Question about Ohaus Pioneer PA214 Lab Balance
8.1 ERR MESSAGE IN OHAUS - Ohaus Pioneer PA214 Lab Balance
Cant see the numbers on ohaus ruby 300
Cant see the numbers ohaus ruby 300
Dec 04, 2014 | Health & Beauty
Ohaus ES50R ES powers tares to zero does not register weight
saya lupa password ID poker88, admin tolong segera bantu saya ya, hubungin ke no ini aj bos admin, 082156894135
Dec 05, 2013 | Ohaus ES50R ES Low-Profile Bench Scale
Ohaus scale won't turn on
Hi Bud, The unit has a built-in adapter which could be the problem but best to call Ohaus directly at 800-526-0659.
ED
Dec 06, 2012 | Ohaus Ranger Heavy Duty Compact Bench...
Need instruction manual for JR Ohaus 300 scale
The Operating Manual for the Ohaus 300 Compact Jewelry Scale may be downloaded here:
http://www.ohaus.ca/PU/PDF/IM%20RUBY%20EN.pdf
Jan 08, 2012 | JR Ohaus -300 Ruby Jewelry Scale, 300 x...
I dropped my Ohaus about 3 feet onto carpet. Now when I turn it on it boots to the E screen everytime. Help!
I am an Ohaus technical specislist. I have unfortunate news. You scale is broken and there is no other way to fix it but get it repaired. You can send it to us at:
Ohaus Corporation
Atten: Service Department
7 Campus Drive
Suite 310
Parsippany, NJ 07054
Jan 02, 2011 | Ohaus CS200 Standard room Scale 200g X1g...
I have a Ohaus gram scale Model N06112 and all the read out says is error code 9.8 and is unresponsive to pressing any of the buttons????
Your problem may have a simple fix. It is called a manufacturing calibration. Unfortunatly it is a little too complicated to answer in this forum. If you will email techsupport@ohaus.com I may be able to help you.
Ohaus Technical Support.
Dec 18, 2010 | Life Science Ohaus Ya-501 500 X 0.1 Gram...
A part is boken inside the measuring cell can I get spares for a AS120 model? for the measuring cell?
Officially at Ohaus the AS120 is no longer supported.
The parts for a PA64 are available. Some of these parts are interchangeble with the older AS120 but I would not recommend an untrained person try to replace them. You can order the parts form Ohaus or any of our dealers. Please remember though all the parts for the AS120 are not available so if something is damaged during the repair it may not be available.
Nov 23, 2010 | Ohaus Analytical Balance Pioneer PA64
OHAUS CS 200. Reads E everytime its turned on
This forum is for Cameras. Please post in a more appropriate forum.
Oct 07, 2010 | Ohaus CS200 Standard room Scale 200g X1g...
Balance is giving me a Err 8.2 message when it is turned on. Unit is an analytical plus model AP250D
The error 8.2 is pretty general. Most likely it is caused by damage to the load cell. There are some things you can try before you decide to get the balance repaired.
1. Turn the balance off and unplug it. Count to 20 and plug it back in anf turn it on.
If that does not work.
2. Put a 100g weight on the platform (the weight does not have to be exact).
3. Plug the balance in and wait for the count down. If the count down starts at 99 you can stop this procedure will not work. If the count down starts at 255 continue.
4.The balance will read error 8.2 again at the end of the count down.
5. Unplug the balance.
6. Remove the weight.
7. Plug the balance in and wait for the count down. The balance should count down and turn off.
8. Turn the balance on and it should work normally.
If this does not work the balance needs to be repaired.
Sep 13, 2010 | Ohaus Measuring Tools & Sensors
Ohaus Pioneer PA214 Lab Balance Logo
196 people viewed this question
Top Ohaus Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you an Ohaus Measuring Tool and Sensor Expert? Answer questions, earn points and help others
