Question about HP Mini 1000 Netbook
My hp mini 210-1000 boots up well both on battery and adapter but it displays faintly on battery while it display well on power adapter
The laptop powers up on battery but displays faint screen, However, it displays correctly on AC adapter
  • PABLOW Jan 10, 2013
    The system power up fine on AC adapter but as soon as I unplug the adapter, the screen goes blank with a very faint display. If i power it on a battery alone, it will startup on a blank screen with faint display. It only displayed well on AC adapter.
The problem is that its set in the power saving options. i mean on battery its set to power saver . while on power adapter it changes to hp recomended or high perfomance. So if you want to change it go to the right bottom of your screen and click the battery symbol it should give you the option to 1> change screen brightness 2>more power options. Go to more power options and select "change plan settings" beside the power saver.(not the one beside the other options) and change ur brightness. but its always better to keep it at ur minimum(with what ur comfortable) as its helpful to save battery
Posted on Jan 10, 2013
Testimonial: "Tnx. I reset to default setting and the problem is gone"
  • HP Master
  • 32,281 Answers
Laptops reduce the brightness when on battery power to conserve battery power. You can still adjust the screen brightness, the brighter the screen the less battery life you will have.
map9966
  • 2351 Answers
SOURCE: Toshiba M115 S3094 Battery Probelm
Your battery not able to hold a charge is a bad battery.
Love your precise description & diagnoses. Wish others would describe their troubles as well as you!
Have a great day!
Posted on Mar 14, 2008
SYSTEM ONE
  • 85 Answers
SOURCE: Hp Pavilion dv1000 Black screen
It is either the inverter board or the bulb
If it looks pink in color than it is the bulb and that can be quite the intensive project to replace
If it is the inverter board than that is not so bad and you can pick up an inverter board on eBay usually for around $10 to $20 and that usually installs right under the LCD screen (usually screwed to the LCD screen)
The inverter board is what powers the light bulb the data cable is totally separate function.
If you can see data on the screen with a flashlight but there is absolutely no light coming from the screen at all ever than it is probably just the inverter board
But there is a possibility that you could order the inverter board and have it turn out to be the bulb and if that is the case then unless you are very comfortable taking apart laptops then maybe a new screen would be best since you practically have to take apart the LCD to change the bulb.
But screen cost around 100 to 150 on eBay so if you decide to do that then might as well try for a deal like this: (I just spotted this on eBay and it is for entire new top half of laptop with glossy screen and inverter board wire harness and all for the same price or less than just the screen http://cgi.ebay.com/HP-dv1000-Pavilion-14-1-BrightView-Glossy-LCD-screen_W0QQitemZ310102538774QQihZ021QQcategoryZ31569QQssPageNameZWD1VQQrdZ1QQcmdZViewItem#ebayphotohosting
That is guaranteed to solve your problem for sure.
Posted on Nov 25, 2008
pontelemon
  • 531 Answers
SOURCE: laptop wont boot and the battery and power lights flash
"......no beeps and it is a 3rd party charger for this model of laptop."
That 3rd party adapter could be the problem. Also, try to take out the battery and power it up from AC adapter only.
Ideally, try to find original AC adapter just for testing.
Posted on Apr 16, 2009
  • 922 Answers
SOURCE: HP Pavillion dv2500 laptop will not boot up.
Pressing the f8 key doesn't work either? This should boot the laptop to safe mode, if it doesn't then check the memory cards before you do anything else, try to get somebody with the same type of memory card to lend it to you. If that doesn't work, then your HDD is corrupted, and to re-install Windows.
Posted on Sep 05, 2009
Geekman
  • 32281 Answers
SOURCE: HP Pavilion dv9700t battery dead, faint blue flash from plug
Check your mains adapter plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Posted on Oct 18, 2009
What will i do to my hp mini notebook it has a power but it cannot booth
Perform a Hard Reset Do these actions first to clear all temporary setting before troubleshooting the problem.Disconnect all peripheral devices and remove all USB devices and media cards.Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds to drain residual charge.Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.Perform each recommended corrective action and then attempt to restart the computer.Symptom 1: LED lights do not glow, display is black, no fan or drive sounds are heard, and computer does not startIf LEDs do not glow or blink when AC power adapter is attached and power button is pressed, there is no power available to the notebook Check AC adapter wiring and power connection to the notebook Connect a different AC power adapter and remove battery, then restart notebook.Connect a different battery and disconnect AC power adapter, then restart notebook Symptom 2: LEDs blink or computer beeps but does not start Blinking LEDs or beep tones indicate a hardware failure during the pre-start up testing Count number of blinking LEDs or beeping tones to help with diagnostics testing Symptom 3: LEDs glow, fan noise may be heard briefly, display remains black, and computer fails to startup or boot Usually occurs if a component is installed incorrectly, or there is a device conflict or failure Connect an external monitor to check if the problem is the built-in LCD display or graphics card Remove all CD/DVDs, SD cards, USB devices, peripherals and do a Hard Reset If memory or hard drive components were replaced, reinstall original component Remove memory modules and replace one-at-a-time Remove and reseat hard drive If possible, turn on power, press F10 to enter BIOS mode, and run Memory Test and Hard Drive Test On newer notebooks, turn on power, press Esc to enter UEFI mode, and run Memory Test and Hard Drive Test If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Repair Computer option, or enter Safe Mode and run Memory Diagnostics If all other methods fail , but computer can boot to BIOS, use recovery disk to recover the computer to original condition Symptom 4: Computer may display an error message on a black screen during startup or boot Search www.microsoft.com for terms in error message Search www.hp.com for terms in error message
  • If possible, turn on power, press F10 to enter BIOS mode, do the corrective actions listed under Symptom 3 to run memory and hard drive tests.
  • Symptom 5: Computer displays a blue screen or continually re-starts After an error message is displayed, you can usually bypass the error and continue to run the notebook in Safe mode to install an updated BIOS or driver.
    • Search www.microsoft.com for terms in error message.
    • Search www.hp.com for terms in error message.
    • If possible, turn on power, press F10 to enter BIOS mode, and run diagnostic Memory test and Hard Drive test .
    • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and do one or more of the following:
      • Select Disable automatic restart on system failure to view error message.
      • Run Repair Your Computer .
      • Run Last Known Good Configuration .
      • Select Boot into Safe Mode and then select Run a Microsoft system restore .
      • Select Boot into Safe Mode and then select Uninstall recently installed programs .
      • Select Boot into Safe Mode and then run Windows Update .
    Symptom 6: Computer displays the Windows logo screen and stops responding If no error message displays, turn on power, press F8 to enter Windows Advanced boot options ,and select Disable auto-restart to view error message.
    • If possible, turn on power, press F10 to enter BIOS mode, and select Restore the BIOS defaults (F9) .
    • If possible, turn on power, press F10 to enter BIOS mode, and run Hard Drive Test .
    • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Last Known Good Configuration (Advanced) . .
    • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Boot into Safe Mode and then Uninstall recently installed programs .
    Update Computer After Resolving A Problem When the computer starts into Windows normally, you should install the latest updates and patches to prevent other start-up problems.
    Oct 09, 2011 | HP Mini 1000 Netbook
    HP Pavilion dv6-3007tu
    what exactly is your problem? will it not start?
    Jul 25, 2011 | HP Pavilion dv6-1122us Notebook
    Recently tried to power computer on and computer tries to boot up but screen will only show colored lines. You can see faintly behind lines are icons like computer is trying to turn on. When shut down you...
    Hello.
    I'm not certain if a power issue or graphics / display issue.
    If a power issue, the most common reasons are the battery, power jack and power adapter/cord.
    Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
    If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
    The power jack is inside the laptop and either needs soldering or replacement.
    If no change, the power adapter is probably faulty and needs replacement.
    If a display / graphics issue, connect an external monitor to your laptop. If an external monitor works, it is the display's backlight or inverter board.
    If you were experiencing discoloration in the screen (pinkish lower light hues) before it failed, that would indicate a CCFL backlight issue. If the screen suddenly went dim on you rather than a slow degradation, the inverter would be indicated.
    In either case, a technician in your area should be able to help. Evaluate to see if the repair is cost-effective.
    It's also possible that your graphics card is faulty and needs to be replaced.
    Hope this helps.
    Feb 27, 2011 | Compaq Computers & Internet
    Pavilion dv7-1174ca -- Plugged in, not charging. Upon initial boot, there is a CMOS message stating that the storage capacity of this battery is low. After boot, I ran the HP Battery Health Check,...
    First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
    If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
    If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
    If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
    Sep 24, 2010 | HP Pavilion dv7-1468nr Notebook
    BLANK SCREEN ON MY hp compaq nx9420. my laptop was working fine and then when restarted I got a blank screen. The power LED and cahrging LED both light up but screen remains blank. have changed the video...
    Did it display any video at all with boot options or HP logo? Any POST test or beeps after you started the laptop?
    Try removing the power ac adapter and battery. then only boot it up with just the AC adapter (no battery).
    Good Luck, JAJ
    Mar 30, 2010 | HP Compaq nx9420 Notebook
    Repair manual for HP Pavilion dv6 1245 dx
    Go to hp.com. Click on support and drivers tab. Select "See Support & Troubleshooting Information." Enter your laptop model number. dv6-1245dx. Click on "GO". See: "What Type Of Support Do You Need?" Choose MANUALS. Scroll down the page and select "HP PAVILION DV6 ENTERTAINMENT PC - MAINTENANCE AND SERVICE GUIDE". Download that PDF format. It is relatively easy to get to the ribbon cable that connects the touchpad to the motherboard. It is connected via a ZIF connector. I had a dv1331se and the touchpad stopped working. I just reseated the cable in the connector and all was well. Hope your solution is as easy as mine was. You'll have to remove the trimplate just in front of the keyboard. Be careful with the connectors there. The manual is well laid out and the diagrams easy to follow. Good luck. HP Pavilion dv6 Entertainment PC - Maintenance and Service Guide
    Mar 16, 2010 | HP Pavilion dv6000z Notebook
    Toshiba A105 will not boot up even with cd and f12
    its not a booting issue if you hear the music, it loaded windows. you might have a display issue, shine a light on it to see if you can see any faint images, if you can the backlights out if not it might be the display adapter on the MOBO, in either situation calling toshiba would be required for a repair, or otherwise take it into a shop, but first try a power reset,
    unplug it and remove the battery, then hold the power button down for one minute, replace the battery and power cord and try to boot again. if this fails call toshiba, its definately a hardware issue.
    Jan 23, 2009 | Toshiba Satellite A105 Notebook
    No display on V3000
    The LCD requires alot of power so if your battery does not have enough juice in it
    the computer just starts up the things that don't use as much power.
    I would purchase a new battery and it will rectify what's going on.
    Happy Holidays
    Dec 19, 2008 | HP Compaq Presario v3000z Notebook
    Power
    Try this:
    With the AC adapter and battery installed and it will not power up remove the adapter and the battery. Then plug in the
    AC adapter after both have been removed for 30 seconds and let the laptop set for 30 seconds and then unplug the AC adapter and then slide in the batter within 15 seconds and try to start the laptop.
    Nov 24, 2007 | Compaq Presario 900 /1500 Series EVO...
    Desk top won't display-hibernation mode
    Based on your post of failure to boot due to hibernation, you can try removing the battery and AC adapter connection for an hour or so. Thereafter, insert battery back and charge but don't power up. Allow the laptop to charge for a couple of hours. Try powering up/booting. Press F8 to start in Safe Mode. Once in Safe Mode disable Hibernation.
    If the laptop still fails to power up, then it may be entirely another problem.
    Post back results. Good luck and kind regards.
    Nov 04, 2007 | HP Pavilion dv4000 Notebook
    HP Mini 1000 Netbook Logo
    190 people viewed this question
    Top HP Computers & Internet Experts
    Tony
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
