Question about KitchenAid Architect Series KEBC107KSS Electric Single Oven
Cant find oven light switch
Switch not there any other place
    President:
  • KitchenAid Master
  • 2,651 Answers
The switch is part of the latch assy, it most certainly is, it is quie possible, htat the heat of a self clen cycle, has melted/malformed the plastic latch housing causing the "Plunger " to become dislodged, and is sitting within the opening somewhere. bit it is ddefinalty part of that assembly
Posted on Jan 22, 2009
MEW 7627A double ovens keep cutting out with a click and then turns itself back on again. The control panel has been replaced and it is still doing the same thing
Hello Sheryl;
My name is Peter. I am a retired field service appliance technician.
If your unit is new it should still be under warrantee for one year.
Who replaced the control board was it a service company? You should have a 90 day warrantee on the work, which did not work.
Anyway, you may have a bad; "Infinite Switch".
An infinite switch allows the user to set the heat from low to high and everywhere in between, hence the name "Infinite." This switch differs from a "Low-Medium-High" switch, which provides only three heat settings. The infinite switch uses a bimetal switch and physically moves through the process of heating and cooling, causing the main switch contacts to open and close and controlling the power applied to the heating elements.Typically, when an infinite switch malfunctions, the surface element will not heat, or it will remain on high in every position.
  1. Before repairs or testing can begin, you must disconnect the electricity at the fuse panel, at the circuit breaker panel, or by pulling the plug. Make sure the power is off before proceeding. A jolt from 220 volts can be fatal, use caution!.
  2. Next, depending on your appliance type/model, access the infinite switch using one of the following methods:
    1. For most standard models, remove the back panel.
    2. On models with front-mounted controls, the panel is attached with screws on both ends. Remove the screws and tilt the control panel, being careful not to let the wires disengage from the components.
    3. For models with a removable backsplash, simply lift the backsplash, rest it on the cooktop and remove the screws to access the components.
    4. If you are working on an eye-level range or wall oven, remove the control panel by opening the door and removing the screws that secure it. The screws may be located under the front of the exhaust hood or below the control panel. If the control panel is hinged, tilt the control panel towards you.
    5. Some models will require that you remove the rear panel and front panel before work can begin.
    6. If the front control panel is glass, remove the screws securing the trim that holds the glass in place.
Test for continuity between the switch contacts:
  1. Remove all wires from the switch terminals. (Remember to label them!)
  2. Set the infinite switch on high and place your ohmmeter on the L2, H2, P and H1 terminals to check for continuity.
    1. If there is no continuity between L1 and H1 or between L2 and H2, the infinite switch is defective.
    2. If there is no continuity between P and H1, the indicator light circuit is defective.
  3. Remove the infinite switch by removing the screws or nuts that hold it in place and install a new infinite switch by following the disassembly instructions in reverse order. Be sure to follow the wiring diagram and install the wires to the correct terminals.
REMEMBER YOU ARE
Feb 16, 2015 | Ovens Ovens
How do I install oven switch in old GE oven?
I would call the place u purchased it and Im sure they could help u sorry I could not help
Sep 12, 2014 | GE Ovens
The oven is not reaching its correct temperature.
This type of problem normally can be ascribed to a defective thermostat. Unfortunately there is no test for a thermostat, it has to be replaced to see if the problem has been sorted out.
One thing you can do is remove the thermostat bulb from the oven and place place it in a position where it will not heat up. Place an oven thermometer in the oven. Switch on and see of the temperature climbs above what you wee seeing before. This is a very much hands on test as you have no control over the temperature that the elements can get to. As soon as you see the temperature reach a point above that seen before, shut down immediately.
Apr 12, 2011 | Tecnik Ovens
The Microwave equipment does not heat any thing when placed on the turntable. The turntable rotates, all the functions appears to be in place , but food does not get heated / cooked Model CE 945G (...
first check the HT fuse enlosed in a black or gray case or the micro switches at the door is faulty, if ok then the magnetron is dead and need replacement.
Aug 06, 2010 | Ovens
Rack does not stop at the right positin
This could potentially be a very easy solution. First you need to verify if when you open the door does the carrier stop immediately regardless of where it is in its rotation or does it continue to a certain point every time and stop in the same place?
If it stops in the same place you need to adjust the alignment bar on top of the shaft. On top of the oven remove the metal shields covering the rotation and lift assembly. You will see a steel ring with two small bars coming out of it attached to the top of the shaft, these bars strike the rack alignment switch when the come around. Have someone on the ground center the rack carrier. Loose the metal ring set screw and turn it until it is sticking the switch, you'll hear it click. Tighten it a little bit and have them start the oven and open the door to see if it stops straight. Continue making adjustments until it is stopping straight.
If when you open the door the rotation stops immediately regardless of which way the carrier is pointing then you have an issue with your rack alignment or pointer switch. Usually in this case the switch needs to be replaced, but sometimes its just a matter of a wire fell off the switch. Before you try to replace any wires make sure the power to the oven is off.
Jun 05, 2010 | Baxter BXA2G Stainless Steel Gas Single...
Oven heats up then turns off
You have a high limit switch that has gone bad. What this switch does is prevent the tyemp of the oven from continuing to heat up. More like a safety device to prevent a fire. Most oven have this switch in a really hard place to get to and come in different shapes and sizes. I suggest having an appliance tech replace this switch (cost should be excessive) due to its location and the various difficulties that you may encounter
Hope this helped
Dave
Feb 02, 2010 | Ovens
Oven switch does not start oven unit, switch does not light up.
Either the switch is bad or the pilot if gas, or relay or circuit if electric. You can test the swtich with an ohmmeter to see if there is power to and from the switch. Use the ohm setting and place one probe on each wire to get a reading. You can get parts and manual at repairclinic.com or partselect.com
Do test before replacing.
Nov 18, 2009 | Ovens
Broken Switch
You will have to remove the oven from the housing to gain access to the other screws that are holding the top console cover in place.
It should not be neccessery to remove the doors.
Once it is out of the unit you should be able to see any remaining screws that are fixing the console panel.
Plz rate my solution.
Thanks.
Jan 11, 2009 | Ovens
Kemore oven door signal
The door switch is faulty or not closing.Without the model the switch may be in different places.where the door closes check to see if theres a button if there is thats the switch.regardless look around the seal of where the door shuts for the switch.When you do find it simply disconnect the wires from the switch (there should be 2) and put them together.this should solve your issue.
Feb 23, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
KitchenAid Architect Series KEBC107KSS Electric Single Oven Logo
73 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
