Question about McCulloch FHH18A Electric Pressure Washer
Need replacement nozzle pa6630gf - McCulloch FHH18A Electric Pressure Washer
I have a model 51012 washer..I need replacement nozzles. where can I get them? thanks.
Go to their website and check out support. Some outfits will only sell parts thru their "authorized" dealers.
Jul 19, 2015 | Greenworks 1700 PSI 1.4 GPM Electric...
Ep93-11 steam cleaner replacement nozzles
please go to http://www.eureka.com/en-US/Customer-Service/Videos/
and proceed with common sense for troubleshooting and replacelmente nozzles.
God bless you
Jul 15, 2012 | Euro-Pro EP93 Steam Vacuum
Canon mx860 clogged nozzle
Inkjet printers need to be used frequently to prevent inkdrying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Jun 26, 2012 | Office Equipment & Supplies
The power nozzle on my c141b model aerus electrolux canister vaccum no longer turns on. It was working when a large stringy object was sucked in. When hitting the red reset button, nothing happens. Is...
It's not a fuse.
Turn the power nozzle on it's top. Try to rotate the brush. If it won't spin, there's till something holding it. Remove all strings, threads, and whatnot from the roller. Try to rotate it again. If it still won't spin, it needs to be taken to an authorized Aerus Electrolux store for diagnosis and/or repair.
Try connecting the hose directly to the power nozzle to see if runs. If it does there's most likely a broken or disconnected wire/cord somewhere in the wands, or the power nozzle. If it doesn't, the problem is with the power nozzle. It could be the motor, although that's unlikely. Other possibilities are broken or disconnected wires or a bad switch. Again, it needs to be taken to the shop to be diagnosed.
Disconnect cord to the power nozzle and examine the prongs on the cord and the terminals in the power nozzle. If there's any discoloring or cracks, they need replaced. Reinsert plug and make sure it fits tightly.
Disconnect cord from wand plug and check for the same things.
Jan 24, 2011 | Vacuums
Shoot kerosene when trying to start
You need to either clean your nozzle assembly or replace it.Cleaning it can be done as follows, you need carb cleaner Q-tip and a tooth pick. First soak the nozzle in carb cleaner, then use the tooth pick to remove any obvious large pieces of what ever just do not damage the front of the nozzle the Q- tip is for cleaning all the exterior surfaces. Now that you have gone this far you need a compressor and an air gun to blow high pressure air backwards and forwards thru the nozzle this should clean it out. On older models they have a screen assembly behind the nozzle if yours does clean it as these corrode while in storage. Put the assembly back together and test nozzles atomize the fuel (fog) not spray, so watch carefully if it sprays fuel you need to replace the nozzle, pay attention to the spray angle and GPH rating printed on the side of the nozzle it is very important when purchasing a new one that you buy the exact same rated nozzle. Good Luck
Jan 14, 2011 | Dayton E52 Utility Heater
When I vacuum with the power nozzle, it keeps cutting off. Do I need to replace the hose or the power nozzle?
Not necessarily. It's hard to tell without checking it out. I strongly recommend taking it to an authorized Aerus Electrolux store and letting the service tech check it.
If you have the "Sidekick", you can try using it. If it still cuts out, it's the hose. If not, the wiring in the power nozzle is loose or worn and needs to be replaced.
Keep in mind that you may not need to replace the hose or power nozzle, just have some wiring repaired.
Nov 07, 2010 | Electrolux Epic 6500 Vacuum
I need a Hayden Superpack Deluxe owners manual so I can change the belt
Hi There,
Actually Hayden uses Panasonic to make all of their power nozzles. Replacing the belt on your Hayden is the identical process to replacing the belt on Panasonic canisters. Kenmore canisters also use Panasonic power nozzles, it's the same process with these.
There is also a power nozzle overload switch on the top of the power nozzle that will shut down if anything is vacuumed up that causes stress on the belt. Try pushing this reset switch before opening up the power nozzle to install a belt. It may be something as simple as a reset switch.
If this doesn't work, here's a link to a repair that I've posted on Fixya on how to replace the belt on a Kenmore canister power nozzle, the process will be identical to your Hayden power nozzle.
http://www.fixya.com/support/t4563318-change_belt_sears_vacuum
Hopefully this helped you. Please be so kind and rate the repair, or leave feedback for the fixya community.
Thank you,
Chris
May 22, 2010 | Hayden Industries SuperVac 6000 Central...
Small crack in the wand.
This part number is for the wand and hose assy 41 7228-H18A01 WASH MANCHINE HAND ***'Y
This is the manual I used: http://ipl.ordertree.com/ipl/604/FHH18A.pdf
It is available from this source: http://www.ordertree.com/ModelInfo.asp?Final=1&SiteID=1&Mfg=139&Model=FHH18A click on the 4th item with the part number above listed and add to cart. $35.93
The shipping fees are listed here: http://www.ordertree.com/cms/shipping-policy/14.html
$9.95 + $12/95 for Canada shipping
If this is not your model or not part of what you needed just respond here and I will get back to you. Please ensure you include your exact model number when responding.
Thanks for using FixYa.
Kelly
May 14, 2010 | McCulloch FHH18A Electric Pressure Washer
I need to replace the nozzle on my FH180B. the
Common issue. Sounds like your nozzle is just clogged. You can try and run a wire through it to clean it or soak it overnight in white vinegar to loosen up the deposits.
May 01, 2010 | McCulloch MCCFH180B Electric Pressure...
Need a new electrolux power nozzle model N106m
If you're looking for a new head for your vacuum. Then you're going to have to replace it with the same type of nozzle.
However, wall inlets are standard so you can purchase any kind of attachment kit and it'll fit your inlets and work with your system. Their are many online retailers that offer a wide range of kits that will fit your system.
Mar 22, 2010 | Electrolux Centralux Vacuum
McCulloch FHH18A Electric Pressure Washer Logo
346 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
