Question about Tunturi R25 Rowing Machine Rower
Strap / rope gone inside - Tunturi R25 Rowing Machine Rower
2006 ultra clASSIC HOW DO YOU PHYSICALLY REMOVE BATTERY I CANNOT GET MY HANDS AROUND BATTERY IN ORDER TO PULL IT UP AND OUT
There is a strap available that clamps to the battery posts.. you could buy one of them.. or, you could work a strap or rope down under the battery and pull it up by that.
Jun 03, 2018 | Ultra Motorcycles
Saturn sedan back seat release straps
Fun stuff.. You may have to remove the back seat and try to rig something with a rope or heavy cord
Jun 09, 2016 | Saturn Cars & Trucks
Replacing cargo strapping top of kayak
Just find strong nylon rope of the same diameter as is on it now, and re-string it all. Use nylon because it lasts better and is stronger than poly rope. Use a colour that contrasts with your boat colour.
Apr 06, 2014 | Current Designs 12 Ft Kestrel 120 Roto...
Rope lights
Hmmm a lot of rope lights are just mini xmass tree lights inside a plastic tube. If one of the bulbs burns out for that section the it takes the whole section out. Sounds like it's time for a new led rope light.
Mar 11, 2014 | Lutron Electrical Supplies
How do I attach wrist strap to vivitar dvr 880 hd
This was really tricky.
There are two holes on the top, close together.
Slide the thin loop through the hole closest to the side of the camera, and then stick a pin through the other hole and try to 'fish' it out. You can tell when you've hooked it because you can pull the needle by pulling the strap. Once it's hooked, you have to carefully pull the needle out, keeping the strap from sliding off by angling the needle away from the other hole. Good luck. Took me quite a few tries.
Jan 20, 2012 | Vivitar Video Cameras
I am getting a lot of vibration noise from the tie down straps [carrying kayak]. What should I do?
i asume you are refering to the kayak being vehicle mounted. and vibration cased by vehicle at speed.
if so try round straps or rope this should reduce vibration. rather than flat straps.
alternative would be to use
pipe insulation foam. the type with the ****.
slide this over the strap during drive to reduce noise.
i hope this was useful
Dec 11, 2010 | Thule Boating
Up until moments ago my only problem was that the tension rope had come off the pulley. I have taken the entire side off to better visualize how to get the rope back on. however, i don't fully understand...
A twisted strap means that it's life is over. You must change it. Even if you keep putting it on the pulley it will keep coming off. To stay on the pulley it must be strong enough not to get twisted.
Jan 18, 2010 | Bowflex Exercise & Fitness
Flat tires on Radio Flyer all terrain wagon
The trick is to spread out the sides of the tire so that they touch the side of the rim. That way, the air you pump in will fill the tire instead of coming out the sides.
This is how it's done: You will need a cargo strap with a ratchet. Sometimes these are referred to as a "come-along". It might take a few minutes to figure out how it works if you've never used one before, but what you wanna do is wrap the strap of the come-along around the circumference of the tire, and then tighten it. The tightening action will spread the sides of the tire and hold them there.
Aug 30, 2009 | Radio Flyer All Terrain Cargo Wagon
How to assemble pull cord
Remove engine cover. Try turning the inside where rope goes counterclock wise then let go (watch your fingers so you don't get pinched. If it spins back remove the rope and and turn the inside till you get some good tension. Put a screw driver through the fins to hold the inside in place so it doesn't unwind. Make sure you line up the hole in the inside so the rope will go straigh through the hole on the shroud and the inside wheel. Tie off the rope and hold the rope and remove the screw driver and slowly let rope back in. Pull a few times to check before reinstalling. Also check the inside wheel. There should be in the center of the wheel a bolt that holds on a flat piece of plastic and under that directly across from each other is two little tabs that engage the fly wheel. Make sure they are both properly seated. If it recoils when you test it reinstall and try starting mower.
Good luck and let me know if this helps
roundo4
Aug 13, 2009 | Mtd Garden
L1997 BMW328i - Ioose convertible top ropes
there is a repair kit avaiable from your dealer and a trimmer will have to install it this is called tension straps.
Jul 01, 2009 | 1997 BMW 328
Tunturi R25 Rowing Machine  Rower Logo
Top Tunturi Exercise & Fitness Experts
gbob59
Jeremiah Meyer
Jeremiah Meyer
Are you a Tunturi Exercise and Fitnes Expert? Answer questions, earn points and help others
