Question about Compaq Computers & Internet
Pioneer dvdrw dvd k17 device what cds can i use for it
Pioneer dvdrw dvd k17 device i got dvdx16 will they work
  • Compaq Master
  • 2,385 Answers
You can use any writeable cd/dvd in this drive.
Posted on Jan 10, 2013
Sunil Panem
  • 80 Answers
SOURCE: pioneer dvd-rw dvr-k17 problem
Hi
Right click on the driver and then click Properties.
On the properties screen, check the device status and then go to the Details tab at the top.
If the details screen shows any errors or problems abt anything other than drivers, then follow the steps below to delete the upper and lower filters from registry.
Step 1: Back up the registry
  1. Click Start and and in the Start Search box type in REGEDIT and hit Enter .
  2. From the Registry Editor window, perform one of the following depending on the operating system:
Click File and then click Export File.
  1. The Export Registry File window will be displayed. Save In: should be set to the Desktop . Next to File Name: provide an easily identifiable filename like “Full Registry Backup”. In the Export Range portion of the window, make sure the radio button next to All is selected. Click Save to save an exported copy of the registry to the desktop.
  2. Step 2: Remove upper and lower filters
The steps below describe how to remove the drivers associated with the drives disappearing. After removing the filter driver keys, the CD recording software will be have to be re-installed.
  1. With a copy of the registry exported, click the plus signs [+] in front of the follow keys in the order they are listed: HKEY_LOCAL_MACHINE , SYSTEM , and then ControlSet . In some cases, multiple ControlSets may be listed similar to the following:
    • HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001 HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002
    or
    • HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001 HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002
  2. Click the plus sign [+] in front of either CurrentControlSet or the lowest numbered ControlSet. For example, in the second list above, ControlSet001 would be the correct listing.
  3. Click the plus sign [+] in front of Control.
  4. Click the plus sign [+] in front of Control.
  5. Click the plus sign [+] in front of Class.
  6. Locate the following key and highlight it in the left window of the Registry Editor (The numbers can be very similar, be careful select the correct key. Another method to find the correct key is to highlight Class, then cut and paste the key below into a Find window accessed from Edit and Find in the Registry Editor.)
    • {4D36E965-E325-11CE-BFC1-08002BE10318}
  7. With the key highlighted, the right pane will have multiple keys listed including LowerFilters and UpperFilters. Highlight LowerFilters and press the Delete (Del) on the keyboard. A confirmation dialog box will be displayed asking if the value should be deleted. Click Yes to delete the value.
  8. Repeat the process for the UpperFilters by highlighting UpperFilters, pressing the Delete (Del) key on the keyboard and again confirming the value should be deleted by clicking Yes.
  9. Exit the Registry Editor
  10. Restart the computer. The optical drives should then be recognized and available for use.
Posted on Feb 25, 2008
SOURCE: HP Pavilion problems with the Pioneer DVDRW DVR-K17
try cleaning the laser lens if you can access it but i guess it is ery hard for laptops. Or maybe you an use an regular CD/DVD lens cleaner try that first. If it doesn't work and stil does the same, then you have to get the drive replaced because such drive rarely being repaird. it has got weak if not defective lens, or maybe motors but as i said this drives rarely being repaired and they always just replace the whole drive. you can eject the DVD/CD drive and get it checked with other Latpops it you have a friend who has one just for testing. thanks red
Posted on Apr 07, 2008
Scott Ellin
  • 558 Answers
SOURCE: detects CD but not DVD
Hi Chopadepve,
Please try this method but be more careful during working out on it:
Since your DVD drive reads cd's, but not dvd's It shows that the hardware works fine. Now we need to Edit the Registry to fix this problem.
1) click the start menu
2) click on "run"
3) type "regedit" and click ok
4) go to string key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
5) delete "upper filters" and "lower filters" in the right side window.
6) right click my computer in the start menu.
7) click properties
8) go to the hardware tab
9) click device manager
10) expand the dvd/cdrom drives
11) right click the dvd rom and click uninstall
12) Reboot PC
Windows should automatically install a clean ROM drive after the reboot otherwise Open the device manager window and click "scan for hardware changes". DVDs just read fine if you have the correct DVD decoders.
If no luck then might be DVD read head wiped out.
Regards
ELLIN
Posted on Sep 12, 2008
  • 3 Answers
SOURCE: PIONEER DVR K17
Hello olejonok,
I ran into this problem while helping a friend with her laptop. Here is the solution:
1) Visit the following webpage: http://esupport.sony.com/perl/swu-download.pl?template=EN&mdl=&upd_id=2031&SMB=YES
2) Download "SOOOTH-01106200-US.EXE"
3) Run the program and follow the instructions, then reboot.
There are several registry filters which, when removed and the system rebooted, re-enable your drive.
Applies to: DVR-K17 VGN-CR220E PCG-5J2L
Posted on Sep 23, 2008
hardkiss69
  • 43 Answers
SOURCE: Pioneer (DVR-K17) DVD RW Burner
Hi, the error code that you have is a known issue from Microsoft that needs a registry tweaks. Error code means "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (code 39)". You can click on this link for your reference http://support.microsoft.com/kb/929461/en-us
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
Hope this helps. Good Luck!!!
Thanks
Posted on Sep 25, 2008
Hello, my Pioneer cd/dvdrw K17 B does keeps not working. I insert a disk. It sounds like it is going to load, but then it give me a message where it says "insert disc"
Probably its the lens problem, clean the lens or you need to higher the intensity of the laser by slightly rotating a preset that is attached to the lens module below the lens, I have repaired almost 80% of the creative cd drives by this method
Jul 28, 2010 | Pioneer DVR-107D DVD±RW Burner
PIONEER DVDRW DVR-K17B ATA Device Issue in HP Pavilion DV9500 Lap
you may need to clean the lens of drive with a wet tissu paper, otherwise the drive might gone out of order, need replacement.
Feb 10, 2009 | Pioneer DVR-107D DVD±RW Burner
Pioneer DVR-K17B
I have the same problem. Has anyone found a solution? I have an HP Notebook dv6700 with a Pioneer DVDRW [DVR-K17B ATA Device]. For the past few months I haven't been able to burn anything to disc. I can't find any firmware updates online. I'm not sure if I need to buy a new drive?
Thank you in advance for any feedback.
Oct 26, 2008 | Pioneer DVR-107D DVD±RW Burner
Pioneer dvd-rw dvr-k17 problem
it's windows problem.
basically you need to edit (delete) registry.
follow this step from microsoft.
http://support.microsoft.com/kb/314060
Aug 05, 2008 | Computers & Internet
Pioneer dvd-rw dvr-k17 ata device
no issue shut down the laptop reset the dvd i mean reconnect it and restart it will automaticaly pick up and if not then thee is a prob wd win they might be corrupted
May 20, 2008 | Computers & Internet
This sounds like you have a Virus or Some other type or Malware that has corrupted your drivers. Please Scan with Avast (http://www.avast.com/), Spybot S&D(http://www.safer-networking.org/), and Adaware (http://lavasoft.com/) all of witch have free versions.
Also it may be that your driver got corupted some othere way if it still does not work try roleing back your driver or updateing it.
Thank you,
Rel
P.s. if that does not work please come back and make sure you give the info that you have
scanned with the above and if you do not reply in this question then make sure you include all
that info with all the info you have already put here. Good Luck!
VISTA and Pioneer DVD DVR-K17
(1) Try to detect manually from control panel "ADD new hardware".
(2) Check the device manger for DVD is not disabled
(3) Check vista is geniue and not tweaked too much
Apr 17, 2008 | Computers & Internet
PIONEER DVR K17
Hello olejonok,
Dec 26, 2007 | Computers & Internet
Computers & Internet Logo
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
