Question about Motorsports
Need firing order for l18 motor 1974 datsun pickup somebody took spark pklug wires off dont know right order to replace them
rob82abn
  • 28 Answers
SOURCE: coil wire shorting out, replaced wire, still no spark
I HAVE A QUESTION THAT MIGHT HELP, THE 22-RE 4 CYLINDER HAS A STEEL TIMING CHAIN, IVE BEEN TOLD THAT THE V-6 HAS A RUBBER TIMING BELT ON THE SIDE OF THE MOTOR UNDER A COVER?
Posted on Feb 21, 2009
bschilz
  • 2049 Answers
SOURCE: Firing order for Spark Plug wires
Here is the diagram you ask for. While it says it is for the 3.0L V6, it is the same for the 4.0L V6 if that's what you have...
Posted on Feb 15, 2010
c17hydro
  • 2984 Answers
SOURCE: need fireing order for 1998 gmc 2500 pickup, 454 engine
Here ya go:
Posted on Apr 18, 2010
  • 1757 Answers
SOURCE: I need to know the firing order of my 1995 limited...
For the 1995 Jeep Grand Cherokee:
I do not know if you have the 4.0L In-Line (Straight) 6-Cylinder or the 5.2L V8; however I have included bothe below.
For the 4.0L In-Line 6-Cylinder:
Firing Order:
1-5-3-6-2-4
Cylinders:
(back)
|..6..|
|..5..|
|..4..|
|..3..|
|..2..|
|..1..|
(front)
Distributor:
...(back)
....5...3.(+)-screw
1...........6
(+)4...2
...(front)
For the 5.2L V8:
Firing Order:
1-8-4-3-6-5-7-2
Cylinders:
.......(back)......
|..8..|........|..7..|
|..6..|........|..5..|
|..4..|........|..3..|
|..2..|........|..1..|
.......(front)
Distributor:
.......(back)
.........3
...4.........6
8...............5
...1.........7
.........2
.......(front)
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.com!
Posted on May 27, 2010
  • 17 Answers
SOURCE: I took of*** my spark plug wires working on my
Next time number each lead before you remove it and no. the dissy cap as well
The firing order, which should be cast into the intake manifold, for the chevy small block V8 is 1-8-4-3-6-5-7-2. The firing order is the numerical sequence in which the spark plugs are fired. The insertion position of each spark plug wire around the circumference of the distributor cap can be found according to a clock face. The insertion sequence determines the firing order. The firing order is followed clockwise around the distributor cap starting from the 6:30 position with the 6:30 position being the number one cylinder spark plug wire.
On classic chevy small block engines that use ignition breaker points instead of electronic ignitions, the number one cylinder is the one immediately clockwise of the small metal sash cover on the distributor cap. The firing order starts here. There is no sash cover on the distributor cap for GM HEI electronic ignitions, and the firing order is the same, but starting at the 5:30 position.
The firing order makes sense if you know how the cylinders are numbered. The number one cylinder is the front most on the drivers side and 2 being the front most on the passenger side. From front to back, the cylinders are odd numbered on the drivers side, and even numbered on the passenger side.
See the diagram; Click to open a printable larger image in a new window. The firing order starts with the number one cylinder. We would connect the number one spark plug wire to the distributor cap terminal in the 6:30 position. distributor.pngSince the next cylinder in the firing order is 8 (passenger side rear), we connect the number 8 spark plug wire to the next distributor cap terminal (approximately 7:30 position) in the clockwise direction from number one. You need to be sure you continue the firing order in the clockwise direction around the chevy small block distributor cap from the last installed spark plug wire. Setting the rest of the firing order is just a matter of repetition. Be sure to count the spark plugs from front to back on each side of the motor to identify the correct cylinder number in the firing order.
Posted on Jun 21, 2010
1974 truimph spitfire mk4 firing order
Edward, Firing order 1-3-4-2 for spitfire. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Engine Tuning Data for the Triumph Spitfire and GT6
Distributor drive gear and firing order question Spitfire GT6 Forum...
getting spark plug wires back in the right order MGB GT Forum MG...
http://www.repairservicemanuals.com/Triumph
Jun 14, 2016 | Triumph Cars & Trucks
Can i replace motor in 1984 nissan pickup with 1982 datsun motor
you can put any engine (and) transmission into your pickup you will need to
make the motor mounts and trans mounts and the drive shaft
but if you are trying to bolt the datsun motor to the nissan i dont belive'
this is coing to work i hope this helps you bob...
Oct 14, 2011 | 1984 Nissan Pickup
I mixed up the firing order on my spark pkug wires when i removed
I can post an awesome diagram but I need to know your engine size...
2.2L
2.7L
VTEC
May 26, 2010 | 1997 Honda Accord
Need the firing order digram for a 1996 nissan pickup 2.4 ltr
1996 Nissan/Datsun Truck Pickup 2WD 2.4L SFI 4cyl
The Firing Order:
Firing order 1-3-4-2 --------- front | | of | 1 2 3 4 | distributor rotates counter vehicle | | clockwise ---------
Hope helped with this (remember rated this help) Good luck.
Nov 04, 2009 | 1986 Nissan Pickup 4WD 1986
Coil wire shorting out, replaced wire, still no spark
Feb 20, 2009 | 1991 Toyota Pickup
Change head gasket 1974 Datsun 620 pickup
As far as compresion goes it is more important that all cylanders are close to each other than what the actual psi is they should be within about 5 psi of each other. When changing the head gasket on the 620 you need to make sure that you wedge the timing chain so that the chain tensioner does not pop out. If it does you need to remove the water pump and front engine cover to replace it. A 6 inch long piece of wood tapered from about 1 inch to about 1 3/4 inch should work. Other than that it's a very easy and straightforward job. I would recomend that you take the head to a machine shop and have it checked for warp, if the engine has been severly overheated it can cause the aluminum head to warp. I know this from personal experience. If there is some warpage just have the machine shop machine it back to flat so that the new head gasket dosen't leak. If you are getting oil comming OUT of the dipstick tube replace the PCV (positive crankcase ventilation) valveThe 620 is a great little truck and the L16 L18 and L20 engines were all very easy to work on and well designed. The downfall of almost all Datsuns was body rust.
Oct 18, 2008 | Datsun 210 Cars & Trucks
Motorsports Logo
46 people viewed this question
Top Motorsports Experts
_-__-___-_
_-__-___-_
chuck ringwood
chuck ringwood
Jim Rus
Jim Rus
Are you a Motorsport Expert? Answer questions, earn points and help others
