Question about Fargo DTC525 ID Card Printer
Printer is printer light and havin color problems
I have a DTC525 fargo printer & is printer my id cards light, & some colors are not printed like the color black & is happen at de back of de card too,... i had 2 change it 2 a darker blue
  • 526 Answers
You can either change the image darkness level on the printer or through the printer drivers.
on the 525 control panel, you can go to the setup menu, and search through it until you see image darkness, select it, and change the values, go up or down by 10 points at a time.
in the printer drivers, go to printing preferences, and there is a tab that
will have image darkness in it.
Posted on Apr 23, 2009
Dtc525 printhead not printing. no error
1, how do you know is the print head that is not doing the job
2, did you check if the print head is slack or a it lose ?
Apr 06, 2014 | Fargo DTC525 ID Card Printer
My fargo printer prints black and white on the back of the card
Possible solution: Change the resin dither from Optimized for Graphics to Optimized for Photos with in the printer driver under the image color tab.
Feb 23, 2012 | Fargo DTC525 ID Card Printer
Resolving a Card not fed error (Cards will not feed off the Hopper)
Make sure that your hopper card thickness guage (located on the right side of the hopper) is set to 30 ml or above if you are using standard 30 ml PVC cards. You may also need to clean the printer with a Fargo printer cleaning kit for this printer.
Also check to make sure to check your PVC cards. Sometimes they have too much static and can stick together not allowing them to feed. Fan the cards before placing them back in the hopper to make sure they are not sticking. In this process, try not to touch the printing surface of the cards as oils from skin will cause defective printing results.
For more id card printer tips, visit our technical assistance blog at www.safecardid.com/blog.
Nov 05, 2008 | Fargo DTC525 ID Card Printer
Printer restarts itself after putting it on
We would recommend to try to update the firmware for this printer from the Fargo website - www.fargo.com. Update the print driver to the most current version from this site as well. Run a test card from the LCD panel if the printer starts after your updates. If successful, run a test card from the print driver on the computer.
If this does not work, there may be major issues. Contact Fargo Technical Support at 800-459-5636.
Visit our id card printer blog for additional Fargo information at www.safecardid.com/blog.
Oct 14, 2008 | Fargo DTC525 ID Card Printer
Print quality with Fargo DTC500 printer
You might go to the print driver settings to change the way the printer prints the card. This can be found in the printing preferences. Go to the device options tab and choose "rotate front 180 degrees". Then print a card. This may fix the problem.
If not, try downloading the latest print driver from www.fargo.com.
Visit our id card printer technical assistance blog at www.safecardid.com/blog.
Sep 24, 2008 | Fargo DTC525 ID Card Printer
Is there a fargo certified service center in the Seattle or surrounding areas?
You could look at Fargo website www.fargo.com to find service center neer you or call customer service they will help you Number on website
Aug 06, 2008 | Fargo DTC525 ID Card Printer
Printer washes the image out.
The problem was with Photoshop. After changing the print settings so that nothing was modifing the color settings it worked just fine.
Jul 31, 2008 | Fargo DTC525 ID Card Printer
Problem on card print using Fargo DTC525 Single Side Print model
you can check with fargo, or perhaps your vendor is giving you the bad rep, since they refuse to help you. i would not do business with them again.
if the printer worked before maybe the program needs to be reinstalled.
Jun 10, 2008 | Fargo DTC525 ID Card Printer
Breaking Ribbon
Ribbon breaking continuously is caused by 2 common problems. 1. The printhead is going down before OR after the card has passed through. You would know this when you open your cover, and unlock you printhead, is the break before or after the card? Try printing the test page from the driver. That doesn't print "Edge to Edge" so if this is the problem, it should not break. 2. The print head heat settings are too high. If this is so, you can change this on the printers menu panel. I can explain more information, once I know your problem.
Jan 15, 2007 | Fargo DTC525 ID Card Printer
Fargo DTC525 ID Card Printer Logo
206 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
