Question about Stoves Ovens
Kenmore model 79046999101 manuel
Front glass replace
I have an Kenmore stove oven. It is a glass top stove that I bought in 2002. The front right element won't shut off.
This is usually the infinite switch has failed. They are easy to check and inexpensive. Here is a video that will walk you thru testing an infinite switch. It may be a different model but the testing will be the same. You can also enter your model # for diagrams and illustrations for your specific model. Not all models are available. All parts come with installation instructions.
Feb 05, 2011 | Kenmore Ovens
How do I change the lightbulbs in the oven
Make sure the oven is off and cool (turn off the circuit breaker). Wear a leather glove to protect your hand. Depending on your model, there may be a glass shield held by a metal holder over the lamp. In the case of a unit with this holder, press on one side to release the shield and remove it. Remove the bulb by turning it counter-clockwise. Replace with a 40 W appliance bulb (turn clockwise). Replace the glass shield and the holder. (On some oven models, the shield will twist on and off like a bulb.)
There are several models of Kenmore 47783 Ovens; manuals are available here: http://www.managemylife.com/mmh/owner_manuals/search?query=Kenmore+47783 .
I hope this helps.
(please note: never operate the oven without the shield in place if your oven has one.)
Dec 12, 2010 | Kenmore 47783 Electric Single Oven
I JUST BOUGHT A FLOOR KENMORE GAS RANGE THAT WAS A FLOOR MODEL AND THEY SAID THEY DO NOT GIVE THE MANUEL WITH IT. WHERE CAN I GET A MANUEL. IT IS A MODEL 70402 ITEM #0220402000. i BOUGHT IT AT THE SEARS IN...
You can order the paper manual from Sears by calling 1-800-252-1698. They will need the entire model number though. Here is info on where to find the model number:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=70402&pathTaken=partSearch
You can download the manual here:
http://www.kenmore.com:80/shc/s/nb_10154_12604_NB_CCownersmanuals?adCell=WF
Again, you will need the entire model number. It should be located under the lid or on the back of the unit. It will start with three numbers followed by a dot, then many more numbers, such as:
102.24300
If you have any further questions or problem locating model number, let me know and I can help further.
Aug 02, 2010 | Ovens
My oven inside glass door exploded tonight while
Very rare, in 35 years I replace maybe 2 to 5 a year out of 1500 to 2000 repairs a year on all major appliances. Make sure you replace it with the exact glass from the manufacturer, usuing your model number. Do not replace with glass from a glass shop.
Jan 29, 2010 | Ovens
I own a Kenmore stove model #639539J2. The glass
yes. open the oven door to the first "click". it kind of stops about a quarter of the way open. most ovens you grab both sides of the oven door and pull up. some models have a couple of screws you have to take out before you can remove the oven door. then lay it down with the insie of the door facing up and take out all the screws holding the oven door together. some may be on the sides or the top and bottom of the door. when apart, clean first with easy off, then clean several times with windex till streaks are gone. assemble door in reverse and put back on stove.
Oct 10, 2009 | Kenmore Ovens
Displays an F5 fault code on kenmore wall oven model 911-47469
HI. This is a touch pad issue. You will need to inspect for binding of the push-buttons and control panel glass. If OK, replace the touch panel board.
Oct 06, 2009 | Kenmore Ovens
GE Gas Built-in Oven model JGRP17B Door Replacement
pull out the bottom drawer you will find a plate on the left side pillar of the drawer opening the model # and, serial # is there this is all that is needed to order a new door glass
Apr 21, 2009 | Ovens
Kenmore smoothtop model 911.9554590 duel size burners
the inner burner is broken so the whole thing needs to be replaced. check your owners manuel for warrenty times on the burner. otherwise just replace the burner and that will solve your problem..
Mar 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Melted tin foil on oven bottom
in your owners manuel is stated to not put tin foil on the bottom of the oven.. depending on your model you may be able to replace the bottom panel.. however you can still use the oven without any problems.
Jan 20, 2009 | Kenmore 30169 Electric Single Oven
Oven door outer glass shattered
will need a model number to tell you the correct price ... most will have to replace the door... you can also give sears a call .. if you gripe loud ... they may replace it for you...
Sep 28, 2008 | Ovens
Ovens Logo
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
