Question about Canon PowerShot SX130 IS Digital Camera
Canon a2300 busy message - Canon PowerShot SX130 IS Digital Camera
How to restart you canon powershot A2300 camera
Do you mean re-set? Re-starting is a child's game and if you don't know how to do it, you may as well not try to use the camera!
Dec 20, 2013 | Canon PowerShot A2300 16 Megapixel Digital...
My camera is canon a2300 power shot i buy this new camera ok and every thing in camera is ok the problem here its when install this camera on my pc not working i have windows xp SP3 so what the problem...
Do you really need to connect your camera to your computer?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Canon ZoomBrowser or Picasa ( http://picasa.google.com ).
Aug 07, 2013 | Canon PowerShot A2300 16 Megapixel Digital...
New camera, Canon PowerShot A2300, I have not used it, yet. Just placed the new battery in after I charged it, and I put in the San Disk 8GB SDHC Card, and the camera says "memory card error". I ca
Normally, you can only insert an SD card one way. Try a different SD card or check to see if the SD card you're using has the "write protect" switch on. If that's not the issue try formatting the card in your PC and then format it in the camera.
Mar 05, 2013 | Canon PowerShot A2300 16 Megapixel Digital...
I have the Canon Power Shot A2300 and can't find in my book how to put my pictures in a folder and than how to email them. Help
You may download the manual from here.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Once the pictures are on your computer, you can move them around and email them the same way as with any other types of files.
Dec 21, 2012 | Canon Cameras
Unable to connect Powershot A2300 camera to computer through USB port.
You might want to consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Canon ZoomBrowser or Picasa.
If you do want to connect them, use the supplied USB cable. Plug one end into the camera and the other into a USB port on the computer.
Nov 05, 2012 | Canon PowerShot A2300 16 Megapixel Digital...
Canon PowerShot SX130 IS Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
