The washing has not fineshes, the machines switchs off but there is still water in the drum
  • 15,935 Answers
There is a water pump in the machine which pumps the water out of the outer tub and into the drain, after the wash and rinse cycles.
It is possible that this pump isn't working properly. I think if it weren't working at all, you wouldn't be able to get beyond the wash cycle.
It has been my experience that small articles of clothing may get washed or spun out of the inner tub and into the area around the pump pick up, thus partially blocking the flow to the pump.
It's also possible that the drain hose from the pump to the drain may be partially clogged.
It is also possible that the pump doesn't run sufficiently long to get all of the water out because its' motor gets hot and shuts down or because of a problem in the control mechanism which manages the the starting and run time of the pump.
First, I would unplug the washer from the wall outlet and probe under the inner tub, or possibly remove the tub to see that there is no blockage from clothing.
It's also possible that things left in clothing pockets like paper clips, small plastic items, etc. can get into the pump and lock up the impeller.
If you're sure it isn't blocked you can then run a "short cycle", no load and water only, and watch to see how much water comes out of the discharge hose where it's hung on the drain pipe.
It should gush out, and tub should be free of standing water prior to the start of the first rinse cycle.
If it does not, then you'll have to access the pump and clear it of obstructions or replace it, if defective.
As it drains, it should start spinning slowly, then speed up as it drains; the final portion of the spin cycle is very fast.
Essentially, the spinning tub wrings out the clothes using centrifugal force.
With the water remaining in the bottom of the tub, it would appear that it is:
a) not spinning long enough, or
b) there is something preventing all the water from getting out in the time allotted by the timer to perform this task.
A fair handy man can get to pump either from the rear of the machine with back plate off, or by removing the cabinet cover from the frame, depending on the model of the the machine.
As always - before attempting any repair, UNPLUG THE UNIT!
When clothes are wet at the end of a cycle, check these:
Motor coupler
To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
If it's spinning when you lift the lid, the coupler is fine.
If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve
Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
The cold water continues to fill the tub and not shut off
There is a pressure switch fitted to all washing machines.basically a tube outside the drum that has air inside it which responds to water going into the the air in the tube compresses it activates the switch to shut off the water and sends a new command to controller board to turn the drum and start washing.when it doesn't switch off tells me that the tube has too much water in it and won't shut off can locate the tube and empty it so it just has air in it reconnect and see if that fixes it.if it doesn't then next place to look is the switch itself and controller board.
Dec 23, 2014 | Washing Machines
Frigidaire affinity washing machine E30 error message
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
Nov 12, 2013 | Frigidaire Affinity ATF7000E Front Load...
Washing machine will not stop filling up with water
Is the machine siphoning off water as it fills? If it is check the height of the drain hose and make sure it is above the height of the normal level of water that would be in te drum when washing, if the hose is to low the drum will siphon off the water on its own and continue to fill. If the machine is not siphoning off water while filling then you may have a blocked pressure hose or the pressure hose bottle may be blocked not allowing the pressure switch to activate. there may even be a small hole in the pressure switch hose. Check the thin pressure hose that goes from the bottom of the drum to the pressure switch.
Dec 27, 2012 | Indesit W 123 Front Load Washer
Lg outer drum leak
Basically you need to open the water tap with the washing machine off. If water still flows in, then your water inlet valve has to be replaced. If the level continues to rise and does not switch off, then either there is a leak in the pressure switch pipe or the pressure switch is defectiv(very rarely) or their is a blockage in the hole entering the brum onto which the thin pressure pipe connects.Either of these could be the problem.
Jun 24, 2012 | Washing Machines
Zanussi zwf 1221 will not turn drum, the end light flashes the water goes into the drum and drains out when a program is selected but the drum will not turn at all. You can turn it by hand and it moves...
you need to check the pressure switch inside the washing machine there a small hose connected with the pressure switch to sense that the level of water inside the drum is ok if this hose blocked the machine will not run
Oct 10, 2011 | Zanussi ZWF1430W Front Load Washer
My haiser washing machine keeps filling up with water when it should stop when enough water is in the drum
It sounds like you have a bad pressure switch. There should be a tube that goes from the drum to a switch that tells the machine to quit filling. If that switch works then the board might be bad. Hope this helps.
Apr 07, 2011 | Washing Machines
Normally the machine used to start after taking required amount of water. Now the machine starts only after the whole drum is completely filled with water making it difficult to turn. Even later when it...
Washing machines stop filling when water pressure from the bottom of the tub goes up a plastic tube and into the water level switch. If the tube is obstructed with debris or anything foreign, the switch will fail to stop the water from overfilling. It is possible that the switch is defective, of course. Check the tube for obstructions, kinks, or a loose connection.
If it is the switch, have your make and model handy and look up the part here:
Good luck.
Mar 03, 2011 | Washing Machines
Water will not stop filling
Not a lot to go on from your description, but most times this is because the small pipe connecting the drum chamber to the pressure switch has become blocked due to either dirt / fluff / soap scrum, or a combination of these. The pressure switch measures how much water has entered the machine by way of water pressure - the more water in = greater pressure.
To find this pipe you will need to dismantle the machine enough to see the pressure switch, the connecting pipe, and where it connects to the drum chamber. Pull off the pipe and check for blockage in the pipe, the connection to the drum chamber, or in really sever cases, the switch.
A manual would be a great help, most popular models are covered by the Haynes washing machine manual, but even if the exact model isn't, it can still give enough info to get a machine apart.
Sep 06, 2009 | Whirlpool Washing Machines
My zanussi 1400xc washing machine won't start its cycle. The lights are all on in the correct settings, but the start button continues to flash and wont start the cycle. I have cleaned the...
unplug for 40 minutes to reset the ECU. If still doing the same - replace the ECU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 16, 2009 | Washing Machines
Washing Machine Hoover H100M fills too much water in the drum.
this is 1 of 2 solutions  2 this problem the first thing to check is the vacuum system or it is a split in the pressure switch hose
Mar 05, 2008 | Hoover AAA140 Front Load Washer
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
