Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
STYLUS PHOTO RX420
In copier mode, only prints out half the page; ie one side
  • Epson Master
  • 419 Answers
I've had a look at the user manual (which was very vague) but found that under the "Product Information" > "Control Panel Functions" there's an option to have A4 or 10x15cm sized paper output on the printer control panel. Make sure that the A4 selection is lit before you copy.
Hopefully that will help resolve the issue.
Posted on Jan 23, 2009
I have an epson Stylus photo RX420 and have downloaded SSC Service Utility V4.30 to resolve issues with flashing E and Service lights etc. The problem is that the Epson Stylus Photo RX420 does not appear...
Yes, it is. Select CX4600(4500)/CX36x0(3500)/RX42x(430)/PM-A700.
RX42x covers RX420/RX425.
Minimise to tray, click on icon in notification area and select protection counter - reset protection counter.
Its there for a reason mind, so replace or clean the overflow sponge first!
Jul 04, 2009 | Epson Stylus RX425 Multifunction...
My epson rx420 only prints the left hand side of any document ??? Can any one help please . many thanks
have you set the page setup in document is same with page setup at print setup. Some new epson printer use paper sensor to measure the paper width. If page setup wider than actually paper inserted, the printer will print only half page. example : Your document 10 cm wide, page setup 20 cm, and you insert 10 cm paper wide. It will print only half of 10 cm, 5 cm.
Jun 09, 2009 | Epson STYLUS R230 InkJet Photo Printer
Only one half of page prints.
My suggestion would be to totally un-install the printer and erase all traces of the driver(s). Search for them after the un-intall and erase them manually.
Re-install the printer and driver...reboot if nessasary...align the print heads...do a test pattern...then try and print your document. It might just be a corrupted driver...some would suggest just installing over the existing driver...but I've found doing it that way gives you the best chance of it working the first time.
Apr 24, 2009 | Epson Office Equipment & Supplies
Lost my starter discs for my printer epson stylus RX420???
epson stylus photo RX420 DL Link:
Epson web support Drivers and Software win XP:link
Mar 20, 2009 | Epson Stylus RX425 Multifunction...
SCANNER WON'T SCAN OR COPY PROPERLY
Try deleting the printer, dissconnect the usb from the computer, reboot.
Install the driver from the CD again and follow directions which will tell you when to connect the printer.
See if this works.
Do NOT connect the printer till you are instructed to do so.
Feb 02, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson stylus photo rx420
Move envelope/A4 lever near paper output tray until the letter L registers on display. Print in this mode and you should have full page printed.
Jan 21, 2009 | Epson Office Equipment & Supplies
Epson stylus rx420 prints only right hand side of the page
the paper was not going in straight, I packed the tray with lots of paper and adjusted the paper lever tighter. Goes nicely now.
Jan 17, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson rx420 printer
Another post suggests that you printer is dead -see (http://www.fixya.com/support/t354202-epsom_rx_425_just_prints_half_page) but I've had the same problem - things seem to be ok after I reset to the defaults in the main page of the printing preferences.
Mar 03, 2008 | Epson Stylus RX425 Multifunction...
Epson Rx420
Click Start - Printers and faxes
Right click on the printer icon and select properties.
Click on Advanced tab. Enable the option print directly to printer.
Click apply n OK.
Check for the result.
Dec 22, 2007 | Epson Stylus 1400 InkJet Photo Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
88 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
