Question about Panasonic PT-47WXD63 47 in. Rear Projection Television
Proline LVD198W DVD player not working
I have a Proline LVD198W and the DVD does not work when a disc is inserted into the drive. This is the second time this is happening and it is now out of warranty.
Please can you advise what I can do or where I can get this repaired. I live in Hertfordshire. A mate of mine said to buy a DVD cleaner this may solve the problem. Thanks in anticipation of your response. Toks
SOURCE: Plays CDs but not DVDs
Melisha, I had a similiar problem. Go into the onscreen menu with the remote using the "ACTION" button on the bottom left of the remote. Using the arrow keys in the center of the remote, move to the menu for the audio processing. It will have menu items for DTS, Dolby Digital etc. Change the menu parameters for the "Down conversion" to "yes", get out of the menu mode and see if your DVD works again. If not, make sure there is no DVD or CD in the player, and press the "open/close", "pause" and the double left pointing arrow buttons all at the same time for about 5 seconds until the display on the DVD player says "INITIALIZE". This resets your machine. I hope this helps you.
Posted on Mar 22, 2007
SOURCE: My DVD tray does not open to insert new disc.
great picture no audio
Posted on Jul 27, 2009
  • 93 Answers
SOURCE: DMR-EZ48V- DVD drive not working
Check Panasonic.com for Firmware updates. If it has a reset button reset it. Take off the cover remove dust and lint, also clean laser eye with rubbing alcohol. DO NOT LOOK DIRECTLY AT THE LASER LENS IF YOU PLUG IT IN, DURING THE OPERATION.
Posted on Sep 14, 2009
tvtek
  • 1284 Answers
SOURCE: DVD player cannot read DVD disc.
Have you tried other DVD's in this unit and they work? If so it might be just an incompatibility issue with that DVD in your TV.
Posted on Nov 26, 2009
Demonic-2011
  • 508 Answers
SOURCE: Unit plays video but not DVD. Once inserted, disc
Sorry but the 'NoRead' error is usually the result of the DVD-RAM drive failing or it has failed, in which case a replacement drive is the only solution - $450 for a new drive - plus labour on top = more than the whole unit is worth new. Not only that, but the service agents will probably need to upgrade and reconfigure software as well, then there is the prolonged and exhaustive soak-testing...
I believe for similar money, you could get a Panasonic DMR-EZ48V with 24 month (or optional extended warranty - extra 3-4 years) on all parts and labour (compared to spending the same on repairs to your EZ47V) or you could save those pennies and invest in perhaps a better more reliable brand and model of DVD recorder (if that's what you want to use). You could also try (for zero cost) a cleaning and checking procedure (if unit is not under warranty) found within FixYa and similar websites. Good luck in your venture!
Posted on Feb 01, 2011
The player will read dvd but will not play cd
Richard: This is what EHow.com said: "
  • Turn on the DVD player. It generally takes a few seconds to get going. Take out the DVD if there's one in the drive already.
  • 2 Make sure the disc isn't scratched or dirty. Use a soft rag to clean the disc if you see any smudges. Insert the CD into the DVD player's disc drive and close it.
  • 3 Press the "Play" button on the DVD player or remote control. Some DVD players will begin reading the disc automatically. Pushing the button works just as well.
  • 4 Use the "Scene Selection" buttons on your remote to select a track. Some DVD players have odd ways of ordering the buttons on the remote. You might have to play around a bit before you find all the right buttons to work the CD playing function of your machine.
  • 5 Crank it up and enjoy your music. The DVD player will act just like a CD player and play the tracks of the CD through the TV.
  • Read more : http://www.ehow.com/how_2036285_use-dvd-cd.html
    May 28, 2015 | Televison & Video
    Tip
    Proline DVD-1000 Region Free Fix
    Proline DVD-1000 DVD Player Region Free Fix
    Would you like to unlock your Proline DVD-1000 DVD Player to Region Free?
    Follow these steps to unlock your Proline DVD-1000 DVD Player:
    1. Open the disc tray
    2. Place a region 1 disc in the tray, but don't close it
    3. Press the buttons 0, 1, 2 and then 3 on your remote control in order, one at a time
    4. Press the Play button on either your remote or the player
    Your Proline DVD-1000 DVD Player is now Region Free.
    I hope that helps.
    on Apr 25, 2010 | Televison & Video
    My cd/dvd player is not working or read dvd disc... what would i do to read such dvd disc in my player..
    Good day,try to insert original cd/dvd disc,but if it's still not working.may be your player is defective.i advice you to use external optical disc drive.God bless!
    Aug 18, 2011 | Acer Computers & Internet
    When I insert a disc I get a "Disc Error" after
    Most DVD players display that kind of error when unable to read data on you disc media. Try other DVD disc if that post the same problem. A new one will test if it is the unit problem or the media disc problem. If it post the same problem on a disc that runs well on other players then your player probably has a dirty lens. You can clean the lens using commercially available DVD lens cleaner on the market.
    Jun 14, 2011 | LG DP450 Portable DVDDivX Player
    The dvd player is not working. It says that the playback on the disk may not work. Is there any way to fix this
    The most common reason for the player not reading discs is a bad drive. The following website sells the drives and does installs:
    store.richspsxparts.com/wiiredvddr
    This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your player including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your player going again!
    Jun 01, 2010 | Philips Magnavox 20MC4304 20 in....
    DVD disc is not working
    The Drive lens nneds to be cleaned by a lens cleaner ...
    Aug 11, 2009 | FEC RKMV5 Custom Rackmount Kit for JVC...
    Sony DVD player reads no disc after inserting disc?
    Its due to faulty Laser Lens/head. Try cleaning it by cleaning CD. If still the problem persists, contact near by service center.
    Mar 13, 2009 | Sony DVP-NS715P DVD Player
    DVD disappeared in DVD Player after viewing movie
    Get the dummy cd disc, put a blue tac on it. Insert it. Then after few seconds, eject it. Your dvd disc should stick with it when they came out. It worked for me and hope it will work for you.
    Jan 31, 2009 | Kenwood DV-505 Multi-disc DVD Player
    Jensen VM9312 not loading DVD.
    If it reaeds the cleaner... then try another disc. 20-30 seconds is a long time to looad a disc...
    If the new disc does not work either , I would suggest resting the deck .
    If reseting does not help , it is still under warrantee. so have it serviced.
    Dec 11, 2008 | Jensen VM9020TS Car DVD Player
    Unlock LG DVD
    The following hack worked for my player. It works for most LG and Aiwa players too. To hack the player try this:
    • Power on player with no disc inserted and wait for "No Disc" message on screen
    • (using the remote) Press PAUSE
    • Press the numbers 314159 in order. (player should now show "COdE - -" the same as below)
    • Press the number of the region you desire ( 0 = any region, 1 = US&Canada etc.)
    • Press PAUSE
    • Power off the player for a few seconds..power back up and insert your DVD disc
    Jan 08, 2008 | LG Televison & Video
    Panasonic PT-47WXD63 47 in. Rear Projection Television Logo
    87 people viewed this question
    Top Panasonic Televison & Video Experts
     Grubhead
    Grubhead
    Demonic-2011
    Demonic-2011
    Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
