Question about Belkin Wi-Fi Phone for Skype - Wireless VoIP phone - IEEE 802.11g - Skype
Cannot connect to sky router
I have bought one of these clever phones , it will find my sky router but will not connect to it - allthe ip adress etc are there it just keeps saying it cant connect - any ideas?
Oh ps. the connection is currently unsecured - would it make a differance?
  • nigelsolo Jan 22, 2009
    sending me back the question hasnt helped!
  • 48 Answers
Sometime this would because your router is thinking that your phone is a hacking device and so it will not allow full connection so if you put a password on you router it would probily fix your problem
Posted on May 28, 2009
I, I have bought one of these clever phones , it will find my sky router but will not connect to it - allthe ip adress etc are there it just keeps saying it cant connect - any ideas? Oh ps. the connection is currently unsecured - would it make a differance?
Posted on Jan 22, 2009
Can not find ip address on richo 1035. I tried to connect my richo 1035 with computers through internet. I did all to change ports on printer properties section. I am putting ip address of my service...
Connect the machine to a router or a switch with a network cable.
In used mode, under network settings - set the machine to DHCP, so it will get an IP adress from the switch/router.
Print out a network status page, and see if you've got an IP adress.
In the command window on your PC type: ipconfig/all and see the IP adress of your computer. Compare it to the adress the machine got from the router/switch and see if they are almost identical apart from the last digits.
Install the driver, and install the printer using device name, and you should be good to go. Or you can set the IP you got from the switch/router as a static adress, and install the copier using the IP adress.
Jun 27, 2017 | Ricoh Aficio 1035 Copier
Weak connection
improve ur brodband connection
Jun 14, 2008 | Sony Playstation 3 (PS3) Console
I have lost the security code and have a new laptop, how do i set it up to work
Hi!
If you don't remeber the wireless security code, maybe you still remeber the user and password to access the web management interface of the router.
Then you have to connect the laptop to the router by using a network cable. Open a browser window, type in the IP adress of your router and check the wireless setup section. There you can find / modify the wifi security code.
If you don't know the router's IP adress, then open on your computer a ms-dos prompt and type the command
ipconfig /all
it will display your current IP adress, subnet mask and GATEWAY. The gateway adress is the router's IP adress that must be typed into the browser.
If you don't remember the user and password for accessing the router's web interface, please refer to the router's user manual in order to reset it to factory default configuration, and then proceed as for the first installation of the router.
Hope it helped,
Bogdan
Aug 30, 2011 | Belkin (F5D8231-4) Wireless Router...
Can't get access limits to work
there is no internet connectivity
check your router ip adress
check the computer ip adress is same range of router ip
if not,, please assign same range of router ip manually
please letme know this helpful
Jan 07, 2011 | Linksys WRT54G-TM Wireless Router
HI I HAVE BOUGHT THIS ROUTER BUT ARE HAVING PROBLEMS GETTING MY COMPUTER TO FIND IT, THE WAN LIGHT COMES ON GREEN WHEN CONNECTED TO THE DSL BUT WIFI LIGHT IS ORANGE. I AM USING A MACBOOK SO SETUP MAYBE...
do you have fixed IP address on your computer. ? that might be the reason if its diffrient from the routers. if thats not the case give a fix ip address to your computer which is in the range of your router and try to connect it.
examples if your router have default ip adress : 192.168.0.1 give your computer address as : 192.168.0.2 and subnet mask 255.255.255.0 default gatway : 192.168.0.1
Aug 10, 2010 | Edimax Computers & Internet
Need ip address for syrens, not sure if i remember right: 192.168.1.1???
Hi Stephan,
the ip address of your router by default should be "192.168.1.1". to check if the ip adress of your router here's the solution :
  1. go to control panel > network and sharing/networking >change adapter settings
  2. then you'll see your local area connection
  3. right click on it>properties
  4. double click on (internet protocol tcp/ip) "tcp/ipv4 in windows vista/7
  5. the select "obtain ip address automatically" & "obtain dns server464142c.jpg automatically" click ok and click ok for the other window
  7. the dns server ip show should be your router ip adress
  8. open your web explorer and type in your router ip an press "enter" you'll get your router configuration where you'll be able to change the default ip.
I hope that it will help & don't forget to rate
Kind regards
Feb 14, 2010 | Sea and Sea Syrens OnBoard WiFi...
Router wont let ps3 have ip adress
you need to open a incoming port for the ps3 on your router all you have to do is use the computer to go to your router settings then use whatever ip the ps3 is using and open a port for that ip address that should work but i dont have a ps3 so i dont know you could try that
May 09, 2009 | Computers & Internet
HI I HAVE BOUGHT A SITCOM 4 PORT CABLE ROUTER AND CANT SEEM TO FIND THE INTERNET SITE OR MY IP ADDRESS TO INSTALL THE WIZARD
open ur web browser then enter ur router default ip adress and configure ur router then it will work
Jan 22, 2009 | Computers & Internet
Locking the connection
you will need the ip adress of the router and the user name and password enter ip adress in enternet browser it might ask for user name and password Then you would find a seting to protect it by a WEP password.
Jan 02, 2009 | Linksys WRT160N Wireless Router
Cant connect to http://192.168.0.50
what you need to do here is manually set your static IP adress, I had this problem as well and I know what to do.
you need to go to your network connections ( Controll panel>network connections) in xp (Controll panel>network and sharing center then left hand it sais: change adapter settings )
then rightclick your wireless connection and look at it's properties. then you need to click on Internet Protocol, for vista/windows 7 it's internet protocol 4 which you need to select. once selected click on properties just a little below.
there you'll see the setting is on: obtain Ip automaticly, but you'll have to choose ( use the following IP adress ) and enter
IP adress: 192.168.0.99
subnet mask: 255.255.255.0 Default Gateway: 192.168.0.50
once entered press OK and now go to your browser and type the routers adress (192.168.0.50) in my case and now you should be in your modems setup menu.
once changed your setting you need to change your IP back to auto obtain IP adress. or your internet still won't work
Oct 20, 2008 | D-Link AirPlus Xtreme G DWL-2000AP...
Belkin Wi-Fi Phone for Skype - Wireless VoIP phone - IEEE 802.11g - Skype Logo
959 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
