Question about Dimplex CS3311 Compact Heater
Flicker motor runs backward - Dimplex CS3311 Compact Heater
I have a Zebra 170xiIII. The feed motor runs both forward and backward. Will be running fine and I have to pause and will start running backward. Have replaced motor and same thing. What's wrong?
The DC power supply drives that motor and may start running it backwards when it begins to fail. The motor normally makes more noise than usual in both directions when it starts to fail like this.
Google "43470-002 power supply, Xi III +" and you will be able to purchase the part.
Feb 24, 2015 | Zebra 170XiIIIPlus Thermal Label Printer
140 international tractor when turn motor off the motor runs backwards
It is called dieseling. Could be carbon on the plugs or in the combustion chamber. Carbon gets hot enough to cause fuel to keep igniting after ignition is turned off.
Apr 18, 2014 | Farmall International Tractor 140 Radiator
Fan motor on Carrier inside runs backwards
Sometimes a motor can start to run backwards... on an indoor fan it is usually because the air inside for some reason started the fan backwards while it was off and then when power is applied it continues to run backwards... once this happens the fan is ruined and it often will not atrt the right way even after the air problem is solved...
You will need to replace the motor and see if you can figure out why there was reversed air flow in your system...
heatman101
Aug 21, 2010 | Carrier 38CKC036 Air Conditioner
Fan motor runs backwards
Make sure the capacitor is connected to the start lead, not the run lead(s). Also some fans come with some wires you can switch to reverse the direction. If your motor has them there will be 4 and the label on the motor will tell you how to connect them. Let me know if you need more assistance or if this helps.
Jun 02, 2010 | Carrier 38CKC042 Air Conditioner
3 days old and when I push any of the buttons that are supposed to cause belt to start moving or to change incline there in no response, though the electronic display starts counting the seconds as if it...
The single most cause of no motor output is failure of the DC motor control Look for any test lights on the power boards beneath the motor shroud use caution when removing the motor hood because you may still have electricity in the motor area even if the treadmill is unplugged.
One of the lights should be labeled PWM when hitting the start button that will start flickering , because the upper console is sending a signal to the lower board telling it to start the motor. if that process happens then you need to check the motor
Cordless drill battery- get a fully-charged, 18 volt (preferred) cordless drill battery and on most treadmills connect the red and black motor leads to the battery (some have different colors but if you have two wires and get it hooked up backwards, the motor will just run backwards and won’t be harmed). If good, the motor should operate at about 1 MPH.
Car battery- these are 12VDC high amp batteries so the motor will turn slowly but you can walk on the belt. Always be careful with battery acid on these things so we don’t recommend bringing them in the house…take the treadmill to the battery. If does move then the controller board needs to be replace.
May 24, 2010 | Nordic Track NordicTrack Elite 9500 PRO...
I have a Horizon elite 507 treadmill, everything works except the main motor which drives the treadmill itself, is there a simple answer such as a fuse or trip switch i can change/reset?
Unplug your treadmill and remove motor shroud ,locate Motor control board their a series of LEDs . Now without getting on treadmill hit start look down and you should a light starting to flicker this is your PWM signal, t the upper console sends a signal to the lower board and instructs the motor to start. This tells me that the upper board and cable are functioning properly and our problem is either the board or motor.
DC motors can be easily tested in a number of ways. Many times a motor is replaced only to find another problem exists so be sure to test the motor if you think it is a problem. Methods to test a motor: 1) Cordless drill battery- get a fully-charged, 18 volt (preferred) cordless drill battery and on most treadmills connect the red and black motor leads to the battery (some have different colors but if you have two wires and get it hooked up backwards, the motor will just run backwards and won’t be harmed). If good, the motor should operate at about 1 MPH. 2) Car battery- these are 12VDC high amp batteries so the motor will turn slowly but you can walk on the belt. Always be careful with battery acid on these things so we don’t recommend bringing them in the house…take the treadmill to the battery.
If the motor test good then all fingers point to the Motor Control Board replace the board. When was the last time lubricated the running deck?
Answer: Never ! Then I suggest you purchase lubricant and apply it on the deck about 75% to 85% of the problems are belt and deck related.
May 23, 2010 | Horizon Exercise & Fitness
My PX110MX will not turn on, if I hold the on/off button down I can hear the reverse motor run but the forward motor will not run.
If you can hear the motor run that is a good thing....however there is only 1 motor...it does both jobs running backwards and forwards....if it runs backwards the motor is "probably" ok and the problem is with the pcb inside...call Royal at 1-800-524-0799 for parts assistance.
Feb 02, 2010 | Royal VF1000MX Shredder
Hoover Elite motor runs when moving backwards but not forward
Are you sure its not just your belt on the beater of head slipping and needs to be replaced?
Oct 18, 2008 | Hoover Elite Rewind Bagless Upright...
Dimplex CS3311 Compact Heater Logo
42 people viewed this question
Top Dimplex Heating & Cooling Experts
Paul Carew
ashburton
David Burbee
David Burbee
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
