Question about Hotpoint Ultima WF860 Front Load Washer
Hotpoint aquarius ultima 1000, when wash cycle is comple the rinse cycle wont start and displays message check outlet pipe which i have done but it seems to be clear as i can syphon water from the machine via the outlet pipe
  • karl338 Jan 22, 2009
    THANKS VERY MUCH THAT WAS THE PROBLEM, FILTER BLOCKED UP AT REAR OF WASHER WITH WASTE AND SOME COINS MANY THANKS, KARL
  • Hotpoint Master
  • 3,463 Answers
It sounds as though the pump is not draining the water out.
If you have checked outlet pipe and it is clear, then you need to check the filter, if there is no filter at front of m/c, then remove the rear panel, and unfasten the large black hose that goes to bottom of drum, remove filter and clean, check pump at same time.
Watch out for water from the drum.
Refit filter and hose and test.
Plz rate my suggested solution, and feel free to leave a comment.
Thankyou.
Posted on Jan 21, 2009
I have a Hotpoint Ultima 1200 - WM75. At the end
Check the filter and the actual pump itself for blockage.unless you have already done so, also pump itself could be faulty.
Mar 29, 2010 | Hotpoint Ultima WF860 Front Load Washer
Spin not working properly, sounds ok but clothes are too wet once complete and the independent spin cycle leaves clothes soaking!!!
Sounds like a small blockage in the outlet pipes, possibly just in the filter but check all outlet pipes. Just done one the other day and it was a clothes button that had passed out of the machine through the pump to the outlet pipe but had turned sideways inside the outlet pipe.
Jan 25, 2010 | Hotpoint Aquarius WMA56 Front Load Washer
When i put it on a wash cycle it starts then all of a sudden the power light flashes rapidly and the rinse hold light flashes steady
Fault code F02 meaning Motor jammed / tacho detached: check motor
& module connections.. on the motor plug check that a wire hasn't become dislodged or broken...
Dec 14, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquarius wd440. Flashing lights
press and hold on off button till the display panel lights up.Then press and hold the on/off button and the start /cancel button together.You will now reset the washing machine settings.And just pick your cycle again
Oct 04, 2009 | Hotpoint Aquarius WD63 Front Load...
Just plumed in my hotpoint ultima it has done a
when you start the cycle the water will disperse. but check the fillters at the bottom of the dishwasher and make sure the drain pipe end is not crushed if you are enptying into the kitchen sink drain make sure the pipe is not kinked back on its self. try and get it as strait as you can.
Mar 27, 2009 | Hotpoint Ultima WF860 Front Load Washer
Ultima 1000 wont spin
there may be a blockage at the pump end of the drain hose or the filter.
Jan 21, 2009 | Hotpoint Ultima WF860 Front Load Washer
Outlet Pipe
Your machine has detected a problem with draining. The place to check is the filter located at rear of machine.To access it remove plate at bottom rear of machine & you will see a black pipe hanging vertically from the drum secured by a spring clip.The filter is in this pipe. If this is clear take off other end & check pump is not obstructed.Be aware that there will be water in these pipes so may be wise to take machine outside.Let me know if problem persists.
Nov 18, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint aquarius wf740
Sounds like water pressure could be low or inlet pipe is kinked.
F04: possible filling or water level problem. Check water inlet pipe (or shut-off valve), or the outlet pipe, or the pump or pump filter if accessible (check for blockages or foreign objects). Also could be the water valve solenoid weak, causing filling to be too slow.
F05: possible draining (pumping off) problem, check the pump filter, or pump, outlet pipe, or U-BEND.
Don't forget to rate!
Feb 27, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius 1000 deluxe
Try the "spin only" button to take the water out of your machine. If this does not work, take the pipe from the wall socket and lay it on the floor for the water to spill out. The spin normally does not work when the outlet filter is clogged; if the filter is clean you should then check your pipe coming out from under the tub (plug off the wall first before doing all these things). Last check your outlet pump, could be blocked with something. Refit carefully, you might need a nice pair of pliers to get the grip clip on and off the pipes.
Plug off the wall, & check your outlet filter first.
Nov 22, 2007 | Washing Machines
Hotpoint ultima 1200 washer/dryer
Have suffered the same problem. Suggest you remove back (after turning off electrical supply) and look at the water outlet pipe - you may have a sock or two in this - remember to reattach outlet and secure in position.
Aug 15, 2007 | Hotpoint Ultima WD72 Front Load...
Hotpoint Ultima WF860 Front Load Washer Logo
236 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
