Question about E-Machines Computers & Internet
Clock resets to Jan 1, 2008 everytime you shut the computer down
CMOS error comes up but only if the computer is shut down for a period of time.
  • 21 Answers
Your CMOS battery needs to be replaced. It's a round and flat silver battery found on the motherboard, it's 3V.
Posted on Jan 21, 2009
My D 630 Win 7 laptop periodically resets time & date to the last manual setting? Is there a fix?
Not too difficult if your a member of the computer Dr mobile pc Dr's in black n white volkswagons. But it is the battery on the mother board
it should be 3.0 volt lithium watch battery 2016. Battery is dying an not holding its tsr programs on the cpu an reseting to defualt cmos
changing battery's information onyoutube based on your pc cabinet and its model and serial number. They'll play start to finish end user information on issues listed by steps
Aug 26, 2014 | Dell Computers & Internet
Computer clock resets to 1 Jan 2002 when I switch off? How do I reset the BIOS to default?
When you get the BIOS POST screen you need to press either "f2" or "Del" then look for the "Default setting" selection. The chances are that the cmos battery has failed. a new one is very cheap and easy to fit. It about the size of a Quarter or a ten pence piece. Good luck.
Jul 19, 2012 | Foxconn Computers & Internet
Macbook pro resets every time it runs out of power
Your laptop contains a small battery (aside from the regular battery) that saves CMOS information like time/date and a few other settings.
When your computer loses all AC/battery power, the settings are reset to factory.
You'll need to replace this battery, normally it is a regular disk battery that can be purchased at any hardware store.
If you're not tech savvy, you can have a professional technician open up your macbook and it won't cost much more than $100.
May 16, 2012 | Apple aluminum 13-inch MacBook laptop-...
Hi, my desktop pc problem is the CMOS clock. i already put the new battery on it. when i shut down my PC and open it for the next day, the CMOS clock turn back to zero count. i already save it after i...
Nothing happened to it. Try resetting the CMOS jumper
>turn computer off
>look for a 3-pin jumper that looks like this
>take that plastic thing that connects two pins and turn computer back on
>allow the computer to load windows
>shut the computer down properly
>put the plastic back TO THE EXACT PINS where to took it off from
>turn computer back ON and set regional settings, time, region, etc...
Sep 15, 2010 | Computers & Internet
Booting problem
There are usually three main reasons that a CMOS Checksum Bad Error has occurred. They include:
  • CMOS Battery may not be functioning properly. The battery life may have expired.
  • Your BIOS may have been updated (either by user or possibly a virus)
  • The computer may not have been shut down properly e.g. shutting off the computer's main power without first shutting down the computer (MS Windows requires you to shut down your computer before shutting off the power).
Solutions to CMOS Checksum Bad Error The CMOS Checksum Bad Error can be fixed easily by following the listed steps carefully.
If you suspect that your CMOS battery is not functioning properly, you can easily change it. Before changing your battery, reboot your computer to make sure that the error still exists. If it does, go into your CMOS and write down all of the settings. If all the settings are lost, you can usually retrieve them from your computer manufacturer. Now locate the battery and remove it, you might need to consult your computer’s manual or technical support to remove your battery (the battery a flat, shiny silver colored and coin-shaped). Take down the CMOS battery’s information such as volt, size, etc. Once you have your new battery, you can replace it and reenter your CMOS settings. If your battery was the cause of the CMOS Checksum Bad Error, you should have solved the problem.
If your BIOS have been updated recently, your CMOS settings may have reset. Make sure that the values entered in the BIOS are correct or simply reset them to the default settings. If you believe that a virus has updated your BIOS settings, run a virus scan and make sure that the BIOS settings are back to the default.
The Computer may not have been shut down properly
Sometimes when running MS Windows, if you shut down your computer without first properly shutting down your operating system, it will corrupt the CMOS settings causing the CMOS Checksum Bad Error. You can easily avoid this error by making sure that you completely shut down your computer properly before turning off the main power. Usually this entails going into the Start Menu, clicking on Turn Off Computer/ Shut Down. If improper shutdown was the cause of the error, you may have solved the issue
Mar 05, 2010 | Microsoft Windows XP Professional With...
Where isw the cmos battery
it's inside the computer, it's a small round, flat, silver battery similar to those in watches and tons of other devices. It stores the clock time when the computer is shut off. You will need to take apart the laptop carefully in order to get to it. Is your clock getting reset everytime you turn it back on? Then yes you will need to replace the battery.
Jan 21, 2010 | HP Compaq Evo n610c Notebook
Everytime i boot up dos gives me a clock error and ask 2 go 2 set up or press enter 2 continue so when i continue it boots up but my time keeps reseting 2 jan 1st 2000 12:00pm
It's asking you to go to set up to enter the correct time in the BIOS also when rebooted make sure your time zone is set correctly
Sep 02, 2009 | IBM ThinkPad 600 E Notebook
Error 161 and 163
any error like this is a dead giveaway youre cmos is dead.
Its a really common problem.
Mar 25, 2008 | IBM ThinkPad 600 E Notebook
BIOS Clock Error
Update the BIOS or CMOS it should be fine after that.
Sep 09, 2007 | Compaq Presario 1275 Notebook
Computers & Internet Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
