Question about Thetford RV Toilet Aqua Magic V
Water does not stay in bowl
Replace blade seal a year ago, solved problem for a while
How to take out stuck chef bowl
I've not seen a bowl stuck on one of those unless the chopping blade is jammed on the shaft and preventing the bowl lifting up. Or is the chef bowl a smaller bowl that fits inside the main bowl?
Jan 12, 2016 | KitchenAid Professional KFP770 Food...
I have a toto toilet , model MS604114CEFG , bought 2 years ago . Last night , when I flushed it , the water level in the toilet bowl did not come down . It stay high in the bowl . In the tank reservoi
If the toilet is the only fixture in the bathroom group that is having an issue, then there is a partial blockage in Strap of toilet or in drain pipe close to toilet. If other fixtures are showing sluggish drainage, then the main drainage line is clogged. If all is fine with tub lav shower etc., pull toilet from floor and carefully turn upside down, and look to see if anything is visable. if so remove it and reinstall with new seal(wax ring). Also, look into pipe and see if any water is standing in it. If water is standing in pipe, the drain line is clogged and must be rodded(snaked) out to cure problem
Nov 14, 2014 | Toto MS604114CEFG01 UltraMax II Toilet,...
Need to increase bowl water level. how do I do that
Step 1:
Remove the top lid of the tank, ...carefully, so as not to break the ceramic by dropping it on the floor accidentally. Inside exists a "lever" attached to a "float" acting as a "fulcrum," with the "float" resting on the level of the water in the tank. The more water in the tank, the more water will enter the bowl, at flushing time.
Step 2:
The level of water in the tank corresponds to the level of water entering the system upon flushing the commode (bathroom fixture). At the bottom of the tank exists a "flap" type of device (usually). As the water exits the tank into the bowl the flap seals off again, discontinuing the water's entry into the bowl. This should always seal off at the end of a "fllushing cycle." The more water in the tank at the beginning of the flush, the more will enter the bowl.
Step 3:
Therefore, raise the arm of the "lever" (sometimes it's a "vertical" post with an "adjustable float" on it; in what case one raises the float on the post, by depressing a "clip" like device on the float itself, sliding it up versus down) by bending the arm upward, ...carefully. The increased water in the "tank" by the above process should solve your problem. Be certain to note whether the "flap" closes prematurely (It shouldn't), adjusting the flap's "chain" (held up by the "handle" itself) should it close prematurely.
Step 4:
You may need to tighten the "nut" (fastener) on the "handle" inside the tank as the "chain/flap" may simply be closing prematurely, because it's "loose" (easily tightened by hand at times, versus with a small, adjustable wrench bought at a "hardware store" like "Ace Hardware").
Step 5:
The above items (one, versus several of them), should solve your problem.
Jan 19, 2013 | Jacuzzi Bath Maxima EL61 959 White...
How to change out a new seal in toilet water does not stay in bowl leaks out past seal tried cleaning seal still leaks
Hi peglegii...
The main thing to keep in mind when replaceing the seal between the tank and the bowl is it MUST BE LEVEL.
Use a level tool to make sure both sides are tightend down evenly.
Also I would suggest that you let dry overnight all the parts that are in contact with water, after it is dry then use some silicone sealant on the gasket and then tighten down and let dry overnight again.
That should solve your leak.
Please take time to rate me
Aug 15, 2011 | Home
The toilet bowl never stays full of water? It empty's out and if you need to use it for a BM you need to flush it first to get water in the bowl. How do I fix this?
I have the same problem with my Toto TS703. When you flush it, it fills the bowl with water to the rim and stops. Within an hour, the water in the bowl is totally empty except for a small puddle. This has been going on for a few days. It was installed 3 years ago and never had a problem with it until now.
Mar 21, 2011 | Jacuzzi Home
Water is coming out of the tank and on to the floor instead of the bowl, and it's been running, I live in cedar rapids iowa and this system was in the toilet when i bought the house 4 years ago, don't know...
First, try to tighten the bolts securing the tank to the bowl. If that does not stop the leak, you can buy replacement parts at your local home improvement or hardware store. Before you go to the store, count how many bolts secure the tank to the bowl so you know which repair kit to buy.
Apr 12, 2010 | Kohler Cimarron 2-PC Elongated Toilet with...
American standard cadet 3 leaking around seal
get a new filler assembly. the water in the tank is heavy enough to close the seal completely. or the rubber seal is not making contact. thats' why the leak.
change the whole assemble ususally correct the problem.
adjuste the flow to about 1/4 to 1/3 under the over flow. if that still don't give you the pressure. you ca adjust the flow tube to 1/5 under the cover. that is the max.
Oct 28, 2008 | American Standard 2294.011.020 Afwall...
Food processor
I phoned the 800 number at Cuisinart (800-243-8540) and the person who answered the phone explained to me what to do: Fill the bowl with the hottest tap water I have (but not boiling) above the entire blade (including the part that fits over the shaft). He said to pulse a few times, then try to pull it off, but not to expect it to work right away. He said to do this until it comes off and that it could take 1/2 hour. I did what he said, and the blade came off after the first pulses. But also, the water was pouring out all over the counter--leaking between the bowl and the base (possibly because my old work bowl is also cracked, but I'm not sure).
I was told that the problem would happen again, and that I needed replace the blade and the shaft (which is cracked, as he guessed), both of which are available from Cuisinart.
Oct 07, 2008 | Cuisinart DLC-5 Food Processor
Hoover automatic 830 washing machine - leaking from under bowl
The water seal has been damaged. Will need to be replaced by a qualified technician.
Nov 03, 2007 | Washing Machines
Thetford RV Toilet Aqua Magic V Logo
Top Thetford Home Experts
john h
Tom Chichester
Are you a Thetford Home Expert? Answer questions, earn points and help others
