Question about Lorex Home Security
Lorex WL2700
Record error
Lorex solid red and not responding
Did you check the hard drive it may look like it's recording but the hard drive can still be bad thx..
Feb 03, 2018 | Lorex Home Security
Lorex WL2700 blue screen and shaking
plug the camera directly to monitor if no change check connectors and cable
Apr 14, 2014 | Lorex L23WD845 4-Camera Security System...
Lorex security camera
Coax from camera needs to feed vcr, at line in, line out from vcr goes to input of tv ie av1 av2 video in what have you. go that far and see if it makes sense.Then you can set vcr to record continuous and watch it at same time on tv or monitor.
May 14, 2017 | Lorex Home Security
Lorex-edge model no lh314 series will not record and beeps and says hdd is not installed
You need top open the top of the case by removing the screws and check to see if the hard drive is operating (it will be warm to the touch and may be making a slight noise). If the hard drive is not working, verify that it is plugged in. If the hard drive is bad, you can replace it with a SATA hard drive. The Lorex system will see the new hard drive and ask you to format it for use with the system.
Feb 02, 2013 | Lorex EDGE L314501C4 4-Channel Network...
I lost the owner manual so I don't know how to use it to record. Can you show me how to record it? or tell me the website where I can download the owner manual? My Lorex model is Sg7964
The manual is available here: http://www.midwestcommunications.com/cctv504.html . The direct link is: http://www.midwestcommunications.com/SG7964_manual.pdf .
If the timer is not currently active, then for a basic recording, put in a tape that has the erasure prevention tab in place. Then press Rec/PlaySpeed (up or down arrow) to set the recording speed. If you want to skip the setup steps, press Display. Then press Rec. Press Stop to stop recording.
I hope this helps.
Apr 29, 2011 | Lorex SG-7964 VHS VCR
How do I delete recordings on my Lorex QLR440 system?
You can find the details to the same by going to:
http://static.tigerdirect.com/pdf/lorex-QLR440-manual.pdf
This link would provide you a manual and guide you through the process
Sep 09, 2009 | Computers & Internet
Home Security Logo
55 people viewed this question
Top Lorex Home Security Experts
Lawrence Oravetz
gbob59
Are you a Lorex Home Security Expert? Answer questions, earn points and help others
