Question about ASUS X53E-XR1 15.6" Laptop with 2nd Gen Intel Core i3-2310M Processor
The sonic focus app will not switch on as normal and I am refered by the app to re-enable by refering to the windows advanced speaker tab, but I can not re-enable sonic focus.
My phone keeps on displaying this massege:- "unfortunately, the process com.google.process.gapps has stopped." how can I solve it
Hi the gapps in the error refers to Google apps ENABLE THE DOWNLOAD MANAGER..step 1 : tap on apps ..step 2: tap ,& drag the application screen towards the right to access settings ,& then tap on settings icon 3: tap on more 4: tap on application manager under more tab. 5: now tap & drag the application manager screen towards left and access DISABLED application ( note if disabled tab is not available.go TO ALL TAB,) 6,: tap on download manager with Android icon. 7: tap on enable now Download manager is enabled ( disabled should B on screen ) ...8 restart you're device ...good luck
Jun 19, 2016 | Tablets & eReaders
Metro mode windows 8
  1. On the Start screen, find the Desktop icon and tap it to switch.
  2. Once you are in the old desktop look Right-click the taskbar at the bottom (or tap and hold there for a second to bring up the menu)
  3. Click on Properties and go to Navigation.
  4. Under Start screen, check the "When I sign in or close all apps on a screen, go to the desktop instead of Start" option
  5. Click on OK and restart the system
For advance users and more information refer to article: http://knowledgepedia.net/index.php/knowledgebase/23-how-to-switch-between-desktop-and-metro-ui-mode-in-windows-8
For advance usr
Mar 25, 2014 | Computers & Internet
The colors on my laptop's screen are inverted, how can I fix this?
Both OS X and Windows have inversion options for their displays. Their meanings, on the other hand, differ with the operating system. An inverted display on Windows refers to the display actually being upside down, while an inverted display on the Mac refers to the colors being inverted. Either way, these options can hinder the use of your computer, for obvious reasons. Luckily, an inverted screen can be fixed quickly, on both Windows and OS X.
Right click on the Desktop and select "Properties." Click the "Settings" tab and then select "Advanced." Click the "Driver" tab and then "Graphics Properties." Press "Display Settings" and uncheck the "Enable rotation" option. Click "Apply" and then "OK." On Mac OS X Click the Apple logo in the upper left hand corner of the screen. Scroll down and select "System Preferences." Select "Universal Access" and click on the "Seeing" tab. Check the "Black on white" option and the display should return to normal. Close System Preferences to save the changes.
Feb 28, 2013 | Dell Latitude D820 Notebook
Enable WMM in DLink interface
You may be referring Virtual Servers under Advance. This will allow specific apps access via specific ports. There is also a similar application setting tab. Again in Advance.
Nov 07, 2012 | D-Link Computers & Internet
How to install a game on my samsung galaxy tab?
Well, there is a place called "Android Market" or similar.
If your desired game can be found there, simply download and install the game app and you can enjoy the fun.
If the game can't be found, or it requires a fee to play. You'll probably need to root the device. Here is a 1-click Android-Root solution for your reference.
Sep 07, 2011 | Samsung Galaxy Tab Tablet PC
Does all the features from soundcard work on windows 7 ?
im not sure what you are referring to
click start control panel hardware and sound manage audio devices playback you should see your speakers right click select enable or you might have to configure them this option will be at the bottom of the playback list also
right click on the speaker select properties you should see a few tabs general levels enhancement and advanced you might find you need to select a different option possibly stereo or dvd or studio quality
Aug 11, 2011 | Creative Labs Sound Blaster Live! 24-bit...
Sonic update manager
either uninstall sonic or
uncheck the sonic software in MSconfig
MSconfig
goto Start-Run-type msconfig
click on Startup tab
unclick any reference to sonic software
reboot
Oct 09, 2009 | Computers & Internet
When I turn lap top on Windows installer automatically atemps to execute a Sonic Upgarde Manager. uring the process there is reference to the Sonic installation package disk to locate UM.MS1. Upon...
to stop this
Go to Start >> Run >> type: msconfig (one dialog appears)
Select tab >> Start Up
UNCHECK the field where is located your "Sonic Upgrade Manager"
(Usually the path is like this:..(eg.) C:/Program files/.....your device.exe)
Hit >> Apply and then >> OK
This will be fixing your Pain.
Please don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
Oct 16, 2008 | Computers & Internet
ASUS X53E-XR1 15.6" Laptop with 2nd Gen Intel Core i3-2310M Processor Logo
254 people viewed this question
Top ASUS Audio Players & Recorders Experts
ALI DEHBAN
ALI DEHBAN
Level 1 Expert
David Payne
David Payne
 Grubhead
Grubhead
Are you an ASUS Audio Player and Recorder Expert? Answer questions, earn points and help others
