Question about Crafts & Hobbies
What kind of glue is used for model building?
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 45 Answers
The type of glue you use to build your model all depends on what materials you are using for the structure. It is important that the right glue is used so that it will hold your structure together. I found this article which may be helpful
Posted on Jan 10, 2013
Tip
Model Scratch Building
You may not have heard of it but scratch
building is a hugely popular hobby that fans take very seriously.
Scratch building involves building a
scale model but from scratch ie not using a commercial kit or a pre-assembled
model.
What are the rules of scratch building?
There are no official rules to scratch
building. Some people believe that you can only call it scratch building if you
use completely raw materials and don’t have any plans or measurements to work
from. But others are not such purists and are willing to use even commercially
built parts in order to build their models.
What kind of materials are used for
scratch models?
Anything can be used to build scale
models from scratch, such as; wood, plastic, clay, paper or metal.
How do I get good at scratch building?
Most scratch builders start by
practicing on ready made building kits for scale models. Some of these are very
detailed and despite having all the parts, still require a lot of technical
skill.
Once you are good at commercial kits,
you can move on to building from scratch.
How do I scratch build?
You need some kind of plan; either a
prototype to follow or a design of your own that can be transferred into a
pattern so that you can start to cut out the parts and pieces you need for your
project. At the end of the actual building, you then need to ‘finish’ the
piece. This involves trimming, polishing, painting, weathering etc. This is the
part of the process that will take your technical piece to the level of
realistic model.
Good luck and have fun.
on Dec 25, 2013 | Crafts & Hobbies
What can i use to remove glue from lcd screen
depending what kind of glue it is you can try a hairdryer and rub the screen with (isopropyl) alcohol.
- stronger solvents may not be used to avoid damage use-remove-glue-from-lcd-screen-wutfveiel3ypko01ydor435x-2-0.jpg
Apr 30, 2014 | Adhesives, Coatings & Sealants
I have a beko wm5100 washing machine and the pump impeller has come off Ive tried glueing it but to no avail is there anything else that I can do
Robert! Am I to understand that you...Never Mind! My Friend come over here I want to tell you a secret. Glue-Water-Pressure! They NEVER work! If it is an impeller it is probably a pump. most washers have two 1) Drain Pump (impeller) and circulating Pump-impeller. You need to REPLACE either or both the entire Pump, install it. Then use/store the glue to build Model Airplanes...Not on Washers?!
Mar 15, 2014 | Washing Machines
What kind of glue can i use to glue .030 4 ft by 8 ft aluminum sheets to plywood for exterior use ie camper
You can use Loctite PL Premium 10 fl. oz. Advanced Polyurethane Construction Adhesive or liquid nails adhesive. The PL may be available in a pail. It will permanently glue aluminum and plywood together.
Jan 31, 2014 | Adhesives, Coatings & Sealants
The paddle on my water dispenser broke off. Can this be glued and if so what type of glue should I use?
Hello, Thank You for using FixYa. I will be helping you today.No it can not be glued it would have to be replaced.
Thank You and please rate my answer if it was helpful..
Jun 23, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
Master mechanic glue gun 207 stopped working
There is a glue build up inside. Most likely in the feeding mechanism, try to heat it up, the unplug, and use like a paper rolled up to try to remove some of the glue. :)
Mar 25, 2010 | Crafts & Hobbies
I broke the paper tray on my Ricoh AP 2000; need a replacement
Everything is repairable! Between epoxy, super glue, model glue (works better on the plastics it's designed for) and Duct Tape!?!? Yankee Engineering!!, Come on. :^D
But to answer your question: eBay
Aug 24, 2009 | Ricoh Aficio AP2000 Laser Printer
What kind of adhesive do I need to replace the bellow LHW0050PQ?
there isn't any glue or anything that you use,what you see is most likely old detergent,it builds up on the rubber boot caused from using to much soap,then the washer starts to stink and the soap eats at the spider gear on the back of the tub or spin basket and you'll hear a loud noise when in high spin,you should only be using 2 tablespoons of soap that's it.but there's no glue,there's a spring ring that holds the outside of the bellows on and another in the inside,if your boot has the little drain tub on the bottom or top there's a little clamp that holds it on and that's it.good luck with your repair
Oct 06, 2017 | Whirlpool LHW0050PQ Front Load Washer
Which glue to reattach chromed plastic to plastic?
Use old fashioned model cement. Not the child safe type. The old type will melt the styrene to the styrene. The new stuff only fills the gap but never really makes a good bond.
Mar 10, 2009 | PUR (FM-9500) Air Purifier
Crafts & Hobbies Logo
614 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
