Question about Canon imageRUNNER C6800 Copier
C6800 error code E000020-01a9
Have attempted to change out the yellow toner and error code persists. can not reset toner levels to indicate full level. When this error appears the next step is to power of then on the unit.
  • 23 Answers
I don't have the manual for this machine, but if Canon is consistent then you problem is a fuser unit (the device that melts the toner to the paper) that is not heating up for some reason.
Possible causes are:
Blown fuser lamp
Defective thermistor
Defective AC Driver Board
Posted on Apr 20, 2009
WorkCentre 7245. What does error code 009-380 indicate?
That error indicates the yellow atc sensor detects a low toner concentration. Try clean atc sensor and reset value to 0.
Nov 06, 2015 | Xerox Office Equipment & Supplies
How do I fix cannon image runner e 000019-0000?
DEAR
its indicating the waste toner full. Get clean the waste toner box and reinsert it. If problem persists then the clean/replace the waste toner sensor. Check the harness of this sensor to DC CON board.
Thanks.
Jan 28, 2015 | Cannon Office Equipment & Supplies
The machine has been stopped and show error code E000013-0001
this is explaining on the book
e000013
-0001 The PLL lock isreleased because waste toner motor is locked up, etc.-0002 The micro switch employed to detect clogging of waste toner isactivated.
-0003 The waste toner case is detected full
May 30, 2011 | Canon imageRUNNER C6800 Copier
Error code 19
E019
Indicates that the waste toner case is full.
Thereafter, if the waste toner case is not replaced after making a total of about 2000 prints
(A4/LTR), the machine will indicate 'E019' on the control panel; the error code can be reset
by replacing the waste toner case and then turning off and then on the power switch.
If the waste toner case is not set, the light-blocking plate will block the light between the
photosensors, causing the Waste Toner Case Full message to appear.
Feb 04, 2011 | Canon imageRUNNER 2200
Error code E000013-0001
getfile.asp?rid=1258 February 2, 2005 getfile.asp?rid=3215 Product : imageRUNNER C5800 / C6800 Title : E013 code and Waste Toner Full message Question :
The copier shows an E013-0001 and "Waste Toner Full" message. The Waste Toner Bottle has been emptied and SW1 is operating properly but the code and the message are still appearing on the display.
Answer :
The counter for the Waste Toner Bottle needs to be reset back to zero in Service Mode.
Enter Service Mode level 1 by pressing * 2 8 *, select Copier > Counters > MISC, then highlight WST-TNR, press Clear - the counter will zero out.
Power off the copier, turn the copier back on, the Waste Toner Full message on the display should clear out.
Canon USA, Inc. Systems & Technical Support Division 1-800-528-2830
Dec 22, 2010 | Canon imageRUNNER C6800 Copier
Please help e0020-00ff black toner supply????? comes and goes
Check for blockage in toner supply ,located at rear of hopper. Also is the toner ok
Jun 26, 2010 | Canon imageRUNNER C6800 Copier
Washer won't fill or start cycle fault codes indicate pump failure. Changed the pump but problem persists
Seems that the controller thinks your machine is full of water. Water level pressure sensor may be sticky. May be blockage down air line to pressure sensor - try blowing into sensor end to clear.
(Always disconnect from power before attempting repairs).
Feb 28, 2010 | Kenmore HE2 Plus Front Load Washer
Hi, can you please tell me what error code E000751-1301 is on a canon clc 3220, thanks Jane
E751, 1301 means there is an issue with the toner system. The machine is checking for the presence of toner. After 3 attempts the machine will go into the error. In this case, the yellow toner tube needed to be replaced even though the machine did not indicate to do so. The color that is causing the issue is the first digit in the sub code.
Oct 13, 2009 | Canon CLC 1150 Color Copier
Toner Replacement
The cyan and magenta go into the machine through the same aperture as the yellow toner cartridge. The machine will automaticaly rotate the toner turret to the correct position when toner replacement is necessary for that particular cartridge.
Nov 14, 2006 | Canon imageRUNNER C6800 Copier
Canon imageRUNNER C6800 Copier Logo
467 people viewed this question
old marine
old marine
