Question about HEWLETT-PACKARD M1212nf All-In-One Laser Printer
No strings in RO
    New Friend:
Update Latest Firmware using a USB cable.
Posted on Sep 27, 2013
How can I connect a tiny-150 compact reverse osmosis water filter to the water supply?
Water Supply Connection uses metPure Universal EZ RO Adapter that fits both 1/2" and 3/8" supply stops.
Amazon $20.00
9mhakhhf6wzaqaagfpczwmaaadko7mbaaaa5dhzaaaagplobaaaaeb5ddyaaacgpdobaaaaub6ddqaaacjv1m7+d6jadilb3eqhaaaaaelftksuqmccaa== Express Water RO Feed Adapter Valve Quick Connect for Undersink Reverse...
Apr 06, 2018 | Plumbing
The strings won't stay tightened
Common problem... You need to use a tiny bit of peg drops where the peg goes into the wood of the peg box. Here is a YouTube video...
http://www.youtube.com/watch?v=byau0C5je5Y
Jul 26, 2011 | Maestro 4/4 Size Violin With Case - Mvk441
How do I know which style RO I have. RO 30 or RO 50. It is installed in the basement and has a blue pressure tank. It is plumbed to two sinks and two ice makers
The numbers 30 or 50 indicate the gallons produced by the membrane in 24hrs. If replacing the membrane I would go with the 50gpd membrane. Especially feeding that many locations. The higher producing membrane will supply quicker recovery of RO water used.
RJH2O
Jun 24, 2011 | Culligan Compatible RO Prefilter AC30AC15...
Unde pot gasi niste drivere pt acer aspire 5100...web..usb...mouse...keyboard..sunet..cardrider...
intra aici,selecteaza sistemul de operare si ia ce iti trebuie:
http://www.acer.ro/ac/ro/RO/content/drivers
Feb 27, 2011 | Computers & Internet
I want to unhook my reverse osmosis how do u do that and what are the steps
Here are the steps to remove your RO system. Put a pan and a couple rags under sink to catch any water that might spill.
1. Label all the lines from RO (with masking tape) to remember where they go.
2. Turn the water off to RO system
3. Run all the water from the RO tank
4. Turn the valve off on RO tank.
5. Remove the line to the RO tank and pull tank out.
6. Remove the line to the RO drain.
a. If there is an AIR GAP faucet this line may go there first
b. plug the whole for RO drain or replace the standpipe
7. Remove the product line from RO faucet
8. Remove the water line feeding the RO system.
9. Make sure the valve feeding RO is shut off completely
a. If this valve is a piercing valve you may want to consider replacing the section of copper
plumbing because it will eventually leak if left unused.
10. When re-installing the RO remove old filters, sanitize system and replace with new filters.
RJ
Nov 11, 2010 | Culligan Under Sink Water Filter
Leak at one of the fittings on my Culligan RO system
Too much pressure in holding tank will not cause leaks in the RO unit. All too much pressure in tank will do is cause low or no product water in RO tank. Older Culligan RO systems (H8, H83, H5) had fittings that used metal locking washers and these can cut the RO line after the RO has been moved around while changing filters. Newer styles (AC30, Water Tower) use quick connect fittings and the RO line may work loose after filter changes and system being moved around under sink.
Turn the incoming water off to RO, turn the water off on RO tank, open the RO faucet to relieve pressure and pull the line off feeding the RO tank, inspect (you may want to cut off a small portion of the line at the filter) check the o-ring and re-install.
RJ
Aug 01, 2010 | Culligan Under Sink Water Filter
How to sanitize ac30 culligan RO sytem?
It helps to sanitize the RO system each time you change the filters. Always test the RO water with a TDS meter to determine if the TDS rejection has dropped below 80% rejection. If it has the membrane should be changed along with the other filters. Always wear latex gloves when changing RO filters to prevent bacterial contamination. There are complete instructions on sanitizing the RO in the Culligan manual. Here is the link for the AC30 Manual.
http://www.freshwatersystems.com/support/AC-30.pdf
RJ
Dec 31, 2009 | Culligan Under Sink Water Filter
I HAVE A RO WATER FILTRATION MY PROBLEM IS I CANNOT GET WATER FLOW TO THE WATER STORAGE TANK ALSO I JUST CHANGED THE MEMBRANE FILTER
There may be several causes for this. Here is a list of things to look for.
1. If an activated carbon filter was installed many times carbon fines will plug up the head of the RO housing. Pull the filters out and flush the whole assembly with NO filters in it.
2. The capillary tube (which puts back pressure on the membrane to create water) may be worn out and all the water will run to the drain. Replace capillary tube
3. The automatic shutoff may not be opening to allow for water flow.
4. Shut the water off at RO tank and take the line off from RO filters to see if any water is flowing from housings.
5. The RO tank may also need air. If the air charge is low in tank (7 psi for 3 gal tank) no water can be forced from the tank.
6. If the RO is fed by a piercing valve make sure their is water coming from it.
7. Depending on what type of RO it is their may be a flow restrictor in head of membrane housing that can get plugged also.
I hope these tips may help you,
RJ
Oct 11, 2009 | Culligan Under Sink Water Filter
Ro Ro sound while no accelaration
I think you are on the right track ,The diff sounds to be the cause of your noise
Dec 24, 2008 | 1999 Mercedes-Benz E-Class
HEWLETT-PACKARD M1212nf All-In-One Laser Printer Logo
710 people viewed this question
Top HEWLETT-PACKARD Office Equipment & Supplies Experts
Victorman
Victorman
Are you a HEWLETT-PACKARD Office Equipment and Supply Expert? Answer questions, earn points and help others
