Question about Linksys Wireless-G WRT54G Router
Loss of wireless settings
Once I get everything setup and going. In about 2 or 3 days I loose my wireless conection but my wired connections still works. all I have to do is unplug the router and let it start over and then I get my wireless connection back.why? this is annoying can anyone help. my laptop and ipod etc show the signal but wont connect until I unplug and plug back in.
  • peivlex Jan 21, 2009
    My lappie always cant connect to the internet.. But my desktop which is connected to the modem straight still can be used..
    So i figured it has to be the router's problem.. But im not really sure wads wid it.. N even if my lappie gets to connect to it, it's connected wid limited access..
  • 33 Answers
What you can do is go into your routers settings via 192.168.1.1 and put in the username and password. Go into the wireless tab and change the wireless channel to 8 or somthing. Everyone usually has it set on 6 and this can cause a large problem if there are alot of wireless networks in the area.
Gary
Posted on Jan 25, 2009
I have the belkin surf n300 and i am trying to get my xbox computer ipod and wii to conect to it but it will only connect to 1 thing at once and that is when i hit the wps button on it. The light that is...
Try this .
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
PS3 And XBOX :: BELKIN
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Regards
TOM
Jan 06, 2011 | Belkin Surf N300 Wireless N Router
My ps3 has an error 800100a it doesn't detect any near my routers
Is your wireless turned on both on the system and the wireless router? Do you have a wireless connection setup?
If not then these may be your issue. You also need to go into your internet settings on your ps3 and the select your connection type for example: wired or wireless then > select scan> if there are any in the area select your> rename it if you want> put in the passcode if there is one> make sure everything is correct> then test the connection. If the test works then your fine.
On the other hand if you don't have a wireless router or a wireless connection setup on that will be an issue. with your wireless router they should have included instructions on how to setup the wifi network. Follow those and the problem should be solved rather quickly. Once the wifi is set up just refer back to my previous paragraph and follow those instructions again.
May 06, 2010 | Sony Playstation 3 (PS3) Console
Ok i want to play xbox live but i keep getting a really slow conection because my nat is not open i have tried everything and its not working but my router is not wireless it connected with wires can u...
Step 15:Enable UPnP
Open Router setup
Feb 24, 2010 | Belkin (F5D8231-4) Wireless Router...
I want to setup a wireless connection
To set up wireless connection, first you will need to access the router set up. yhen change the wireless settings on the computer.
Secure the wireless network and then try to connect to the wireless network ?
Click Here for step by step info
Nov 22, 2009 | NetGear WGR614 Router
Ihad internet conection how would i connect d link 802.11 wireless router to make my laptop wireless
connect your modem to the router and go into the setup of the router and set up the wireless settings for your wireless network
Oct 05, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Linksys WRT160N PROBLEM... PLEASE HELP...
Some time what happer router will start blocking the data , in that case what you have to do is that you need to reconfigure the linksys router . First press the reset button for 30 sec , then remove the power for 30 sec and now your router is ready to reconfigure with your setup disk .
if you dont have the setup disk , i am pasting some router reconfiguration steps and i am sure that will help you out .
Please Double Click on the Internet Explorer and on the Address bar,
type in 192.168.1.1 and Press Enter.
Leave the Username blank and type "admin" in the password.
Step 04:
Configure Wireless Settings:
1. Please click on Wireless tab on the router's setup page.
2. Make sure that the Wireless Network Mode is set to Mixed.
3. Change the Wireless Network Name or the SSID from Linksys into your name.
4. For the Wireless Channel, please change it from 6 to 11.
5. Enable the Wireless SSID Broadcast
6. After that, please click on the Save Settings button.
Apply Security Encryption
1. When the router's setup page appears, please click on the "Wireless" tab.
2. When the Wireless area appears, click on the "Wireless Security" sub tab.
3. When the Wireless Security area appears, Change the Mode to WPA personal.
4. Enter the password of your choice in the WPA shared key (it should be minimum 8 characters) and then save the settings.
Step 05:
1. Under Basic Setup tab and set the "Internet Connection Type" to
Automatic-DHCP. After that, please save the settings.
2. Click on the the MAC Address Clone sub tab.
3. In the “MAC Clone” section, set the option to Enable.
4. Click on the Clone Your PC’s MAC button.
5. After that, please save the settings.
Step 06:
Power Cycle:
1. Unplug the router’s power cable.
2. Unplug the Broadband modem’s power cable.
3. Wait for 30 seconds.
4. Plug in the Broadband modem’s power cable and wait for its
lights to stop blinking.
5. Plug in the router's power cable once the modem’s lights stop
blinking.
6. Finally, Test the Internet connection.
Apr 11, 2009 | Linksys WRT160N Wireless Router
Sir, i cant acces irles internet conection from my room,becuse i don't know pasword
Try accessing the configuration page of your router by typing 192.168.0.1 on the address bar of your browser and log-in to the dlink.
>Configure your wireless setting on this window.
>Under setup click on wireless setting
>Then click on manual wireless ....setup
>You will have the configuration of your wireless network.
>You may use WEP or WPA for your password on your security
>For WPA with pre shared key or passphrase the minimum character for your password is 8 characters
>For WEP with pre shared key of passphrase the minimum charactere for your password is exactly 10 characters.
>Once you have save your wireless network
>Go to your laptop and connect to your wireless network before
connecting to the Internet.
Jan 12, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Ativa router
ok, fine....
Reset the Ativa router to factory defaults. This is normally accomplished by holding the reset button down for 10 seconds or more with power on for most routers.
Once you do that, you need to connect the computer directly to the motorola modem and configure it to be in "bridge mode".
Putting your modem into bridge mode means to bypass the router function and make it work as a simple modem. And, yes, if you do that then you must configure your wireless router to make the internet connection. If you don't want to do that, you can leave the modem as it is, I think the Ativa wireless router can still work even if your modem is still in PPPoE & you can still configure the router as an ethernet switch & wireless access point.
Now you can connect the router (after powering EVERYTHING down), turn on the modem, wait for steady connect, turn on the router, wait two minutes, boot the connected PC.
After you get a wired machine connected, you can enter the Ativa setup and configure the wireless security.
Open up IE or Firefox. On address bar, type in "192.168.2.1" and click enter.
Ativa wireless setup should load up. On top right, there is a Log In button. If this is your first time login in, leave it blank and submit.
Check up on the following: a) Internet WAN > Connection Type > select Dynamic; b) Wireless > Channel and SSID > Disable ESSID Broadcast, also set wireless channel to AUTO; b) Wireless > Security > set up your security, you should know what to do.
Now for the most important thing. Click Firewall, and DISABLE IT!! By doing this, it said that you'll will be vulnerable to hacker etc...blah blah, but with security keys to access wireless and virus program/window firewall should be enough to make you stop worrying. Apply changes, then the thing restarts.
*** also leave MTU setting to 1454 & set it to auto connect; leave the DNS & MAC settings alone; also leave LAN settings as it is.
i would greatly appreciate if you could give me the modem's exact model no. (such as SB4200, 2100 etc.) and the router's as well....
Apr 23, 2008 | Computers & Internet
D-link 524 looses conection
check the timeout when idle settings on the router. you need to set it to 0 for never break the connection.
other options are to upgrade the firmware of the router.
you should also isolate the problem by connecting the pc directly to the modem to make sure the same problem doesnt occur. if it does then contact your isp.
good luck
smeags.
Dec 31, 2007 | D-Link AirPlus DI-524 Wireless Router
Problem conecting with the iternet.
Service pack 2 is a more secure version, but it shouldnt effect any internet settings, post back how you are connecting, eg router, wireless, wired. I suspect that when installed the ip address of your pc was altered to XP default, so you may have to go into the properties of your nework cards and ensure that obtain an ip address automatically is ticked, or better still use the wireless connection wizard if you are wireless and the network setup wizard if wired.
Aug 24, 2007 | Fujitsu Siemens (IPAD142-RFI) (IPAD142RFI)...
Linksys Wireless-G WRT54G Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
