and check for a signal. If there is still no picture or sound at this point, the best option is to contact technical support for further assistance.
Apr 22, 2011 | Toshiba 42HP66 42 in. LCD Television
The screen is green no color at all it makes aloud humming sound what is the problem we replaced the lamp last year
Do you have a cable box going to the TV and is this condition on all of the inputs or just one. Chances are you have standard video connection plugged into the component inputs.
If you have a (yellow/red/white) cable make sure you have it plugged into a connection on the tv that matches those colors because if you have a standard video (yellow) plugged into the Green then you will get a black and white picture.
If you are plugged into a component connection you will need a total of 5 RCA style wires. One will go from Green to Green, another from Blue to Blue, another from Red video to Red video, anther Red audio to Red audio and white audio to white audio.
The common mistakes made with this connection is the reversal of the RED video and RED audio which will cause the humming noise you spoke of as well.
Thanks,
Robert
Mar 01, 2011 | Hitachi 60V500 60" Rear Projection...
White Westinghouse flat screenTV freezes up and hums.
Sometimes if you just press on your overscan button on the remote and make the picture a little bigger or smaller the humming noise and freezing of the picture will actually stop.
Jul 27, 2009 | Westinghouse SK-26H240S Television
Green light is on ...white noise sound but no picture
This TV finds the connected input sources
automatically for AV1, AV2 and Component 1-
2. It is presumed that RGB and HDMI/DVI
sources are connected.
Check your setup to see if the audio is turn off but if you have a clear picture you should have sound.
Time to call a TV Tech if you are not going to repair the unit.
Jul 11, 2009 | LG 42PC3D 42 in. Plasma Television
My lcd tv makes a humming noise
My 37 inch vizio did the same thing. go to your menu screen on the tv and go sound. My tv has an option to turn speakers on/off. Once I turned my speakers off and the back on again everything worked great. hope I helped! if I did please let me know! youtube.com/xniax1
Mar 21, 2009 | Vizio VW37L 37 in. LCD HDTV
Tv makes a humming noise
check for bad color wheel....may sould like a grinding sound
Mar 01, 2009 | Samsung HC-P4752W 47" Rear Projection...
Tv hums when hdmi is connected via dvd player
how do you have the audio hooked up for it if you are using componet cable (red,white) for sound they could be causing the humming you can either switch audio cables or use some other form of cable for sound
Jan 24, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Sony KV XA 21M80 Trinitron- HUMMING NOISE AND PICTURE NOT CLEAR
If your set has a humming noise when connecting the cable, call your cable company. There is a ground issue. This can also be a safety issue.
If your signal is PAL, and your TV is NTSC only, you will have to replace the TV with a PAL one in order to properly view the programs.
Jerry G.
May 15, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Samsung lcd ln46a550pf3 no sound from hdtv reciever
ok your tv does not come with the very best sound, you have to get a receiver 7.1 or you can use the optical wire , that's if the system you are using has that option.
Apr 10, 2008 | Samsung LN-T4665F 46 in. LCD Television
Vizio L6 20.1 in. HD-Ready LCD Television Logo
163 people viewed this question
Top Vizio Televison & Video Experts
Dave Naylor
Dave Naylor
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
