Question about DeLonghi EO1238 Toaster Oven with Convection Cooking
Delonghi oven not hot
The over does turn on but not hot enough
Light stays on inside delonghi oven after it is turned off
most ovens have a seperate light switch on the control panel
Feb 25, 2015 | DeLonghi Toaster Ovens
Delonghi xr640 toasting-finished chime not working
follow this steps and fix it. God bless you
f the oven doesn't work at all, make sure the circuit breaker or fuse is on at the electrical service panel and test the electrical cord . If the oven doesn't work on its toaster and oven functions, test the main switch . As needed, check the fuse .
If the toaster function doesn't turn off unless the door is open, test the solenoid, the switch and if necessary, the thermostast.
Location of the typical toaster oven's thermal fuse.
If the toaster oven stays on when the door is opened, check the main switch . If the oven doesn't heat, test the heating elements.
Oct 27, 2013 | DeLonghi XR640 Retro 1500 Watts Toaster...
How do you set the delonghi convection toaster oven to cook chicken nuggetts?
Try this:
Thermostat knob - Toast/ broil
Time - 18 minutes
Wire Rack Position - Upper
Turn after 10 minutes.
For other recipe programs, you can download owner's manual at http://www.delonghiusa.com
Regards.
Jun 16, 2011 | DeLonghi EO1251 Toaster Oven with...
What does the asterik with the tear drop on the middle control mean on DeLonghi AR690 Retro Toaster Oven?
Here is contact info for DeLonghi if no one else can answer you.
EMAIL
Our consumer service representatives strive to respond to all e-mail inquiries within 24 hours of receipt. help@delonghi-csservice.com PHONE
To speak directly with a consumer service representative, please call 1-866-Latte- Best (1-866-528-8323). Representatives are available 8:30 am - 5:00 pm (EST) Monday through Friday.
<a href="http://www.toasterandconvectionovens.com">ToasterandConvectionOvens.com</a>
Feb 18, 2011 | DeLonghi AR690 Retro 1500 Watts Toaster...
How to clean the inside walls of a delonghi alfredo toaster oven?
pour water in the pan with little detergent for dish,and heat it on 30 deg Celsius for about 30-50 minute,and wipe the walls with cotton rag.
Jun 29, 2009 | DeLonghi XU620 Alfredo Ultima Bake 'N'...
My delonghi toaster oven knobs broke! as
Hi, you can purchase them on amazon. Here: Amazon com delonghi knobs. I think this was helpful, Have a nice day
Jun 12, 2009 | DeLonghi EO1260 1400 Watts Toaster Oven...
Dead Delonghi toaster oven
Your timer switch burned out. The timer is manual and will tick even unplugged. Delonghi switches are available at The Gourmet Depot website or search "small appliance parts" for other places that sell the switches.
Mar 23, 2009 | DeLonghi EO1258 - Stainless Steel Toaster...
Delonghi AS690 toaster oven lower element won't turn on.
Cactus Bob Is WRONG. I've had these replaced; and then, when it happened subsequently, bought the part and replaced it myself. You have to take the entire thing apart. but it can be done.
Mar 13, 2009 | DeLonghi AS690 Airstream Stainless Steel...
Toaster/oven
Could be the timer switch. They will suddenly stop working all at once or work intermittantly. Unless it's a Delonghi you may have a very hard time finding the part you need. If the switch is a DKJ/1-60 you will not find one but there is a Delonghi switch that you can use which you can find at www.thegourmetdepotco.com or www.applianceparts.com . The Delonghi part # is 5218104600 to replace a DKJ/1-60
Mar 05, 2008 | DeLonghi EO1258 - Stainless Steel Toaster...
DeLonghi EO1238 Toaster Oven with Convection Cooking Logo
27 people viewed this question
Top DeLonghi Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Steve
Craig Butler
Craig Butler
Are you a DeLonghi Toaster Oven Expert? Answer questions, earn points and help others
