Question about One Touch Jitterbug One-Touch Cellular Phone
Alphabetize names on 733 jitterbug phone
How do you move virbrate mode on jitterbug phone back to ring mode
To adjust the volume of the ringer follow these steps:
First, make sure your Jitterbug phone is turned on and open. While looking at the inside screen, adjust the volume by using the rubber volume button, which can be found on the outside of the phone. Press the top of the button to increase the volume and the bottom of the buttonn to decrease the volume. The inside screen will display the ringer volume level, which ranges from Vibrate to Max.
If you need additional help, you can call our Customer Service department at (800) 733-6632. We are available 24/7.
Jun 21, 2011 | One Touch Jitterbug One-Touch Cellular...
I would like to get a Manual for our Jitterbug phone. How can I get one??
We have several different model phones, so the User Guide will vary. If you have our most recent model phone, the Jitterbug J, the User Guide is available at greatcall.com for you to download. Or you can click here to access it directly.
If you have a different model phone, you will need to call in to our Customer Service department at (800) 733-6632 and we will be able to mail you the version you need. You can call in any time as we are available 24/7.
Jun 04, 2011 | One Touch Jitterbug One-Touch Cellular...
My jitterbug phone is on vibrate how do i get my volume back
First, make sure your Jitterbug phone is on and open. While looking at the inside screen, adjust the volume by using the rubber volume button, which can be found on the outside of the phone. Press the top of the button to increase the volume and the bottom of the button to decrease the volume. The inside screen will display the ringer volume level. The ringer volume ranges from Vibrate to Max.
If you need additional help, you can call a customer service expert available 24 hours a day 7 days a week at 1-800-733-6632 who will walk you step-by-step through the process.
Jan 22, 2011 | One Touch Jitterbug One-Touch Cellular...
Can I put all my contacts on speed dial?
NO, IT IS NOT POSSIBLE. THE MAKER OF YOUR PHONE WOULD HAVE GIVEN YOU PROVISIONS FOR ONLY NINE CONTACTS.
Jan 10, 2011 | One Touch Jitterbug One-Touch Cellular...
How do you get the jitterbug phone off vibrate and to ring?
First, make sure your Jitterbug phone is turned on and open. While looking at the inside screen, adjust the volume by using the rubber volume button, which can be found on the outside of the phone. Press the top of the button to increase the volume and the bottom of the button to decrease the volume. The inside screen will display the ringer volume level. The ringer volume ranges from Vibrate to Max.
If you need additional help, you can call a customer service expert availalbe 24 hours a day, 7 days a week at 1-800-733-6632 who will walk you step-by-step through the process.
Dec 25, 2010 | One Touch Jitterbug One-Touch Cellular...
I NEED TO DOWNLOAD A MANUAL FOR A JITTERBUG PHONE SPH-A310ZRADYN THEY SENT THE WRONG MANUAL WITH MY PHONE
You can find our User Guide online by visiting GreatCall.com or simply click here to access the PDF version directly.
If you would like us to mail you a copy, you can also call our Customer Service department at (800) 733-6632. We are available 24/7.
Dec 24, 2010 | One Touch Jitterbug One-Touch Cellular...
How do I use the calendar on my jitterbug J. There are no instructions in the manual.
To add an event to your Calendar, either create an account and login to MyGreatCall.com or call our Operator Services by dialing "0" and then Yes on your Jitterbug phone. There are no monetary charges for calling the operator, but it will use your standard minutes as with any other call and there is an additional 5 minute charge when connecting with the operator.
If you would like step-by-step assistance with adding an event online, please call our Customer Service department at (800) 733-6632. We are available 24/7.
Nov 03, 2010 | One Touch Jitterbug One-Touch Cellular...
How do i add phone numbers
There are several ways to enter a number into your Phone Book:
1. Call GreatCall Customer Service for assistance 24 hours a day, 7 days a week at 1-800-733-6632.
2. Create an account at mygreatcall.com and modify your Phone Book online.
3. Manually enter a number into your phone.
To manually enter a number, it depends somewhat on what model phone you have - either the Jitterbug Original/One Touch or the Jitterbug J. In all cases, you will need to open the phone and access the Phone Book menu option. With an Original or One Touch, this can be done by pressing NO until you see PHONE BOOK listed at the top of the screen. With a J, you will press YES once the option for PHONE BOOK is highlighted in the center of the screen.
Press the up arrow and you will see the option EDIT PHONE BOOK. Press YES to select. Press YES again to select Add. Now you will be prompted to type in the name of the contact using the Triple-Tap method. Each number corresponds to 3 letters. Tap the appropriate number in quick succession until you see the letter you want to enter. Use the "#" to enter a space.
Example: To enter the name "John," you would press 5-666-44-66.
Once you are satisfied with the name, press YES to select DONE. You will then be prompted to enter the number. It is recommended that you include 1, the area code, and then the 7-digit number even if it is a local number.
Example: 1-760-555-4321
Once done, press YES again. You will see the message Successfully Added and you are done!
Oct 21, 2010 | One Touch Jitterbug One-Touch Cellular...
I need a Jitterbug cell phone manual. Can I download it?
My name is Stephenie Lavallee and I am a customer service representative of Jitterbug by GreatCall. I would be more than happy to provide you a PDF version of the Jitterbug One Touch phone user manual. All I would need is your email address. Another option is to contact our customer service 24 hours a day at 1-800-733-6632 for a user manual to be mailed to you.
Thank you and have a great day!
Stephenie Lavallee
Oct 17, 2010 | One Touch Jitterbug One-Touch Cellular...
One Touch Jitterbug One-Touch Cellular Phone Logo
Top One Touch Cell Phones Experts
john smith
Lawrence Oravetz
Are you an One Touch Cell Phone Expert? Answer questions, earn points and help others
