Question about Toshiba Satellite P35-S611 Notebook
Ii forget how to switch from battery service to plug-in service, can you help me? I know it is an easy fix, but can't find the switch
  • 1 more comment
  • cherbess Jan 21, 2009
    It should switch automatically to AC adaptor when it is plugged in, but it does not.
  • Dan rogers
    Dan rogers May 11, 2010
    Then there is something wrong with the computer. The pins that connect to the a.c. port may not be in contact any more. Or the adapter itself may not be good anymore. Can you test the adapter or try another one?
  • Dan rogers
    What do you mean battery service to plug-in service. Whenever the laptop has the adapter plugged in and it is plugged into the wall you are running on the power coming from the wall.
I forget my bios paswordof my wipro laptop
This is a somewhat easy fix, but it'll come down to how handy you are with electronics. If you're not, take it into a service shop and tell them what I say below.
First, make sure the laptop is not plugged in and the battery is out. No power at all!
Basically you just need to remove the battery that is inside the laptop's motherboard. It's like a large watch battery, about the size of a nickel and will pop out relatively easy. Once it's taken out, it will reset the bios to it's default settings.
So: take it out, wait for 15 minutes just to be sure, and then put it back in. Put the larger laptop battery in and boot up.
Aug 12, 2014 | Computers & Internet
My 1987 Ford Bronco II won't start
First you always test things & never replace anything
When you understand how things work & how to test
them,then they have to fail a test in order to need replacing
I would think Fuel Pump--if it quite while driving
Put a gauge on the motor if you have a shrader
valve to do so
Seldom do you need to replace a dist
The parts inside can be diagnosed & replaced
if you can source them
Things like plugs,wires & such you leave until you
know if you have fuel pressure,spark & so on.
Once a vehicle gets to 20 years of age you start
checking for wire corrosion such as around fusible links
Never forget the battery & it's cables & the internal
corrosion possible there
Worn ignition switch a possible
You say won't start,so I assume the engine
does turn over?
Oct 01, 2012 | 1987 Ford Bronco II
Just bought the EWI4000s plugged it in but no sound.
First of all I recommend reading your entire manual cover to cover. Then read it again with the EWI in hand. Go step by step following the setup procedure. You have a complex instrument so it is very easy to miss something or make a mistake. Here is a link to the best wind synth website in North America:http://www.patchmanmusic.com/ There is an 1/8" jack on the instrument for headphones. There is also a 1/4"unbalanced jack for plugging into an amp, mixer etc. Here is a link to the manual if you didn't get one:http://www.akaipro.com/ewi4000s/?tt=5 It is battery powered ( 4AA batteries ) so don't forget them. It can be powered by an optional MP9-II adapter (use the exact model ). It has a built in analog synth so if you set it up correctly you should get sound right out of the box. Hope this helps.
Oct 26, 2010 | Akai Ewi4000s Electronic Wind Instrument
Forget security question
Am sorry but Yahoo has their policies very estricted for your own proteccion.
If you have forgotten your yahoo password and you cannot provide the same information you gave during registration or when you last updated your account. Without the correct verification information,You will not be able to obtain a new password. If there were a easy fix it would be open to abuse from hackers...Sorry. If you need more assistence please let me know Your rating is very important to me Was this information helpful?
May 23, 2009 | Yahoo Mail
No Response from Wenger / Swiss Gear Daytona II on MAC
I had the same problem but i figured out how to fix it,on the usb part of the mouse there is a button you have to press, and also the connect button on the mouse(near the on o/ff switch). Hope this helps.
Feb 06, 2009 | Wenger DAYTONA II Mouse
Whirlpool Ultimate Care II spins only once in a while :-)
hi there,
sounds like the timer switch. the switch is mechanical, so it's quite easily replacable.
also, the overfilling is a result of the pressure switch no engaging. this switch senses the water level and once it's up to capacity, it will shut off the water supply into the tub. check the switch and switch wire to make sure it's working correct. this switch is also mechanical and easy to fix.
let me know if i can be of more help.
thanks
Sep 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Jeep cherokee infinity amplifier
yes, you have a few options. Chances are, its your amp.
1st I would test the speakers - find the amp under the back seat, then test which wires go to the front speakers and use a AA battery to check if the speaker pops with those two wires and the battery.  If it does pop, its your amp needing replaced.  You can switch out that infinity amp for an aftermarket one very easy. Just use a testlight, or voltmeter to test the wires, and switch them to a new 4-channel amp.
if you need the wiring diagram, let me know...and dont forget to rate me! or ask for more help!
Sep 04, 2008 | Car Audio & Video
Blackjack II will not start
This has happened to my Blackjack II and I've found if I plug it into the charger then plug the charger into the wall, the phone comes right on. It's a pain, however, if I'm not at home when it decides to do this since no amount of button pushing will turn it back on, it acts like the battery is dead (when I know it isn't!)
BTW, I've have to have my SIM card switched out twice and the battery replaced 4 times since I bought this phone brand new in February......
Aug 30, 2008 | Samsung BlackJack II Smartphone
Sandisk
yall advertise free help then try and charge forget you the add said free then when i clicked on you wanted money i will find someone that knows something and wont charge thank you anyway
Feb 20, 2008 | SanDisk ULTRA II 4GB Compact Flash Card...
Limited edition sidekick II
You can by a battery on ebay.
Here is a guide to help you along.
Sidekick II Battery replacement
Oct 03, 2007 | T-Mobile Sidekick II
Toshiba Satellite P35-S611 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
