Question about Taylor 5778F Body Fat Scale
Scale will not weigh - Taylor 5778F Body Fat Scale
Salter scales weighing more than double the weight
Sounds silly but check the scales for a Kilogram or Pounds switch. its usually under the scales and is a sliding switch. It should tell you on the display if you are weighing in pounds or kilos.
Sep 15, 2014 | Health & Beauty
Spring scale can be used to weigh it?
Spring scale shouldn't to weigh heavy items, it may easily malfunction. But it can be weigh some small items.
Dec 30, 2012 | Health & Beauty
I have a NOVA Weighing Scale model BGS-1212. I am not able to reset the weighing scale display. Please help
i HAVE NOVA ELECTRONIC PERSONAL GLASS SCALE MODEL BGS-1212. THE RUBBER GROMET STAND IS CRACKED. I HAVE TO REPLACE THE SAME PLEASE INFORM ME THE REPARI CENTER NO.
Oct 14, 2012 | Health & Beauty
How can I weigh my dog, it will not hold still on the scales?
This is really easy! Weigh yourself alone, then weigh yourself holding the dog, then subtract your own weight from both of you's weight. You can also ask your vet to weigh your dog for you.
May 15, 2012 | Pets - Others
How to calibrate seca 780
I recommend you look in your local yellow pages for a scale company. Calibration is very easy to do, but we recommend that you bring the scale to a local scale company. All unit sold by Precision Weighing Balances are factory calibrated and should provide you trouble free weighing for many, many years.
Jun 15, 2011 | Seca 780 Digital Adult Scale, 440lbs/200kg
Tells different wieght each time
Does it tell you a different weight each time you weigh yourself in the same few times? Or day by day?
If its consecutive uses that give you different weights, if you're within 0.2kg, I wouldn't be surprised if the scale can't do better.
Otherwise, weigh yourself each day at the same time, and take an average of 3 weighings for the 'best' weighing.
Mar 02, 2011 | Taylor Body Fat Analyzer & Scale, Model...
New Scale out of box will not weigh correctly
Take a 5 pound bag of sugar, flour or what have you. Put it on the scale. If it is off, turn the scale so that you can check every possible place for an adjustment. Adjust and go for it!!! Good luck...Lee
Jan 16, 2010 | Jobar International Idea Works Wireless...
Scale is not weighing correctly. Weighs correct
The scale must be on a hard, level surface. Make sure there is absolutely no dirt on any of the pivot points. Calibrate it with a KNOWN 25 pound weight.
Jan 04, 2010 | Health-O-Meter Health o meter 402KLWH...
Taylor 5778F Body Fat Scale Logo
26 people viewed this question
Top Taylor Measuring Tools & Sensors Experts
deton8 von Splosion
Are you a Taylor Measuring Tool and Sensor Expert? Answer questions, earn points and help others
