Question about Toshiba Lands Phones
How do i get the pages to come through the phone
How to program the page button
Can you please be a little more specific? Are you referring to assigning the paging feature to a button on the phone or programming the actions the system performs when you press the existing paging button on the phone? Normally, when you press the predefined paging button on this phone the system prompts you to select where your paging output goes. Depending on how your system was set up it may ask you to select "set", meaning when you select this soft-key the system will sound a short alert tone through all of the speakers in all of the phones connected to the system then allow you to talk through all of the phone set speakers. The other option is to select a soft-key that directs the output of the paging to an external PA system that is connected to the NAM through a punchblock connection. You can usually also select "both" which directs the output through the phone sets and the PA system. I am not certain what, if any system programming might be involved - I am fairly certain that if your system has not been connected to a PA system the paging function is just available to output through the phone set speakers. If your phones have no buttons assigned to the page feature then you'll need to refer to the system programming procedures to find out which feature code is assigned to paging and then access it by pressing FEATURE + the paging code or assigning the paging feature code to an unused button.
Oct 16, 2013 | NorStar Meridian M7310 Phone
How can I program Norstar M7310 to announce pages
To page - F60
To receive a page make sure the phone is in the correct page zone under Set Capabilities in system programming.
Aug 09, 2012 | NorStar Meridian M7310 Phone
How to page
You will need the page codes if you use the feature to page select groups. One softkey will have PGE written above it when the phone is in a mode that can page. This is the Page key (the second softkey on most of the phones in the group).
To make a page announcement to phones or external speakers: Lift the handset, press the extension and then enter a paging access code.
To make a group page, Press Group Page and then the group code or press extension + #31 and the zone number .
To make an All Call Page
1. With the handset off-hook, press All Call Page
...or dial #30. This pages all telephones in the All Call Page Group but, depending
on system programming, you may or may not page external speakers.
2. Make your announcement then hang up.
To make an Emergency Page
1. To make an Emergency Page, lift the handset off-hook, dial #37.
2. To make an Emergency Page to a group, lift the handset off-hook, dial #38 and
enter the Group number.
The manuals for all Toshiba phones
are here: http://www.telecom.toshiba.com/Telephone_Systems_Resources/User_Guides/ . The DKT3010SD is part of the IPT2000/3000 series phones; the direct URL for the manual is http://www.telecom.toshiba.com/Telephone_Systems_Resources/User_Guides/pdf/_new/Strata_CIX_Strata_CTX_User_Guide_IPT2000_and_IPT3000_Series_Telephones.pdf .
I hope this helps.
Jan 31, 2011 | Toshiba DKT3010SD Corded Phone
Can't page to central speaker system. gives a busy signal.Merlin Plus system with Page Pac 20 paging system. All other features work. I think it is the Page Pac but don't know how to troubleshoot.
If you are getting busy signal, something is shorted out.
Disconnect the wiring from the phone systems page port, and try to page. did the busy go away?
if not the port is bad in the phone system. If it did, the page pac is bad...
Apr 30, 2010 | AT&T Merlin BIS 10 Phone
M7310 doesnt page when i press page button
So pick up the handset and press FEATURE 63. Does that work?
If it does, press Feature *0 and the button labeled PAGE. What does it say? If it doesn't say PAGE, dial FEATURE *3 the PAGE button and dial FEATURE 63.
Of course, it's possible that your whole phone system lost the programming. And, it's also possible that the all page code is 60x instead of 63. FEATURE 6 starts external paging though.
Carl
FEATURE 60 Page-General
FEATURE 61 Page-Sets
FEATURE 62 Page-External Speakers
FEATURE 63 Page-All
Dec 09, 2009 | NorStar M7310 Phone
Overhead paging
How do you dial paging? Pressing a button or dialing a code?
THat phone can be on a few different systems, do you know what you have for a phone system?
May 28, 2009 | Lucent PARTNER18 Corded Phone
Small office system - when paging another person,
AFAIK, there is no way to turn of the ringer for only paging.
Feb 18, 2009 | Uniden 5.8GHz Dual Cordless Phone
Intercom paging not working on avaya partner phone
Are you paging the overhead speakers, or paging the speakers on the phones?
Jan 27, 2009 | Avaya 700340193 Corded Phone
Page causes phone to ring rather than come through the speaker
What "page" are you using?
If it is a button on another phone that "pages" just your phone. The button is programmed incorrectly on that other phone. If it is the "page" button that pages all phones, do all the phones just ring?
May 02, 2008 | Avaya Lands Phones
Lands Phones Logo
22 people viewed this question
Top Toshiba Lands Phones Experts
george  peters
george peters
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
