Question about Zanussi ZWD1470W Front Load Washer / Dryer
No spin E20 alert on washer how can i fix? - Zanussi ZWD1470W Front Load Washer / Dryer
  • Zanussi Master
  • 3,463 Answers
E20 is saying that the water is not draining, locate and clean filter if washer has one, check pump and outlet hose for possible blockage, make sure drain hose is not trapped or restricted in any way.
Plz rate my solution.
Thanks.
Posted on Jan 21, 2009
rajeshmb
  • 38 Answers
SOURCE: E20 Error sign
Plug off the mains. First drain out all your water by lowering the exit hose into a bucket or drain. You have to look for screws below the front kick-panel, the panel comes down & out. The pump is on the right side. Be prepared for dirty water. Inside the big flexible tube (coming from the tub bottom) is the filter, be prepared to find all sorts of junk here, clean out. Examine your pump also, clean out the impeller. Carefully refit all. Your machine would be fine. Don’t wait for the machine to jam to look into your filter.
Posted on May 30, 2009
  • 29 Answers
SOURCE: E20 ERROR
It doesn't spin because it has to drain first. E20 means not draining. You'll very likely have something caught in your drain pump. If you take the two screw off at the front, very bottom of you washer you'll be able to pull down the small panel to reveal the drain pump at the right corner. if you empty all the water from your machine you can take off the spring clamp attaching the thick rubber hose from your tub to your drain pump. ( you may want to have some old towels ready ) With this off you can feel around for what's blocking the drain pump's impeller. You may want to take the screws out that secure the drain pump to the base and the other spring clamp that attaches the drain hose to the drain pump. Good luck!
Posted on Oct 13, 2008
SOURCE: no spin E20 alert on
clean out filter (small door front bottom right, then unscrew filter and clean it)
Posted on Jan 24, 2009
carlsbiz
  • 1124 Answers
SOURCE: My washer says E20 and wont spin. Any suggestions
I think I had same problem.. It was because my load was very unbalanced.. I had a hevy item with a few small items inside..
These front load washers have sensors for the weight balance.. If it is to heavy in one spot - it wont spin...
Posted on Jul 08, 2009
  • 1382 Answers
SOURCE: Repeating E20 alert on washer
  • Get the washer laying on it's side and using the access hole on the bottom carefully remove the screw clamp holding the large hole of the rubber housing to the tub drain (it will be obvious all other clips are green compression clips).
  • Carefully work the strainer out of this flexible rubber drain housing through the large hole.Clean it out and replace you will be good to go. Also remove all the hoses and check for a buildup of gunk. Hope this will fix your problem.
Thank you!!
Posted on Jun 21, 2010
Thank you!!
Jun 21, 2010 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire front load washer (LTF600ES1) Error E20
this is an error that indicates the tub is clogged or draining slowly
to fix this you have to go under the washer and pull the tub hose off and clean all obstructing stuff in the hose and thru the hole on the tub
Oct 18, 2008 | Frigidaire ATF6000ES Front Load Washer
E20 error, but isn't spinning
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 14, 2010 | Frigidaire Affinity ATF7000ES Front Load...
E20 message want spin
E20 is not an exact error code. It's indicating a possible pump out problem. Here is a few possible causes of an E20 error code:
1. Restriction in the drain pump
2. Failed pump
3. Water not pumping out fast enough (crimped drain hose)
4. Too many suds ( too much detergent or wrong kind)
5. Pressure switch (not communicating with control board)
6. Loose wire at pressure switch
7. Loose wire at pump or control board
8. Failed control board
Apr 29, 2010 | Frigidaire ATF6000ES Front Load Washer
My washer says E20 and wont spin. Any suggestions on what to do to try to fix it?
Jul 08, 2009 | Frigidaire Affinity ATF7000E Front Load...
Code E20
my cloths will wash but will not spin out the drum stop turning when it comes to the spin cycle makes a humming noise
Mar 30, 2009 | Frigidaire GLTF2940ES Front Load Washer
Oct 30, 2008 | Frigidaire GLTF2940ES Front Load Washer
E20 ERROR
Sep 28, 2008 | Frigidaire GLTF2940ES Front Load Washer
Your washer is not draining properly. You need to check if the drain hose is kinked and also whether the household drain is running smoothly.
Aug 02, 2008 | Frigidaire GLTF2940ES Front Load Washer
My washer wont spin out it has a code that is E20
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Jan 12, 2008 | Frigidaire GLTR1670A Front Load Washer
Zanussi ZWD1470W Front Load Washer / Dryer Logo
132 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
