Question about RCA TH102 (256MB) MP3 Player
Memory Lost.... When I first got this player it worked fine. Then when I attempted to delete mp3's and add a new playlist, all but 4mb was left as space on the memory. No matter what I do, I can't get music to load, annd the memory keeps getting smaller and smaller with no music on it at all. RCA is NO help. They don't have any trouble shooting like this on their site and after 2 motnhs of emails to tech support (there is no telephone number) I have heard nothing back. HELP!
5 Suggested Answers
SOURCE:
SOURCE: RCA S1010A Series, deleting music problems
You have to take the battery out first....then connect it to the USB port then it will find the music and then you can delte it.
Posted on Jun 06, 2008
  • 3 Answers
SOURCE: RCA Opal M4002A Won't let me access playlist without shutting down
You need to re-image your firmware--it sounds like something is corrupted there. I have seen this behavior on other mp3 devices in the past; sometimes it requires special techniques to reset the device. Let's hope this isn't the case with your Opal--RCA was rude enough not to provide a handy reset procedure.
If you are daring you can try to replace the firmware files directly on your Opal using your son's files. You need to enable viewing of hidden files to do this: Tools-->Folder Options...-->View-->Show Hidden Files and Folders. Also uncheck "Hide protected operating system files (Recommended)" and say "Yes" to the dialog that pops up. You can change these back later. For MacOS X, open Terminal, then type "defaults write com.apple.finder AppleShowAllFiles TRUE", push Enter, Option-click (and hold) the Finder icon, then choose Relaunch.
Now, simply copy your Opal's files over to a local directory on your hard drive (this is a backup so you can't make things worse), and then copy your son's Opal files onto your Opal. The files should be as follows:
autorun.inf
playqueue.dat
pmp_usb.ini
RAMLIST.DAT
SETSTOR.DAT
STDBDATA.DAT
STDBDATA.IDX
STDBSTR.DAT
STDBSTR.IDX
All of these files should be placed in the root of the drive--in the folder on the Opal that also shows folders like "Audible", "FMRecord", "Music", "Pictures", etc. After the transfer, stop and unplug your Opal. Try to turn it on and see what happens. If it looks OK, try to hook up to it with Windows Media Player. If you are still having trouble, use the firmware from the RCA website--even if it is the same version. Failing that, you may need to have the device serviced or replaced.
Good Luck!
Posted on Dec 04, 2008
SOURCE: profiling requires 4mb free space
Straiten the end of a paperclip and push it into the reset hole on the back. When you turn it on, it should operate as normal without any data loss.
Posted on Dec 16, 2008
Found a small pinhole on the back of the device. In small lettering it says reset. Carefully insert a pin and light push when you feel it's hit a dead end. It resets the issue and you can resume using your device. Leave it up to a girl to find that and figure it out. lol
Posted on Jan 19, 2009
I want to clear all my old play list and add a new one.
connect your mp3 player to your pc and delete your old playlist from your mp3 player and just create a new playlist folder like a computer.
Sep 23, 2009 | Apple iPod shuffle Second Gen. Silver (1...
I can't make my archos
be sure that you have already saved a list of song on your playlist. and for the pdf also make sure that there was a file that save on that location...
let me know
Aug 29, 2008 | Archos Audio Players & Recorders
I want to delete old playlist then add new
Open iTunes and plug in your iPod, select your iPod in the list to the side in iTunes. Now you'll see little tabs near the top of the iTunes window, click the one that says "Music." check the box that says "Sync selected playlists," now uncheck the playlist you are currently syncing your iPod with. Now, to create a new playlist look way down at the bottom left side of the iTunes window, you'll see a little button with a + sign, click it. Doing that will create a new playlist, now just drag and drop music into the playlist! Then go back to where you unchecked the playlist you were syncing your iPod with and select your new playlist.
hope this helps!
Aug 12, 2009 | Apple iPod classic MP3 Player
Deleting playlist
Nextar MA933A – Deleting Playlists
There are a couple of different ways to approach this problem.
You could 1. connect the Nextar to your computer
2. Double-click My Computer
3. Double-click the icon that corresponds to the Nextar – this is going to be different for every computer – some will have an actual Nextar icon, some will display it as USB Mass Storage Device, and others will list it as a Removable Drive – if it is listed as a Removable Drive, you can find the right one by double-clicking each removable drive until it gives you a new window with folders labeled Music, etc.
4. Enter the Music folder and Delete the folder that corresponds to the playlist that you want to delete
If that set of methods fails, or your mp3 player does not allow you to view the contents of the drive:
1. Go to the MSC menu
2. Press MENU button
3. When you see a song displayed in the LCD, press the Play key to pause the song
4. Once song is paused, press the MENU button
5. Select “Delete File,” and select the songs you want to delete
6. Use the Menu left/right keys to toggle between “Yes” delete and “No” don’t delete
-Tha Mp3 Doctor
Feb 05, 2009 | Nextar MA933A MP3 Player
How do I erase the playlists on my sansa fuse 2gb player?
connect your mp3 player to your pc... find those unnecessary playlists and just delete them... if it doesnt get deleted then try to format the player and make it fresh... add playlists that u wish later :)
Sep 26, 2008 | SanDisk Sansa e200 MP3 Player
Philips GoGear SA3245 - Playlists Not Showing Up on Player
·         Open up Windows Media Player(WMP) on your computer. To add a track to a playlist on your computer using WMP, click to highlight an item.
·         Right-click on the item that you want to add, then select Add to Playlist. A pop-up window will appear. Select an existing playlist or add a new one. Your selection is now added to your playlist.
·         Delete a track. When you do not want a track on your playlists anymore, you are able to delete it. To delete tracks and playlists, click to highlight an item. Right-click the item and select Delete from Library to delete it.
·         To Edit track information, click on a track. Right-click and select Edit. Click on the text boxes to edit relevant information.
·         Once all changes have been made, connect your GoGear to your computer with your USB cable and download the new playlists.
Sep 24, 2008 | Philips Audio Players & Recorders
Won't Process a Playlist
Had problem when on the expansion SD card not being able to add playlists, found out playlist are only saved in main memory, so I had to remove a song from main memory to add another playlist.
Aug 12, 2008 | Rio Cali Sport MP3 Player
YP-K3. Unable to transfer "playlist" into its own file
maybe your memory file is full already this the common causes,checked it out....
Jun 19, 2008 | Samsung YP-K3 MP3 Player
Will not hold the music I download
My problem was that I was deleting the existing library list in my computer when I attempted to add more songs to the MP3 player. I thought since I had already downloaded them to the MP3 player, that I could get rid of them from my PC's Media Player's library. The new songs I tried to add, would override the old songs stored in the MP3 player. Apparently you have to continue to store all the songs in your PC's library, and then when you add more songs you can transfer only the new ones to your MP3 player. A guy at my work told me this.
Apr 30, 2008 | Sony Walkman NWZ-S616F MP3 Player
How do you add a playlist to the player!!!
There is another way but that is called Favorites. First go to settings on the player and enable advance then go to one of your songs and press the select button then it will give you an option that says add to favorites? choose the check mark to add that songs to your playlist. Also there is a way to add playlist using windows media player. The steps given would be for windows media player 10. First click on the Library Tab thecn click on the arrow for the Now Playing List choose New List then Playlist, now add songs to your newly created playlist by dragging them to the drag items here window after you have choosen all the songs you like click on Now Playing List and choose Save Playlist As.. After saving the playlist change the settings of the player to Autodetect and connect the player to the computer. Now wait for it to be detected by the computer and click on SYNC tab on the windows media player software. There are two windows the left is where you will choose the playlist the right your mp3 player. Choose the playlist that you have created and click on START SYNC now it will be transferring the playlist to your mp3 player just go to Music then Playlist. Hope this helps :D
Jun 30, 2007 | SanDisk Sansa m230 MP3 Player
RCA TH102 (256MB) MP3 Player Logo
43 people viewed this question
Top RCA Audio Players & Recorders Experts
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
