Question about Soundstream VR-931NB Single DIN A/V Source Unit w/ Detachable 9.3 LCDBluetooth 3.0
Orange wire on vr-931nb
What is the orange wire for
I have all the wire hooked up corrected by color but my power acoustik 931NB still wont power on what couldve I dont wrong I havent blown a fuse when I hook up the stock radio it works fine.....
Sorry we have no info on aftermarket audio installations. I do know that you can't replace the radio/audio systems on newer cars as it is tied into the on board computer system.
Mar 24, 2016 | Cars & Trucks
Brand new will not accept any Discs, Why?
Dirt on the lazer lens or if you are talking about DVD discs the wrong region code being set on the machine.
Apr 17, 2015 | Power Acoustik PD-931NB
Why calibration want go off my screen of my radio power acoustik model 931nb
Your model must be PD-931NB.
If you do not have the manual you can download this from this site.
http://www.poweracoustik.com/pa2012/manuals/PD-931NB.pdf
I am assuming you are following the calibration procedure on page 40 of the manual. (refer page number printed at bottom of pages).
As this is to do with touch screen calibration, the most likely cause of the message coming up is a dirty screen. If cleaning display is not helping then the touch screen circuit is faulty.
Sep 01, 2014 | Car Audio & Video
POWER ACOUSTIK PD-931NB won't turn off when my car turns off
It is miss wired to power instead of the switch that turns off the car.
May 08, 2014 | Car Audio & Video
Lock lens aperture ring at minimum aperture
Turn the aperture ring on the lens to its minimum setting (largest f/number). If there is an orange slide on or near the ring, slide it so that the aperture ring doesn't turn.
May 02, 2014 | Nikon D3000 10.2 Megapixels SLR Digital...
E7 error message
see this steps and fix it. God bless you
ERROR CODE # 7
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Nov 27, 2012 | Exercise & Fitness
I need the connection wires!
This uses regular speaker wire. Go to Best Buy, Radio Shack, or any electronics store and ask for speaker wire.
Oct 04, 2009 | Kenwood VR-507 Receiver
New vr-3 going into used 2004 Status. Current wiring has black connector and grey connector, also one blk/yellow stripe wire. Have wire colors written down, need to know what existing wires are -new radio...
According to www.the12volt.com The color codes for your vehicle are:
RADIO 12V CONSTANT |orange/black
RADIO SWITCH (ACC)|white/black
RADIO ILLUMINATE|green/white
LF SPEAKER|wht/blu - blk/blu
RF SPEAKER|wht/red - blk/red
LR SPEAKER|yel/blu - gry/blu
RR SPEAKER|yel/red - gry/red
Feb 24, 2009 | Clarion VRX935VD Car DVD Player
Vt Holden Commodore stereo wiring diagram
Here are the wiring codes for the VT,
VN-VT Commodores:
Accessory (12V) Yellow
Battery (12V) Orange/White
Ground (earth) Black/White
Antenna power (12V) Yellow/Red
Front Left + Tan
Front Left - Grey
Front Right + Light Green
Front Right - Dark Green
Rear Left + Brown/Black
Rear Left - Yellow/Blue
Rear Right + Blue/Orange
Rear Right - Blue/Black
Antenna Up White (VR-VT)
Antenna Down Blue (VR-VT)
Phone Mute Yellow/Black (VT)
Dimmer In (12V) Brown/White
Dimmer Out (12V) Grey (VT)
May 18, 2008 | Car Audio & Video
VR-206 - how to wire in equalizer
your vr-206 have several inputs dvd, vcr, tape decks, turn tables etc, also have an opcion called eq in and out usually if you dont have an equalizer al you do is jump straight rca to rca cables red in to red out and white in to white out.
but if you have an eq all you do is output from amp vr-206 to input and the input to output back to the amp
Dec 22, 2007 | Kenwood VR-209 Receiver
Soundstream VR-931NB Single DIN A/V Source Unit w/ Detachable 9.3 LCDBluetooth 3.0 Logo
Top Soundstream Car Audio & Video Experts
Matthew Spark
Matthew Spark
Electro Med Services...
Are you a Soundstream Car Audio and Video Expert? Answer questions, earn points and help others
