Unable to change settings on control panel for monitor
  • 112 Answers
You need to administrator power to change the control panel seeting.
Posted on Jan 21, 2009
When I leave my computer for more than 5 minutes, the monitor turns black and I am unable to access my data. I have to use the power button to shut down and start all over again.
Just change the power settings to never turn your monitor off or never put your pc to sleep when idle.
For Windows 7:
Click on Start.
Go to Control Panel.
Go to Power Options.
Click on Change Plan Settings.
Make sure both Turn off the display and Put the computer to sleep is set to never.
Click on Save Changes.
Restart your pc.
The steps should be similar for Windows Vista and Windows XP.
Jul 24, 2011 | Gateway DX482201 (PTGA002002) PC Desktop
Having changed the os from xp to xp pro i am unable to alter the screen resolution. Any help appreciated.
Go into control panel, click display, settings on the top right, set the color quality at max and the screen resolution also at max, click okay to save settings and monitor should adjust accordingly, if not set monitor to auto setup.
Mar 31, 2011 | Hanns.G Corporation HW191D 19" LCD Monitor
Display resolution very low and bit rate is 4bit, unable to adjust both levels. also where can i obtain latest system disc for foxconn intel type motherboard.
click start control panel administrive tools computer management device manager scoll to ports(com&lpt)right click to scan for hardware changes or scroll to monitors + to expand plug and play monitor right click where you have options to update driver,disable.uninstall,scan for hardware changes or select properties where in the general you have the option to troubleshoot also in the driver tab you have the same options as when you first right click on monitor
also
click start control panel,display,desktop you can select a different desktop from the drop down list also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps don
Mar 12, 2011 | Fujitsu Computers & Internet
I changed the screen resolution from 1024 768. while booting the monitor goes to power saver mode and displays "Out of Range 53.7KHZ to 60Hz. My OS is Win XP sp 3,
If the monitor is able to display the video after the computer boots, it may be something that you will have to live with.
But, you may be able to specify a different refresh rate based on the ability of your video card. Right click on the desktop, choose properties, then settings, and advanced button. On the new window, click on Adapter, then click on the Display All Modes button. The default for 1024x768 resolution is 60Hz, but your video card may offer another frequency which may be compatible with the monitor.
If you are unable to see anything after the computer boots, restart in safemode, then make the changes.
Is this an older monitor? 1024x768 is an industry default mode / setting. I am surprised that the monitor doesn't like it.
Jun 22, 2010 | LG Flatron L1515S 15" LCD Monitor
Mouse disappears behind settings
You need to use the monitor controls from the front panel, not the mouse.
May 10, 2010 | Westinghouse 25.5" Widescreen Flat Panel...
I own an FPD1730 17 in. Flat Panel Monitor. My screen is dim and I'm unable to manually change the tints back to the way it was. I have tried autoset on my monitor screen but it changes back to dim and...
this a micro-controller issue and a tech need to replace components that regulate the voltage to the florescent tube that excite the LCD to give a picture. they are sometimes call a LCD controller. This is a main board problem.
May 02, 2010 | Gateway FPD 1730 17" Flat Panel LCD...
I am trying to hook up my HP Laptop to my 47'' Insignia HDTV. When I plug in the display, my laptop displays only my desktop background and the tv says ''Mode Not Supported''. I am unable to even change...
try changing your resolution for your laptop before you plug in your TV, the screen refresh rate of your monitor,(click the following, control panel, personalization, display settings, advanced, monitor Tab). Also what make/model video adaptor are you using, try updating the drivers, if this helps, please give a fixya rating. Thanks
Jul 10, 2009 | Televison & Video
Unable to connect dell precision m50 to tv monitor
Go to Control Panel - Display - Settings - Advance - Monitor Tab change Monitor Type to Generic Television click Apply
Apr 10, 2009 | Dell Precision M50 Notebook
Driver for Polyview V17E 17" LCD Flat Pane
if you are using windows and it just won't let you go on the other resolutions try checking the monitor settings in your control panel
Nov 06, 2007 | Polyview V17E 17" LCD Flat Panel Monitor
Computers & Internet Logo
David Payne
David Payne
