Hoover commodore Washing Machine Overfilling
I have a Hoover commodore Washing Machine that overfills and floods the laundry. Adjusting the water level knob doesn't have any affect.
I imagine its a problem with the water level control knob or the water level switch. I have taken the machine a part to inspect the knob and the tube that leads down to the tub however I can't work out how to get to the switch on the side of tub and inspect / clean it out.
Thanks for reading, any help or suggestions will be appreciated!
Cheers,
p.
  • 15,935 Answers
This advice is for a washer that fills and will not shut off, resulting in an overflow. Or, water is leaking from the washer while filling. The symptoms can apply to either a TOP LOADER or FRONT LOADER washer. This may be able to save you from an expensive service call by making these simple visual checks.
Water Does Not Shut Off and Overflows: The water level in a washer is controlled by the Pressure Switch. The switch is usually cylindrical in shape and has an electrical connection and an air hose attached. In many cases, the small air hose comes loose from the Pressure Switch fitting and/or falls off. This air hose is required to detect the air pressure from the wash tub as tub fills. With no air pressure, the switch will not function and the result will be a wash tub that fills continuously to the point of overflowing. The same would be true, if the air hose has any cracks, splits or holes in it.
Water Leaking While Filling: The other end of this hose runs to the air dome fitting on the side of the wash tub. If the lower end of the hose comes off, the water will begin to spill onto the floor under the washer, but the tub will not fill.
What to Look For: Check for the obvious. Make sure the air hose is still attached to the pressure switch and air dome. Then, inspect the entire length of the hose, paying particular attention to areas where chaffing may occur and at the points where the hose connects to the pressure switch and air dome. Vibrations from the washer can cause some wear if the hose is rubbing against anything, and the ends of the hose can stretch over time and not seal properly.
On most top loaders the Pressure Switch is located inside the operator console behind the knob that controls the water level. This knob is commonly referred to as the “Load Level”, “Load Size” or “Water Level”. On front loader washers the pressure switch location is usually located in the back of the washer behind the wash tub, or along the interior cabinet wall adjacent to the wash tub.
How to Correct: If the hose has slipped off, cut about ½” off the end of the hose and reattach to the pressure switch and/or air dome fitting. Take a small zip tie and place it around the hose at the point where it connects to the fitting. DO NOT over tighten as this can damage the air hose fitting. Just make the zip tie snug enough to keep the air hose from sliding off. If the hose has any cracks or holes, you can attempt to seal them by using electrical tape. Replacement tubing can be purchased at any hardware store.
NOTE: This is not an all inclusive fix, as the Pressure Switch can fail in some cases and cause similar symptoms. This is merely a preliminary check for a common occurrence that I have discovered. It can give symptoms of a major problem, resulting in a call for a repairman, only to turn out to be a simple fix that any Do-It-Yourselfer should be able to check and correct themselves. I hope this information is found to be helpful and saves many of you a future service call.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
Smeg Dishwasher constantly filling and tripping anti flood sensor
Fill solenoid if water constantly filling when power switched off. Level sensor in sump if just overfilling but stops when power off
Jan 19, 2018 | Smeg Washing Machines
Hoover Interact 1600
This might sound silly, but try it. Run the washing machine through an entire cycle with nothing in it. Select the largest and longest cycle you can. Once this is done, is that error code still there? In some cases, this will clear it. This can be due to overfilling the soap and thereby triggering the sensors that are there to monitor pressure. Running it with no soap or clothes in it may clean this excess out of the machine. Another solution may be a faulty inlet valve allowing too much water into the tub to begin with...let me know what happens
Jul 01, 2012 | Hoover Washing Machines
What does E2 mean? Thanks
Hi, E2 means that anti flood device has been activated. The machine has overfilled.
Check in the base (under the bit you put the dishes in) to see if it's flooded. The causes for overfilling are blockages in the metering tank, blockages in the system hoses.
Drain the water out of the base and try the machine again. If it overfills you'll need to take the machine out, do a fair bit of dismantling to get at the hoses etc. to clear the blockages.
Jun 21, 2011 | Belling 24 in. IDW602 Built-in Dishwasher
Whirlpool cabrio washing machine
FL error code generally means 'flood condition' which is telling you the machine is overfilling with water with water.
Try pressing STOP/CANCEL to clear the display.
If the condition persists the water fill valve or sensor may be faulty and may need replacement.
May 17, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
The washing machine will overflow, flooding water onto the floor. Flooding has happened 8 times, and it attempted to do it about another 5 times (I stand there and watch it and turn off the water supplies...
ive included a solution to a similar problem that i solved earlier this week, i hope you find this helpfull...
I am assuming this is a top load washing machine.... the load size selector button has a hose attached to the back of it. This hose goes down to an overflow box mounted to the side of the tub. This tube often gets clogged and the machine cannot tell where the water level is. 1) dissconnect the tube from the level selector switch and ( w/it unplugged ) attach another tube to it and blow into it. you should hear a clicking sound. this means your level selector switch is functioning properly. if it does not click then it needs to be replaced. 2) dissconnect the tube from the level selector switch and ( w/it unplugged ) blow into the tube and you should hear air going into the tub, ( this is best performed with water in the tub ( bubbles ) )....hope this helps
Asker's Testimonial " Thanks rdrsp. When I took the control panel off, I found that the tube had fallen off the control valve. I put it back on with a band clamp. " - bill_marv460 "
Oct 22, 2009 | GE WVSR1060A Top Load Washer
Machine overfilling
You need to check the pressure switch and tube wich you can access from the top of the machine with the top removed. the tube is a rubber pipe which may have fallen of the switch or pressure chamber connection. cheers
Mar 25, 2009 | LG WM1812C Front Load Washer
Washing machine overfilling
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, your washing machine overfilling.
please give us more information .
What is the manufacturer and model number of your problem washer?
Thank you
Sep 29, 2008 | Washing Machines
Hoover Premier 710 - always fills to capacity (can't adjust water level).
my one the same, I just adjust the water level switch to 60% then it work on full level, but no flood,I hope this help :)
Apr 30, 2008 | Hoover HTC243 Top Load Washer
Hoover washing machine (commodore 5.0 kg)
this is either a belt slip or a squeeling bearing ater seal, if it is not the belt then try doing a boil wash, this often resolves the problem. Regards Advisor
Jan 30, 2007 | Hoover Nextra HNT 2135 Top Load Washer
Washing Machines Logo
346 people viewed this question
Top Washing Machines Experts
