Question about GE Monogram ZISS420NRSS 42" Built-In Side-By-Side Refrigerator (ZIS-S420NRSS, ZIS S420NRSS)
Water dripping and leaking from ceiling of freezer compartment
I have a GE Monogram 48" side by side refrigerator ZISB480D it is leaking water from ceiling of freezer compartment down back and side of freezer is there a recall or a fix I can do?
fridgetech
  • 473 Answers
SOURCE: i have a monogram zisb36drb that leaks in the freezer compartment
This can be fixed.  It's not a defect at all.  The drain is plugged.  I will warn you these are a pain the butt to get into so I would reccomend an experienced repairman to do the job.  You can expect to pay about $200 for this repair due to labor time.  Would appreciate a solved rating for expert advice.
Posted on Oct 18, 2007
Greg20
  • 149 Answers
SOURCE: I have a side by side GE Monogram. When closing
the refrigerator should be leaning back enough to allow it to reclose. there are hieght adjusters behind the grill on front
Posted on Jun 12, 2009
heatman101
  • 43501 Answers
SOURCE: GE Monogram Freezer wont defrost
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 31, 2010
  • 2468 Answers
SOURCE: GE Monogram won't freeze food
your evaporator coil in the rear area behind the panel is iced up and blocking fan air flow to the freezer compartment
Posted on Jul 25, 2010
heatman101
  • 43501 Answers
SOURCE: 48" ge monogram refrigerator not staying cold
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
sfjfg
Posted on Sep 29, 2010
GE MONOGRAM Icemaker: ice melts and re-freezes, resulting in a large frozen piece of ice in the bin
Are you sure icicles are coming from ice bin? Remove ice bin and look above it and see if they are coming from ceiling area of freezer. Side by side monograms have had problems with drains causing water to back-up into freezer. This causes icicles from ceiling. If that,s the case you have to purchase the kit for this. This is not an easy fix and can take a couple hours, even for a pro who's done it before.
Mar 06, 2014 | GE Monogram ZISS420NRSS 42" Built-In...
I have a GE monogram side by side refrigerator and water has started collecting in the "express chill" drawer at the bottom of the refrigerator side. It appears to be collecting in the "ceiling" of th
water into the fresh section or just on the floor around freezer or fresh food door. I also cannot take all credit for solutions in the area of refrigerators leaking water. Every person contributes their own experience so those that have should also be rewarded for their own efforts. I am pretty sure you are having a defrost by CouponDropDown">drain blockage problem. Most defrost every eight hours and over a period of time the drain line that comes down from freezer into a cup like object top middle and back of the fresh food section. If blocked by gunk or ice you will see trails of liquid leaking down the rear wall of fresh food compartment until it reaches the crisper drawers.This is not always the same with every model as you may see frozen ice flowing down ther rear wall of freezers on side by sides. Here is an example Click here=> Whirlpool Leak Photo taken by TechnicianBrian He has been around a good bit and deserves credit for his contributions. Here is another way to make this look more si mple in clip below. TechnicianBrian.com And in this photo are several parts listed in photo group #1 were it is most likely running down the wall=> MagicChef CTB1921AR fresh food section. If you still have questions please ask and rate me if I was able to explain this well enough. Every refrigerator is made different so these are examples only. The key is to find if ice or just gunk has blocked you defrost drain. Unplug and then remove the rear panel in back of freezer. We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the drain leads down back of your refrigerator. Much more on this page=> Leaking Refrigerators! This is a common tip so I will be placing this post and add as we go new ideas listed in Sea Breeze Tips Section. If you run into any problems along the way of repair please let me know, Thanks, Sea Breeze
Mar 31, 2013 | GE Monogram Side by Side Refrigerator
Approx 1996 model- Have been having water leaking into freezer- water line is shut off. Now the entire freezer compartment on top is a large block of ice and dripping down. Is it possible to shut the...
No, the fridge side gets it cold from the freezer. You can turn the freezer off and use a hairdryer to thaw it out and the fridge side won't loose much cold during that time.
Your water inlet valve may need replaced to fix the leak unless the leak is a hole in the water line.
Feb 05, 2011 | GE Monogram ZISS420NRSS 42" Built-In...
GE Monogram ZISW36DYA ... frozen ice-cycle rivulets run down both sides of freezer (water off for days to verify it is not ice maker) ... defrost control clicks when rotated and advances with time ... do...
Seems to me that might be a clogged defrost drain or maybe a dripping water valve. Doing that. I have the service manual with nice pictures in it that show clearly how to access the components.
GE MONOGRAM SERVICE MANUAL
Nov 10, 2010 | GE Monogram Side by Side Refrigerator
I have a monogram zis 42d side by side the freezer section works but in the defrost mode the unfrozen ice runs down the sides of freezer and into ice cube storage container, I have cleaned out the drain...
I have this same problem. Now, the freezer will not get cold enough, but still water runs down into the ice bin and just turns into a big solid block of ice. The water is dripping from the top of the freezer compartment. I have disconnected the water coming to the refrig to not allow it to make ice, but still happening. Please post if you have found a solution? Defroster issues?
Nov 09, 2009 | GE Monogram ZISx420DR 42-inch Side by Side...
GE Side by Side, water leak inside freezer door
you will need to [possibly replace the solinoid valves on the backdside of the refrigerator
Jan 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water Leak
Make sure the drip pan is in the correct position.
Dec 31, 2008 | GE Monogram Side by Side Refrigerator
I have a monogram zisb36drb that leaks in the freezer compartment
Oct 18, 2007 | GE Monogram ZISS480DRSS Stainless Steel
GE Monogram ZISS420NRSS 42" Built-In Side-By-Side Refrigerator (ZIS-S420NRSS, ZIS S420NRSS) Logo
108 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
