Question about Sony KDE-37XS955 37 in. Plasma HDTV
Service menu code toshiba regza C/X3030D series
Code for Toshiba Regza 32XV555D handset please
PDF]BT Vision remote control TV code list A - BT.com
www.bt.com/help/codes
BT GroupBT Vision remote control TV code list ... If your make of TV isn't in the list, pleaselook for the code you need in the installation manual of your TV. 888 ...... Toshiba. 0011 0688 0002 0009 0005 0000 0049 0642 0646 0190 0727 0748 0006 0018 ...
Remote control code for Toshiba Regza 42rv530u - Verizon Forums
https://forums.verizon.com/...Programming/Remote-control-code-for-To...
Apr 12, 2010 - Remote control code for Toshiba Regza 42rv530u. Options. Mark as New ... to find a working code. Please write back if I can assist you further.
I need help finding remote control program codes for Toshiba Reg
Dec 14, 2015 | Toshiba Televison & Video
I have sound but no picture the menu still displays just nothing from any video inputs its a toshiba 47hl167
I am assuming you have already tried leaving it unplugged for 15 minutes and then trying to restart it. Does it work in the TV mode? I.m not sure if there is a rest button on that model. If you go to Toshiba Support there might be more info.
Apr 12, 2015 | Toshiba REGZA 47HL167 TV
How do you change the time zone on 2007 Toshiba Regza 42HL67?
the manual doesn't mention anything about setting the time, so I am wondering if it comes from the cable or satellite box connected to it.
this is how it is done on another Regza model
Setting the time zone
The Time Zone setup will allow you to specify the
correct time zone for your region. This feature will
allow the TV status information to show the correct
time zone information for your viewing area.
From the SETUP menu, highlight TV Settings and
press T.
Press B or b to select Local Time Setting and press
T.
Highlight Time Zone and press C or c to set your
desired time zone.
If you want to activate the daylight saving time,
highlight Daylight Saving Time.
5
Press C or c to select On and press O.
Toshiba REGZA 46SV670U Owner Manual Setting The Auto Input Feature Setting...
your model manual
Toshiba 42HL67 42 LCD TV Service Manual
Jul 24, 2017 | Toshiba REGZA Televison & Video
Ive lost my manual for my toshiba 37rv753b,and when i go into my menu its all in some eastern european language,and can not reset it to english,can you help?
Here is the link for the manual for the TV you specified. The link to the PDF is towards the bottom of the page. Hope this helps ;)
http://www.home-entertainment.toshiba.co.uk/Regza-LCD-TV/30-39-LCD-TV-screen-size/37-Regza-LCD-TV-RV753-Series/
Jul 13, 2011 | Televison & Video
I have a Regza X3030D. When I turned it on this evening I have no picture or sound. Nothing strange happened when it was turned off last night and I don't leave it on stand-by. The set is a four years...
It is fixable, I would inspect the power supply module for bad caps with domed tops first since it is four years old. Outlet is good for sure?
Please read my guide first:
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jun 14, 2011 | Toshiba REGZA 47HL167 TV
Toshiba regza 37" reset defaults
Unplug the TV for some time (usually 1hr is plenty) and it should reset to factory settings.
Mar 14, 2011 | Toshiba Regza 37HL17 37 in. LCD TV
Toshiba Regza with red LED blinking
hello the red blinking lights is a service code when this happens it means theres a power problem or a fualty circut. it happens alot with these new plasma and lcd tv's its very common since these units have built in protection and power loss a fualt or short will cuase this.
the tv needs service the tech will know what to look for according to the number of blinks.
hope this helps.
Dec 18, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
I have a Toshiba C/X3030D television was working fine yesterday when turned off. Turned on today and digital channels will not work. Analogue is fine,Digital menue is just flashing up and will not stay...
I have a Toshiba C/X3030D television was working fine yesterday when turned off. Turned on today and digital channels will not work. Analogue is fine,Digital menue is just flashing up and will not stay open so can not reset television. Any one with ideas as to what has gone wrong?
Thanks
Jul 11, 2008 | Televison & Video
Open Questions:
Sony KDE-37XS955 37 in. Plasma HDTV Logo
78 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
