Question about Santai TD-V26 Portable Mini Digital Speaker with Micro SD / TF / USB /FM - Green
What mean h1
Sound is off
My wall air con kelvinator just installed turned off after 2 hrs and H1 came up on display
H1 is defrost mode. This means that the outdoor coil has gotten too cold and needs to warm itself up in order to continue heating. Heating will resume in a short period. Nothing wrong with machine, this is normal when outdoor air temps are extremely cold.
Jun 21, 2017 | Heating & Cooling
How to remove carrier bearing from from prpeller drive shaft on a 2003 H1 Hummer
Do you mean the center support bearing of the two piece driveline?
Sep 20, 2016 | 2003 Hummer H1
What the code h1 means samsung washing machine
H1 on a samsung washer is a heating problem.
You need to check the heater and the control unit and find the fault form there.
If you have a multimeter you can test the heater as it should read about 28 ohms. If faulty then the heater will need to be replaced to cure this.
Check it out and see what you find but the H1 error code is a heating problem.
~~~via just answers
Feb 14, 2016 | Samsung Washing Machines
What does H1 code indicate?
Hello E, I appreciate your post!
I see that your Frigidaire air conditioner is displaying an error code of "H1". I have reviewed the air conditioner and the "H1" error code could be an "HI". The "HI" error code means that the room temperature is above the display range. I would recommend performing a reset on your air conditioner. In order to reset the air conditioner you need to unplug the power cord you can press the reset button and then the test button that should restart your air conditioner. If that does correct your issue I would recommend seeking assistance from a professional technician for proper diagnosis and repair. I hope this information is helpful for you. -Matt
Jan 22, 2016 | Frigidaire FRS12PYS1 12000 BTU Split...
In IFB front washingmechain AC h1 error is coming what to do
AC h1 is actually AC hi error which means input voltage is too high. Wait for sometime for voltage to stabilize Washing machine will automatically start. If not call electrician to check electrical fault for high voltage
Jul 03, 2014 | Kenmore Elite 45986 Front Load Washer
2006 arctic cat 650 h1 starter problem? are they
Sounds like starter clutch is binding? Therefore turning starter while riding, then it will melt!
Sep 30, 2013 | Arctic Cat 2006 650 H1 4x4 Automatic SE
I have a arctic cat ATV 650 H1 2007 started it yesterday and it sounded boggy , almost like I my have fouled a plug , or have a small manifold leek , it runs and idles still pretty good , pulled the plug...
Diagnosing issues like this can be hard,, but, I would replace the spark plug(s) and see if it helps.. just because it looks good, doesn't mean its not fouled..Try this and reply to me...
Jun 18, 2017 | Arctic Cat 2007 Prowler 650 H1
What means h1
H-1. High pressure switch open. Check gas pressure/clean condenser coil/Check fan motor speed/Replace capacitor for defective.
Dec 17, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Santai TD-V26 Portable Mini Digital Speaker with Micro SD / TF / USB /FM - Green Logo
51 people viewed this question
Top Santai Computers & Internet Experts
David Payne
David Payne
Are you a Santai Computer and Internet Expert? Answer questions, earn points and help others
