Airtouch usb keyboard - Computers & Internet
How to connect to ipad
Posted on Feb 25, 2013
Dell xps400 usb keyboard driver
http://download.cnet.com/input-multimedia-usb-keyboard/3000-2110_4-108663.html
This package supports the following driver models:
hope it helpa you
Oct 18, 2011 | Dell (002TR) Motherboard
My Acer KU 0760 keyboard is not working at all. Seem as if the computer doesn't recognize it at all. The mouse works in the USB ports, but nothing from the keyboard. Had old gatway keyboard laying...
Try the keyboard in the USB port you've been using for your mouse. Just move your mouse to a different USB port. I know, this seems like a "too simple" solution, but USB ports sometime get cranky.
A question I would have would be: have you been using a PS2-type keyboard prior to trying to use the Acer USB one? Sometimes the BIOS needs the item "use USB port for keyboard" turned on.
Oct 26, 2010 | Acer NSK8458AN Keyboard
Lite on keyboard sk-6000 USB conection windows xp
Make sure that all USB functionality is enabled in the BIOS, especially USB Legacy Mode. If Windows still does not recognize the keyboard, then it is not compatible with USB. USB keyboards can be found as low as $10 pretty easily if all you need is basic keyboard functions.
Feb 11, 2010 | Maxi Switch Silitek SK 6000 Keyboard
WHEN I TURNED ON COMP KEYBOARD KEYS NOT TYPING AM USING ONSCREEN KEYBOARD
You dont specify weather it's a ps2 or a USB keyboard.
First try setting your bios back to bios default. If it's a USB keyboard make sure all USB ports are working in device manager. If its a PS2 keyboard(round plug) try using a USB keyboard which can be bought for a few dollars.
Best wishes,
Graemevm
Dec 22, 2009 | Gateway 2520915 Keyboard
I am looking for a listing of all smartphones that sync with Outlook.
For United States: (alphabetically by service provider)
Airtouch, Alltel, Arch, ATandT, Cellular One, Cellular South, Centennial, Cincinati Bell, Cingular, Manx North America, Metrocall, MetroPCS, Nextel, Nextel (Boost), nTelos, Sprint PCS, Suncom, T-Mobile, US Cellular,Verizon Wireless, Virgin Mobile, West Central.
http://messaging.office.microsoft.com/HostingProviders.aspx
Choose your country from the drop-down box
Choose your service provider
I hope that this information was helpful.
Dec 13, 2009 | Microsoft Office Outlook 2007 for PC
My computer only has usb connection for keyboard. The keyboard does not work during start up, therefore I cannot connect to bios or setup. How do I resolve this issue?
try putting your usb keyboard in another usb slot and see if it works. If not get another USB keyboard and use that. Also make sure other usb deives are working so you know its a keyboard issue and not a usb issue.
Sep 13, 2009 | Dell Dimension E521 PC Desktop
MANUAL FOR KEYBORD 5188
Type 5C Keyboard to USB Adapter
Operation Manual
Type 5C Keyboard to USB Adapter 5188
TYPE 5C KEYBOARD TO USB ADAPTER Page 1
This equipment generates, uses, and can radiate radio frequency energy and if not installed and used in accordance
with the instruction manual, may cause interference to radio communications. It has been tested and found to
comply with the limits for a Class A computing device in accordance with the specifications in Subpart J of Part 15
of FCC rules, which are designed to provide reasonable protection against such interference when the equipment is
operated in a commercial environment. Operation of this equipment in a residential area is likely to cause
interference, in which case the user at his own expense will be required to take whatever measures may be required
to correct the interference.
Contents
Chapter Page
1. Specifications 2
2. Introduction 3
3. Installation 3
4. Technical notes 3
5. Part Numbers and Accessories 4
1. Specifications Compatible with:
Sunä Type 5C keyboard and mouse (includes Sun Type 6 keyboard)
Ultra Spec Server Control Switch, P/N 5185 or 5195
Sun Sunblade 100 workstation
USB compliant PC workstations (a USB compliant operating system which supports the USB HID 1.1
device class specification is required)
Power:
USB bus powered device. Current load is 100 mA max (adapter only). If also powering Type 5C keyboard
and mouse requires an additional 400mA max.
Size:
4.0” x 2.4” x 1.0”
Shipping Weight:
1 lbs.
Warranty:
Ultra Spec Cables, Inc. warrants all hardware and components of the Type 5C Keyboard to USB Adapter,
with proper installation and normal use, for one year from the date of purchase.
During the warranty period, Ultra Spec Cables, Inc. will, at its option, either repair or replace hardware and
components that prove to be defective.
If your product should fail during the warranty period, phone our technical support department at 1-800-
622-2537 for warranty service (return to factory) instructions.
TYPE 5C KEYBOARD TO USB ADAPTER Page 2
2. Introduction
The Type 5C Keyboard to USB Adapter (P/N 5188) allows a USB compatible workstation to be connected to the
Server Control Switch (P/N 5185 or 5195). The adapter converts keyboard scan codes from the type 5C keyboard to
equivalent USB keyboard scan codes. The adapter also converts the mouse data to USB compatible mouse data.
The Type 5C Keyboard to USB Adapter can also be used in a standalone setup, where it is connected between a
Type 5C Keyboard/mouse and a USB based workstation.
3. Installation
3.1 Between Type 5C keyboard and workstation (standalone operation)
For all installations it is recommended that the equipment be powered off for system interconnection and/or changes
to a setup.
• Connect the port labeled To Type 5C Keyboard to either minidin8 connector on the Type 5C keyboard using a
straight through minidin8 cable (P/N 8002 or equivalent). If using a mouse, connect it to the other minidin8
connector on the keyboard.
• Connect the port labeled To Computer USB Port to any workstation USB port using a USB Type A to Type B
cable (P/N 4021 or equivalent). This type of cable is used for connecting a HUB or other device upstream to
another HUB or a host controller.
3.2 Between Server Control Switch and workstation (system operation)
to a setup.
• Connect the port labeled To Type 5C Keyboard to any Server Control switch CPU port using a straight through
• Connect the video output of the workstation to the Server Control Switch video input connector using an
appropriate cable/converter for connector and sync conversion
• Connect and power on the rest of the Server Control Switch system per the appropriate installation instructions.
4. Technical notes
Keyboard
The Type 5C Keyboard to USB Adapter emulates a Sun Type 6 USB keyboard (P/N 3201273-01) and a Sun
Crossbow USB mouse (P/N 3703632-01). The Type 5C and Type 6 keyboards match in available keys, however
several keys are relocated on the Type 6 keyboard. The adapter appropriately maps the key codes generated to the
key legends on the keyboard (i.e. all keys work the way they are labeled).
TYPE 5C KEYBOARD TO USB ADAPTER Page 3
Important Note Regarding Standby Operation:
USB supports a SUSPEND/RESUME capability that has various and incompatible implementations across differing
hardware platforms. This can affect the operation of the adapter if the workstation supports a low power or standby
mode with an incompatible implementation. Low power or standby mode is normally activated through a menu
selection (using the mouse) or by pressing the POWER key on the keyboard (upper rightmost key on both the Type
5C and Type 6 USB keyboards). For this reason, the POWER key on the Type 5C keyboard IS DISABLED when
using the adapter. In addition, it is important not to activate low power or standby mode through other means.
WHEN IN LOW POWER OR STANDBY MODE THE SYSTEM MAY NOT WAKE UP THROUGH
KEYBOARD OR MOUSE ACTIVITY, REQUIRING A HARD POWER-DOWN TO RECOVER.
In addition, the POWER key on the Type 5C keyboard does not have the capability to power-on a system as it
would when connected to a Type 5C compatible workstation (nor does a Type 6 USB keyboard have this capability
when connected to a USB workstation).
5. Part numbers and Accessories
5188 Type 5C Keyboard to USB Adapter
4021 Cable, USB Type A/B, M/M 0.5M
4022 Cable, USB Type A/B, M/M 1M
4023 Cable, USB Type A/B, M/M 2M
4024 Cable, USB Type A/B, M/M 3M
4025 Cable, USB Type A/B, M/M 4.6M
Jul 10, 2009 | HP Multimedia Cordless Keyboard/Mouse...
USB Keyboard will not access BIOS.
Hi there.
Get the PS/2 keyboard and go back into the bios, make sure all the USB controllers are set to "enabled", save the changes and exit the bios, the computer will restart and your USB keyboard should now work and you will be able to access the bios using the USB keyboard.
Good luck and thanks for using FixYa!!
Apr 29, 2009 | Computers & Internet
Is it possible to unlock omnia 930sc here in the philippines
Yap. but the software should be replace or reflash or reformat.Changing hardware parts depending on the imei code and the country where it came. hope i helped you.Just go to your authorized mobile phone shop or repair center like junrex , airtouch or wellcom
Apr 15, 2009 | Cell Phones
I need to unlock my samsung 820sc here in the philippines
Go to your nearest network provider or mobile phone phone distributor.like junrex, airtouch, wellcom,
Open Questions:
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
