Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Major leak after 20mins into wash cycle!
Hotpoint Aquarius washer dryer WD1200. Water appears to be coming out of beneath drum. The hoses appear fine.
  • Hotpoint Master
  • 3,463 Answers
Have a good look at door seal., and see if you can see any hole or tear in rubber.If o/k, then remove rear panel, and watch whilst it is running, and see if you can see any sign of water coming from anywhere.
Make sure the water is not running down the front from the dispenser, which would suggest a blockage in the dispenser drawer.
These are the steps I would take first.
Also make sure the waste outlet is clear
Plz leave rating and any comment you may have.
Thanks..
Posted on Jan 21, 2009
I have a water leak during use. I have removed top panel and leak appears to be coming from top of hose between detergent dispenser and drum. Hose does not appear to be split. I noticed that there is no...
There should be a plastic clip or similar to hold the hose on, this is probably where the water is coming from.
A normal jubilee clip will suffice, or a strong plastic tie.
Jan 07, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint Aquarius waher dryer
possible blockage ' filter or could aslo be water coming back from the sink if drain hose too low , you may need to raise this....
Nov 13, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
WATER IS COMING OUT FROM THE BOTTOM OF THE WASHING MACHINE ONCE THE WASHING HAS STOPPED, IT DOES NOT LEAK DURING CYCLE AND IT SPINS AND DRAINS FINE..
i would inspect both the hoses on the pump
no leak during cycle is explained because water is moving through them to fast to leak when the machine settles it starts to leak
Oct 15, 2009 | Hotpoint Aquarius WD63 Front Load...
Door/drum seal has split causing a major leak also had probs for last few months where it gets to last 10 mins of cycle then it just counts down and doesnt complete the cycle it then gets stuck on 1 min...
Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting.
And rate me nice pl for the free help!
Feb 18, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius washer dryer!
The water is coming out of the dispenser because it is going into spin with water in the drum due to it not draining properly.
So you need to check the filter.
If there is no filter at the front bottom of m/c, then you need to remove the lower rear panel on the m/c, locate the large black hose going to the bottom of the drum, undo the clip[ securing hose and remove hose.
There you will find the filter, remove and clean.
Check the pump at the same time for any obstruction.
Refit hose, making sure you get it on properly.
Test for leaks before fitting back panel.
Plz rate this solution.
thanks.
Dec 21, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Leaks after wash programme ends
Check your inlet hose or hoses if it is hot and cold fill.
Turn off supply to washer and see if it still leaks, if it does then you have water coming from inside m/c somewhere
Nov 23, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius 1000 washer/dryer
cleared blockage from end of drain from machine.
Jul 27, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD420 5+5Kg
The water level vacuum switch are not working , check hose might lose.
Dec 31, 2007 | Hotpoint Aquarius WD640 Front Load...
Washers leaking
SOUNDS LIKE THE OUTLET PUMP / HOSE
Oct 21, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
129 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
