Question about Car Audio & Video
How do i set the clock on a crc 2050a car radio
3 Suggested Answers
oldnovii
  • 667 Answers
SOURCE: clock on car radio
Hi blackie - I could tell you how to do it but I believe it is easier if you look at the manual with the pictures. Below you'll find a link for your manual. After clicking on the link just click on manual for MP5610 next to the red dot. It's in English and Spanish but it's ok to read it. I believe you want pages 9 and 10 for the menu and the clock. If this solves your problem PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks.
http://mobile.jensen.com/jensen/JensenInfo.do?findManual=MP5610&x=4&y=7
Jeff
Posted on May 15, 2008
pumpkinman
  • 1144 Answers
SOURCE: how to set clock on Akai ARC-18MPH car radio
Akai Customer Support: (800) 726-4405
Posted on Sep 22, 2009
Crc 5310 schoolbus stereo radio
How do I remove a crc-5310 bus radio from the dash..If I need a key where do I find one
Jan 06, 2014 | Radio Communications
KD-R805 does not store clock settings
first of all you must be able to check out a few things like do you know how to set your clock for the kd-r805. if you can check to see if you set your clock and set your presets for radio station to be saved. set your clock and set all your station presets once done. Once you have done that turn off the car wait about 60 seconds then turn your car back on to power up the radio and see what happens to your clock and presets . if your clock and presets are not still saved this means that who ever did the radio install has the yellow memory wire connected to switch ignition and not constant battery wire from the factory harness. have someone fix it. If the clock and station presets are still save then it was that you don't know how to program the clock.. how to program your model radios clock .......
STEP 1 : TURN ON POWER TO RADIO
STEP 2 : PRESS AND HOLD MENU UNTIL THE MAIN MENU IS SHOW ON RADIO SCREEN PRESS AND TURN THE VOLUME KNOB TO MOVE THROUGH THE MENU ( YOU MUST CANCEL THE DEMO FIRST TO BE ABLE TO PROGRAM THE CLOCK).
STEP 3: TO SET THE CLOCK SELECT THE CLOCK IN THE MAIN MENU SETTING ROTATE THE VOLUME KNOB AND PRESS IT ONCE TO SELECT THE CLOCK SETTING.
STEP 4: ADJUST THE HOURS AND THEN PRESS THE VOLUME KNOB TO MOVE ON TO THE SECONDS .
STEP 5 : THEN SELECT 12HR OR 24HR TO BE DISPLAYED
STEP 6 : RETURN TO THE PREVIOUS MENU BY HITTING (BACK BUTTON)
STEP :7 TO EXIT SETUP OR MENU HIT THE (MENU BUTTON)
radiorepair@www.windowtintingin239.com
Oct 26, 2013 | Car Audio & Video
I cannot set my clock because the preset buttons 5 and 6 wont work
SHOOT SOME CRC ELECTRONICS CLEANER IN BUTTONS TO TRY TO CLEAN...IF NOT= RADIO SERVICE
Mar 07, 2013 | 2005 Saturn ION
Resetting clock on truck stereo
The Kenwood KDC-MP335 is an aftermarket car radio that's available for many cars and trucks. The radio unit comes with a built-in digital clock. If your clock is showing the wrong time, all you need to do is enter the radio's clock-setting mode to correct the time and set the clock.------------------------------------------------------------------------
vas 5054a v19
Nov 28, 2012 | Cars & Trucks
How to set clock radio crc 5340a without a manual
Hold the T/F button down until it flashes on clock. Radio must be off. The hour will flash. Move volume know to adjust. Then hit T/F button again to switch to minutes and move volume button again to adjust. Then hit power button to set.
Nov 02, 2012 | Car Audio & Video
Panasonic clock radio RC7469. Electric motor that actuates flip panels (hours, & Minutes) operates but the primary gear extending from the motor itself does not rotate. The motor unit is sealed.
If you have situation like this just open clock, remove clock assembly from base. Use LUB OIL 88/200 by CRC Industries, two point where you should apply oil: drive shaft and gear box (two point of lubrication - power wire enter point in to clock and point where wire go to motor). Lubricate it well and let clock run for 48 hours add additional oil if needed.
Jul 29, 2011 | Audio Players & Recorders
HOW DO I CHANGE THE TIME
    • 1
      Refer to the section of your owner's manual that addresses the car radio. Each car radio is different in the way you set the clock. If you've installed a car radio other than the one that was manufactured with the car, consult the manual for that radio.
    • 2
      Know that if this is the first time you're setting the clock or are setting the clock after installing a new battery in your car, you have to set the hour and the minute of time. Often, you set the clock with either the radio station up or down arrows. On some car stereos, you use the CD track selector buttons for setting the clock.
    • 3
      Using either the CD or radio selector buttons, set the hour first. Push the button labeled "Set" or "Clock" and then set the minute with the same procedure. When setting the minute, some manufacturers allow you to move through in increments of five by pressing and holding the button. If the time of day were 2:49 p.m., for example, you would push the button 13 times, including nine times to display :45, then four additional times incremented by one to display :49. Push the "Set" button or the "Clock" button.
    • 4
      Determine whether your car stereo is equipped to automatically change when Daylight Saving Time begins and ends. If it hasn't changed at 2 a.m. of the time-changing date, you know it isn't equipped for this. In that case, set the hour either forward or backward and the appropriate time of the year.
    • 5
      If you can't figure out how to set the clock on your car stereo, wait until noon on any given day, disconnect your car battery and reconnect it.
Read more: How to Set the Time on a Car Stereo ' eHow.com http://www.ehow.com/how_5003245_set-time-car-stereo.html#ixzz1MlfuX6eT
May 19, 2011 | Car Audio & Video
I am trying to set the clock on a CRC-4050 auto-reverse cassette radio and can't figure it out. How do I do it? Thanks.
Turn on the radio. Press the DSP and right tuning button at the same time to adjust minutes. Press the DSP and left tuning button for hours.
Nov 24, 2010 | Car Audio & Video
GPX clock radio clock question
I emailed the company and they sent a pdf of the manual back the same day.
partsinfo@dpi-global.com
Jun 06, 2008 | GPX CRCD6306DT Clock Radio
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
