Question about Toys
Nemisis battle copters on same channel
Both battle copters are labeled Channel A near the on/off switch. Both controllers operate both copters regardless of the controllers channel selection switch setting. Is there a way to change the copters channel??
    New Friend:
I just fixed this problem on mine. The helicopters are not actually set on channel A. Not sure why it says that on the bottom. They match the channel on the controller.
Here is how:
-First turn one helicopter on
-On one of the controllers select channel "C"
-Move the throttle stick(on left) all the way down
-Turn the controller on
-Move the throttle stick all the way up and then back down again
-When the light goes from blinking green to solid green that copter is ready
-Repeat this with the other copter but select channel "B" or "A" instead
For some reason it works better when you start with the higher channel, C, first and then work your way down.
Hope this helps!
Posted on Mar 05, 2013
  • Cory Mar 05, 2013
    Here is how:
    Hope this helps!
Just got the Protocol ToughCopter 2, i charged the heli for 2 hours and put fresh brand new batteries in the controller and the controller does nothing but flash the red light constantly. i have repla
check the helecopter see if it has a chennel number selection or it might have channel A channel B and Channel C. Make sure the remote and the Helecopter are set on the same channel if it has multiple channel settings.
Dec 25, 2014 | Protocol Tough-Copter 3.5-Channel...
Quad copter won't lift off ground
Maybe battery is not accepting charge. I would try using a new battery.
Apr 20, 2014 | Protocol Manta 4-Channel Radio-Controlled...
Manta 4 channel rc quad-copter will not calibrate properly
Sounds like the axle is slightly bent and warped from the initial crash. Try replacing the axle and this should solve your problem.
Apr 19, 2014 | Protocol Manta 4-Channel Radio-Controlled...
Rotor spins while charging
You have a bad flight control board. There may be a loose wire near 5be charge port making fontact wi5h the output circuit for the main rotors. Good luck
Feb 26, 2014 | Generic Udi u13 3 channel co-axial...
Copter is charged. it wont respond to the rc though
Turn on the remote control first then the heli the instructions are wrong
(I have the heli)
Dec 25, 2013 | Protocol Manta 4-Channel Radio-Controlled...
Can't figure out how to change frequency on the S107 copter itself (not the controller). Can someone advise. Thx
Found this for you.
it appears that the helicopter dynamically configures the control channel upon first detection of a signal from a controller. So, If you 1) turn off the helicopter, then 2) turn on the controller, then 3) select the desired channel on the controller, then 4) turn the helicopter back on, then 5) hold the throttle down on the controller, the helicopter will start up (after a slight delay) and be controlled via the new channel.
Jan 04, 2011 | SYMA Toys industrial New Syma S107 Radio...
I have 3 s107 and I it says 3 channel on the box and the transmitter says A B C but will only let me select 2 of them. What's the trick on flying 3 at the same time?
Mine's exactly the same as yours. Although the transmitter shows A B C the switch has only two positions, so there's a choice of two only. I doubt it's possible to fly 3 at the same time.
Nov 08, 2010 | SYMA Toys industrial New Syma S107 Radio...
Toys Logo
171 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
