Question about Vizio P2 42 in. HD-Ready Plasma Television
Vizio p42 When it comes on it works fine but when I shut it off it will not come back on is it the mainboard or power supply problem
  • 92 Answers
Power supply
Posted on Feb 09, 2009
The sound on my vizio model no is vp322 hdtv10a comes on for a short time and then it goes off and the only time it will come back on is when I cut hte TV off and after a while and the cut it back on.
You may have a bad power supply, or the voltage regulators on the main board are flaky. It may be a bad capacitor, generally a visible difference from the other capacitors will indicate the candidate.
Vizio has a recurring problem with \'adjusable\' voltage regulators on their mainboards that produce the sub-5 volts components desire.
So, it is a component that is heat sensitive, has a bad / cold solder joint, or possibly the power supply capacitor that drives the sound ICs and amplifier.
Oct 27, 2014 | Vizio Vp322 Hdtv10a Crossover...
Vizio P42 HDTV no picture
Try first unplugging power cable for thirty minutes, then plug back, this will drain power from TV completely and will reset it.
See if it works.
Oct 18, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
HELP PLEASE Vizio Plasma tv broken again - possible driver board?
This could cause by the power supply or the mainboard.
- If the LED stay Green when you turn on the TV. But you can not turn it off, in this case the main board has failed. Replace the mainboard will fix the problem.
- If the LED light always stay at Orange, you can not turn on of off. In this case the mainboard also has failed.
- If you turn on the TV you will hear the power supply click on the LED is green then it click off the light turn Orange. In this case the power supply has failed.
Which boards did the repair shop replace?
Hope this will help.
Feb 18, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
yes you need to check the power supply board going to the pitcure tube board common problem bad transister
Oct 12, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
SMPS power supply for Vizio p42
Sure:
http://www.vizio.com/support.aspx
Call the support phone number early in the morning!
solutiondoct
Sep 05, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio P42 Plasma HDTV10A
THE CABLE INPUT IS SERVED ON 22" VIZIO HOW AND WERE CAN I GO TO FIX THIS PROBLEM IN ATLANTA
May 19, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio p42 type sp42a nov 2004 hd tv
POWER SUPPLY OR LCD PANEL INVERTER BOARDS . AVAILABLE THROUGH VIZIO , PARTSTORE.COM OR EBAY
May 14, 2008 | Vizio L32 32 in. LCD HDTV
WILL NOT TURN ON
Likely a bad power supply. If it uses the same PS as the L6 it's part # is adp-60cf. The PS is used in numerous vizio models including the p42. Check the output plug on the PS, pins 1 & 2 should be 16V, and 3 & 4 are ground. There is also a slo-blow fuse soldered onto the board very close to the AC in plug.
Sep 04, 2007 | Vizio L6 20.1 in. HD-Ready LCD Television
Vizio P42 dark haze when turned on
This is an ongoing issue with the Vizio 42" series. The SMPS power supply has been a problem in all the Vizio models since day 1. We repair these sets and I do not recommend them at all, they are very unreliable. The SMPS power unit is board replacement only at this time and very expensive. Joe Weibel Custom Electronics Memphis, TN 38133 (customelectronics.org)
Jan 07, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio P2 42 in. HD-Ready Plasma Television Logo
88 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
