Question about Vermeer Bc1000 Chipper Operators Manuel
BL1000 shuts down
After start machine shuts down slowly as you start to chip
My front loading washer starts to fill very slowly with water after the machine is shut down after a wash. wh
I would suspect that the water inlet valve has failed. could be some dirt got stuck in it .
Aug 02, 2015 | Washing Machines
Tip
HOW TO FIX YOUR DV6000/DV9000/DV2000 All the Problems described are Graphics...
All the Problems described are Graphics Related..
Faulty Nvidia Chip..Both Intel And AMD Based Motherboards..Though More Common on the AMD..
The symptoms of the Laptop Powering on and Shutting Off Repeatedly..Or.. Powering On and Having No Video...Or... Power Strip Lights Up, Beeps,Shuts Down...Or..No Power At All...Or.. Intermittant Loss Of Wireless/Video Goes In And Out/Touchpad Slows and Freezes..
To Fix this issue, You will need to Reflow The Graphics Chip.
I will Explain In Full Detail As To The Correct Method Below....
HP DV6000/DV2000/DV9000 Compaq v2000 Video Chip Reflow Instructions
First Step Is Complete Disassembly Of All Parts And Components..
Remove RAM, Remove CPU, Of Course Remove Heatsink and Fan assembly.
Next Step is Insulating the Motherboard... You need to Protect The CPU area, The RAM area, Cover any plastic Plug ports.
Try to leave 1/4 inch area around the edge of the chip free of insulation.
To Insulate the Board.. I use thick pieces of Tin/Aluminum, you can fold up some aluminum foil (tin foil) About 4 folds thickness....
Now that you have your Motherboard Insulated... Make Sure There's Nothing Flamable Or Burnable Below the Motherboard... it will get quite hot underneath.
You will need a Heat Gun.. You can get one of these at your Local Home Improvement Store, they cost about $15 - $30.. You Will Use ONLY the LOW Heat Setting... I REPEAT..... USE ONLY THE LOW HEAT SETTING ....
Next You Will Need Some Coins.. Yes Coins..
8 Quarters and 2 Nickels... Put the 2 Nickels On the Bottom and Stack Quarters On Top...
Place The Stack Of 2 Nickels And 8 Quarters On Top Of The Graphics Chip...
The Reason for using the Coins: Using the coins serves a few purposes...
1) It Helps Transfers the heat Into The Chip More Evenly/Slowly
2) It Helps Hold The Heat Longer/Then Helps To Cool Slower
3) It Gives The Correct Amount Of Weight That Is Needed To Press The Chip
A Thing To Look Out For...
Hewlett Packard is nutorious for using the RED epoxy around the edge of the Graphics chip.. this epoxy is used to help secure the chip to the motherboard...
This is a process that is Hand Done at the Factory.. And Some Boards Will Have Only A Little Amount of this, Some Will Have Alot of it...And Some are Only Done On The Corner Edges....
If There Is Alot of This On Your Chip, You Might End Up Needing To Carefully (REAL CAREFULLY) Remove as much of this epoxy as able to....You can use a Razor Blade To Lightly Scrape This Off... DO NOT MISS AND SCRATCH THE MOTHERBOARD!!! Go SLOW...
Now Comes The Heating Of The Chip...
Start With The Heat Gun About 6 Inches Away From The Top Of The Quarter Stack..You want to be holding the gun at a 45% angle.. Aim the heat at the Edge of the chip, You Will Start Rotating Around the Chip- around the outer edge of the chip...then use tighter circles concentrating on the quarter stack, then after about 30-40 seconds, slowly move closer to the chip...
Never Move the Heat Gun Closer than the Top Of Your Coin Stack...Then Pull It Back And Slowly Repeat.. The Chip Needs To Get Hot Enough To Re-Melt The Solder Balls On The Underside Of The Graphics Chip Back Down To The Contact Pads On the Motherboard.. and this takes Quite Alot of heating to Do.... You Must Not OVERHEAT the CHip... It Is Best To Underheat it and have to Redo.. than to overheat.. It will cause the solder to break down and even crack/split.. causing failure forever...
This process will take about 3 minutes total.. Once you shut off the Heat Gun.. Leave The Stack of Coins On The Chip And Let Sit For Another 5 minutes..
Now Remove The Coins(carefull they might still be hot)
Remove All Insulation.. Reinstall RAM, CPU, Heatsink and FAN Assembly (and Of Course Thermal Pads or Paste.. Note:. If Paste Is Used.. It Must Be Silver Paste...
Now You Can Connect The Power Button Strip/ Video Cable And The DC Jack Cable.... And Plug In AC adapter .. You're Now Ready To Test For Solid Power and Video....
Upon Sucessful Chip Reflow/Rebake.... You Need To Go To The HP Website..( www.hp.com )..Click on SUPPORT AND DRIVERS, then select...DOWNLOAD DRIVERS AND SOFTWARE....Then either click the box to Auto-Detect System, Or Enter Your Make/Model Info, Once At The Page With All Of Your Drivers.... Choose The BIOS UPDATE Driver..
Choose The Newest Driver And Download/Install It... It Will Reboot The Laptop And Upon Rebooting, Your Fan Will Spin Faster And More Often Due To A Thermal Controller Update In The BIOS Update...
on Dec 01, 2009 | Computers & Internet
2004 mxz 600 ho with 4500 mi. Pre condition of machine - kill switch rarely works so pull the key fob/chip to shut it off. it started last weekend with the electric start being intermittent but would pull...
Electrical doesn't affect the engine mechanically. Besides making it run rough or shutting it down. Engine mechanical does affect the electronics though. Sounds like you have an electrical problem that needs attention. Also sounds like you have an engine that just threw rod/main bearings. At 4500 miles, I hope you have a warranty on this engine.
Feb 22, 2015 | Cars & Trucks
Cant get machine to embroider
there are three positions the presser foot can sit in. Up and down are the same on any machine. The 7570 has an in-between position for embroidery. Lift the presser foot and the lower it slowly while pushing gently. It should stop about half way down. The embroidery foot pushes the foot into the down position with each stitch allowing the fabric to move easily to the next stitch.
Jan 29, 2013 | PfaFF Creative 7570
Hi, I have a pavilion dv9743cl. all of a sudden it will not turn on at all. No lights at all. the only light is at the power cable, just lights up blue. I've tried a new battery, and power cord, and still...
I love this machines. I have the DV9933cl the following it will be a lenghty process but if successful on following instructions you will be happy with the results and a little more computer sabby.
HP /DV9000 Video Chip Reflow Instructions
this is the same issue that the Xbox 360 has with the power rings over heating. also to maintain your computer at a lower temperature never leave your computer on your bed. All the vents are cover so no air goes in and this happens it over heats
Jun 13, 2010 | HP Computers & Internet
My HP Pavilion dv6500 is running but lcd screen stay black only power light is on I press any bottton but nothing happen,power off then on,stay same... Thanks Milan Detroit
All the Problems described in the previous posts are Graphics Related..
Nov 22, 2009 | Toshiba Satellite P105-S9722 Notebook
When I start the laptop the light comes on but the screen stays blank.
Nov 16, 2009 | HP Pavilion dv9000z Notebook
Slowly boot
Try running disc clean up and then defragmenting the drive.
Click start,all programs,accessories,disc clean up.
Select drive "c" and run the cleaner, may take a while, and try not to delete compress old files.
Then when that is done , start,all programs,accessories,disc defragmentor. Defragment drive "c". shut down and reboot you should see some improvement, depending on start up programs etc.
May 05, 2009 | Sony VAIO VGN-SZ220/B Notebook
Resetting lbp fuser
you need to do a lbp fuser reset and lbp error log clear
fuser reset
function- 7- monitor button 4 times slowly- then press * "start" button, should say service mode, then press 7- start- down arrow - start- then yes
log clear
function- 7- monitor button 4 times slowly- then press * "start" button, should say service mode, the press 6 - use the down arrow to get to lbp log clear.
if this does no work you need the fuser replaced
good luck
Oct 12, 2008 | Panasonic PanaFax UF-490 All-In-One Laser...
Toshiba Satellite M55-S135
for all problems like this start by simplifying - pull both ram chips out and try each one individually. Remove any accessories like the CD drive and hard drive and see if the machine does anything different.
If these basic steps dont help its probably an internal problem with the laptop and you would have to take it somewhere to disassembly and diagnose.
Jan 14, 2008 | Toshiba Satellite M55-S135 Notebook
Vermeer Bc1000 Chipper Operators Manuel Logo
47 people viewed this question
Top Vermeer Heavy Machinery Experts
Jerry Kramer
Jerry Kramer
Tony Crow
john h
Are you a Vermeer Heavy Machinery Expert? Answer questions, earn points and help others
