Question about NetGear WGR614 Wireless Router
Wireless my pc does not recognize my router.
  • deliverance9 Feb 03, 2009
    i have an ethernet cable from my wireless router to my xbox. but have no signal
  • pauldvs1 May 11, 2010
    Did you try the install disk?
    Scholar:
  • 141 Answers
There are several reasons for that. Try this http://technicalsupport.blog.friendster.com
Posted on Feb 16, 2009
Linksys router not recognize internet
Make sure your router's WAN port is set to dynamic IP. If the light on the front doesn't glow/blink for the WAN port, try a different cable. If a different cable doesn't work it's probably toast. :( This problem appears to be directly linked to the relationship between the WAN port and the modem. Given that the devices can connect to the router, but not internet, it has to be the WAN. Sometimes if the modem goes out it will send too much voltage through to the router and fry the WAN. Had that happen to my parents router. If the above doesn't "fix ya" then try a different router.
Worst case, you might have to put a wireless card in your PC and bridge the modem (wired connection) to the wireless card and broadcast for your wireless devices. At least until you get a new router.
Aug 02, 2013 | Dell Computers & Internet
I just used recovery disk to restore back to factory setting for acer aspire 7741Z. Now it won't recognize my wireless router
To connectyour computer to a wireless router, you click the Refresh networklist, then Choose your wireless network and then click Connectto your secured Wireless Network, it will asks for a Network Keybefore allowing you to connect into your wireless network. This NetworkKey is either the WEP, or WPA or WPA2 Encryption key that is used toconfigure the Wireless Router. The Passphrase is an alternate way tosetup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router.http://www.fixya.com/support/r5270415-network_password_network_addressFor information on securing your wireless network,configuring the wireless router and configuring the wireless card in thelaptop/computer, please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jul 28, 2012 | Acer Aspire 7741z
Wifi modem is not recognized
Try recycling the wireless router by unplugging the power to it and wait 20 seconds then plug the router back in. Sometimes that is all it takes.
After recycling the router if the adapter still does not show any wireless networks make sure you don't have the wireless radio turned off in the software that runs the adapter.
If all fails, try the adapter in another usb port if it is a usb adapter.
You could reinstall the adapter's software and driver.
May 06, 2012 | AcerPower 2000-UD431C - Core 2 Duo E4300...
Iphone doesn't recognize router
Check the wireless settings of your router. Make sure that Wireless SSID broadcast is enabled on your router.
If other wireless devices are able to see the network and only Iphone is not able to see the network then it might be the issue with the Iphone.
You can try changing the wireless channel on your router. You need to open the setup page of the router using 192.168.1.1 and change the settings.
Dec 07, 2011 | Linksys Wireless-G Broadband Router
A random guy came in and setup a home network for us using a Netgear Wireless router (WGR614v6). We have a PC on main level, an iMac and laptop in the basement that connect wirelessly and without any...
Hi whioch computer has a problem ?
A PC with the new hard drive ?
Mkae sure that you have the wireless adapter working on the computer.
If it is working then try to find the network .
Click Here for more info about wireless network.
Oct 08, 2009 | NetGear WGR614 Wireless Router
Unable to get PC to recognize wireless connection with DI-624
Which is it? PC cant connect or not able to setup wireless? If the router came with a setup CD, run that from your pc... Make sure you have a crossover Cat5(ethernet) cable connected between the router and a PC just to set it up initially... within the router can enable or disable wireless function... But to really narrow your device down, i need to know the hardware revision number... its on the same label as the MAC address on the outside of your router
Apr 03, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Wireless conection
Window XP...go to start > Control Panel >Network Connections...
Does your laptop have built-in wifi...or wireless PC Card ? Make sure your laptop recognize your "wireless PC card" or a built in Wifi system.
Feb 20, 2008 | NetGear DG834G Router
Problem connecting to the net
You router may be set to be DHCP enabled so that it allocates the ip addresses automatically to each pc, so check that the pc's network card with connection problems is set in the properties on the TCP/IP line is set to obtain an ip address automatically. You can also try, Start>run then type ipconfig /flushdns to clear the pc ip address and dns. and restart pc. Lastly if you pc is both network cabled and wireless, ensure one or the other is dissabled as this can confuse the ip adress alocation.
Apr 29, 2007 | Linksys Wireless-G WRT54GR Router
NetGear WGR614 Wireless Router Logo
22 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
