Question about Sewing Machines
Bernina virtaousa 155 makes a puffing noise while sewing
While I am sewing my sewing machine will make a sound kind of like a puff, not like every so many seconds but randomly; At first it did it every once in a while mow it is quite often. Could my problem be electrical or something slipping, do you have any suggestions.
  • 202 Answers
Hi Mary, I suspect that the noise your hearing is the bearing on the belt tensioner. Like a woosh woosh sound. It is quite common and usually one of the first things I look at when servicing a machine like yours. Under the handwheel inside there is a tensioner with a bearing that turns against the belt. Over time this bearing gets build up in it, mostly rubber from the belt. This tensioner needs to be removed, the c-clip popped off and then clean and oil the bearing part and reassemble.
Its really not a task I would suggest doing yourself. A servicing is in order and if you have this done, specify this part, as sometimes it gets skipped in the process.
In the mean time its not really anything to worry about unless that bearing seizes up which you will notice bigger problems.
Good luck
Posted on Jan 21, 2009
My bernina aurora 440 sewing machine is making a high pitch humming noise when I turn it on
These machines do make a noise during start-up, but if it stops after the sewing machine has gone through the set-up, it is probably okay. However, if the noise continues, it should probably be taken for a check-up. Even so, if you are worried, a check-up may still be helpful.
Feb 12, 2017 | Bernina Sewing Machines
How do I change the light bulb in my Bernina Virtuosa 155 sewing machine?
Remove light cover on left side with torque wrench then just pull the bulb downward be sure to replace with a bulb of correct wattage
Aug 07, 2014 | Bernina Sewing Machines
Bernina 140 which has a sqeak in its Handwheel How do I fix it
it's sounds like the machine needs to be serviced when they start sqeaking or making odd noises
Mar 06, 2012 | Bernina Activa 140
I have just bought a new bernina 440QE - it makes a loud noise when turned on, which gets louder when you increase the sewing speed - I have a 240 which runs much quieter - is it a fault or is it normal?
That is a great machine, should sound realy good. Should sound just like a 240. Are you lubricating the hook (that is important with the 440). If that does not help I would take it in.
Apr 05, 2011 | Bernina Sewing Machines
I have a Bernina Virtuosa 155 and use it daily. Without
In checking I can either adjust the tenion screw and if that does not work, purchase a new bobbin case.
Oct 27, 2009 | Bernina 1008
Sewing Machines Logo
53 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
